C3 LSx Conversion Directory
Engine: LS1
Engine Mounts: Speed Hound
Engine Accessories: Alt only (underdrive crank pulley)
Waterpump: Stock/Aftermarket: Stock, modified by Superpowers to relocate heater hose fittings
Manual Throttle/Drive by Wire: Manual
Transmission: 2004r (Stage 2 from BTO with 2200 rpm stall) 3.08 currently but on the lookout for 3.50-3.90 rear
Crossmember (stock/modified/aftermarket): BTO xmember made for the 2004r swap
Exhaust Manifolds/Headers: Mac Mid Length Headers (dinged pass side to fit, had to remove factory heat shields)
Wiring Harness (modified stock/aftermarket): Original 71 harness (no FI so only needed to wire starter and alt)
Radiatior/Fan: PRC double pass aluminum rad, Cheap ~15" electric fan (double pass puts i/o on pass side so hoses were easier to route)
Fuel Pump/Lines/tank: Edelbrock quietflo, -6, stock tank
Steering System: Manual (manual R&P planned for future)
Misc info: Edelbrock carb conversion- rpm intake, AED built 750 double pumper. Motor has all forged internals, cnc ported heads, .550" cam, comp lifters, 10.5:1.
Contact info: PM me
Engine: 2004 LQ4, stock, Speed Density tune (removed MAF)
Engine Mounts: Generic -
Engine Accessories: Truck modified with F-body parts minus A/C
Waterpump: Stock/Aftermarket: Stock F-body, modified heater hose locations – Home made water inlet
Manual Throttle/Drive by Wire: Manual throttle body
Transmission: stock 4 sp BORG WARNER T10 with HURST shifter, stock bellhousing
Rear End Gear: 3.36
Crossmember (stock/modified/aftermarket): Stock
Exhaust Manifolds/Headers: SUMMIT Corvette small block long tube modified - 1 5/8 primaries -- 3" collectors. Custom stainless dual 3" exhaust with Thrush Welded Mufflers
Wiring Harness (modified stock/aftermarket): Modified stock
Radiatior/Fan: Single FAN - two speed, aftermarker aluminium radiator
Fuel Pump/Lines/tank: Walbro inline w/C5 regulator, aluminium tubing lines and stock tank
Steering System: Stock power steering with F-body pump
Misc info: All modified is by myself, HP Tuners for dialing things in.
Contact info: PM me
Engine: LS1
Contact info: PM me
COOL... another Carbed C3!
http://www.youtube.com/watch?v=de9BCfp81jk
and first driving out of the shed
http://www.youtube.com/watch?v=OpqNpVFmmLQ
Year of Corvette:1982
Engine:LS1
Engine Mounts: stock 82 with ebay adapter plates
Engine Accessories: stock ls1
Waterpump: Stock/Aftermarket: stock ls1
Manual Throttle/Drive by Wire: stock ls1
Transmission: ls1 4l60e
Crossmember (stock/modified/aftermarket): stock with a little piece welded on to move the mount point 2 inches forward
Exhaust Manifolds/Headers: mac mid lengths
Wiring Harness (modified stock/aftermarket): rewired ls1 fuse box and wiring
Radiatior/Fan: stock dual ls1 fans
Fuel Pump/Lines/tank: stock ls1 pump, factory 82 lines and wiring
Steering System: ls1 PS pump/stock 82 steering ram
Engine: 09 LS3
Engine Mounts: Custom, 1 inch forward
Engine Accessories: Corvette
Waterpump: Stock/Aftermarket: Corvette modified
Manual Throttle/Drive by Wire: DBW
Transmission: T56 from 06 GTO
Crossmember (stock/modified/aftermarket): Stock, modified for T56
Exhaust Manifolds/Headers: Headers,
Wiring Harness (modified stock/aftermarket): Not Yet
Radiatior/Fan: Dewitts, Dual Spal fans
Steering System: Steeroids
Misc info: In progress as of 9/11
This project for my '80 was started in March '11 and completed in Dec.
Engine: 2011 L92 "pull out" converted to LS3
Engine Mounts: Vetteworks, 1in back
Engine Accessories: Street and Performance
Water pump: Stock LS3, 2009 from GMPP
Throttle Body: Stock LS3 DBW, 2009, from GMPP
Transmission: 4L60E, stage II for 500hp max, Century Trans.
Crossmember: Stock modified for 4L60E mtng
Exhaust manifold: Long tube headers, Custom Image
Wiring harness: aftermkt custom, Schwanke
ECM: Reprogrammed/tuned by PCM For Less
Fuel pump: Camero Vetteworks rebuilt, intank w/bypass, single ss feed line
Steering system: Stock using Camero F-body pan
Radiator: HD stock with trans. cooling taps
A/C: Sanden compressor, S&P mtng
Engine: LS2 C6 Vette
Engine Mounts: VetteAid (formerly Speedhound)/Energy Suspension
Engine Accessories: F-Body
Waterpump: Stock/Aftermarket: LS1 modded
Manual Throttle/Drive by Wire: Caddie CTS-V DBW fm Speartech
Transmission: TKO-500
Exhaust Manifolds/Headers: Melrose, MagnaFlow SS exhaust
Wiring Harness (modified stock/aftermarket): SpearTech ECM and harness. Harness modified by VetteAid to integrate w/scty sys & keyless start
Radiatior/Fan: OEM 4-core/Flex-Rite dual
Fuel Pump/Lines/tank: F-Body in-tank w/VettWorks brackets/custom Russell fuelines per /resto stock
Steering System: VB&P Rack Attack
Misc info: VB&P Performance Plus suspension. VetteAid gauge,speedo,tach kit w/custom scty sytem and keyless start. 2004 ZO-6 seats. Retro-fit pdl. Body off resto.
Contact info: pm or check my blog @: http://LS273Stingray.blogspot.com
Engine: LS2, ECU, pedals, harness from '06 GTO donor.
Engine Mounts: Transdapt, modified position
Engine Accessories: Holley LSx conversion brackets - 06 GTO alternator, 06 Corvette PS pump and A/C compressor.
Waterpump: Stock/Aftermarket: stock GTO LS2
Manual Throttle/Drive by Wire: GTO DBW
Transmission: 06 GTO T56
Crossmember (stock/modified/aftermarket): Custom
Exhaust Manifolds/Headers: Hooker Headers
Wiring Harness (modified stock/aftermarket): Modified stock from 06 GTO
Radiatior/Fan: Aluminum 3-core with GTO dual fan
Fuel Pump/Lines/tank: In tank Walbro pump on OEM sending unit. In line regulator/filter with stock return line.
Steering System: Borgeson conversion with C6 oil pan
Misc info: VanSteel rear coil-over conversion.
REMIX:
Year of Corvette: 1980 MT Coupe
Engine: LS2 from '06 GTO donor. Stay away from the GTO LS2 as it is 24x/1x and it's just a headache.
Manual Throttle/Drive by Wire: Holley DBW pedal?
Crossmember (stock/modified/aftermarket): Custom for 3" exhaust
Wiring Harness (modified stock/aftermarket): Terminator X 550-931 with cam sensor wire swap for 24x/1x
Radiatior/Fan: Aluminum 3-core with aftermarket dual fans
Fuel Pump/Lines/tank: In tank Walbro pump on OEM sending unit. In line regulator/filter - wish I would have mounted on drivers frame rail as that is the side of the fuel rail connection!
Engine:LQ9 2004 Escalade, Bored .030 over, Batwing Pan
Engine Mounts:1" set back
Engine Accessories:Holley Accessory brackets
Waterpump: Camaro
Manual Throttle/Drive by Wire:Manual, Cable Lokar
Transmission:Tremec 5 Speed
Exhaust Manifolds/Headers:C5 with 2 1/2 true duals, Flowmaster Delta 40's
Wiring Harness (modified stock/aftermarket):Holley HP
Radiatior/Fan:Alum, F body dual fan
Fuel Pump/Lines/tank:Walbro, in tank using 82 FI with C5 inline filter regulator
Steering System:Jeep-Borgeson Conversion
Misc info:Vintage Air, Dakota Digital, Fiero Seats
Contact info:donpetstop@gmail.com
Engine: Modified LS-1; LS-6 Heads, LS-6 Intake, Magic Stick 4 cam from TSP.
Engine Mounts: 2 position mounts from Custom Image Corvettes
Engine Accessories: Corvette configuration, but at Camaro depth. 3/4" further from engine than Corvette. (Holley kit)
Waterpump: Stock/Aftermarket: Stock (modified)
Manual Throttle/Drive by Wire: Drive by wire.
Transmission: Original Borg and Warner 4-speed
Crossmember (stock/modified/aftermarket): Original stock. No mod needed.
Exhaust Manifolds/Headers: Sanderson Headers
Wiring Harness (modified stock/aftermarket): Stock (modified)
Radiator/Fan: DeWitts direct fit replacement for stock radiator. Flex-a-lite S-blade fan.
Fuel Pump/Lines/tank: Original tank modified to accept Walbro pump.
Misc info: Batwing oil pan. Vararam cold air intake kit for a GTO.
Contact info: PM or email via this forum.
Engine: Stock 5.3 with ls1 intake/rails/injectors
Engine Mounts: eBay billet aluminum
Engine Accessories: Stock truck accessories. Modified alternator bracket
Manual Throttle/Drive by Wire: Drive by cable. Stock truck tb
Transmission: Original th350c
Exhaust Manifolds/Headers: Fbody
Wiring Harness (modified stock/aftermarket): Stock truck (modified)
Radiator/Fan: Stock radiator, electric fan
Fuel Pump/Lines/tank: Original tank modified to accept Walbro pump. Corvette filter/reg
Misc info: Fbody oil pan, stock truck dipstick (modified and bent), using stock check engine light and gauges.
Contact info: PM or email via this forum. 4172248528
Engine: LS1
Engine Mounts:
Water Pump: Modified Stock
Manual Throttle
Transmission: T-56
Crossmember (stock/modified/aftermarket): Aftermarket
Exhaust Manifolds/Headers: Melrose - Coated for the C3 LS Swap
Wiring Harness: Modified Stock
Radiatior/Fan: C5 Fan
Fuel Pump/Lines/tank: Walboro, Steel and Rubber Fuel Lines
Steering System:
Misc info: Custom Exhaust, Push Button Start, RX-8 Seats
Contact info:
Engine: LS1 out of '03 Vette
Oil Pan: Batwing oil pan was retained and will fit easily on a rack and pinon car.
Engine Accessories: modified F-bod to fit C5 supercharger, S&P AC mount
Manual Throttle/Drive by Wire: Manual 90MM UMI Throttle
Waterpump: Stock
Transmission: F-body T56 with LS6 clutch
Clutch Master Cylinder: modified '85 1 ton truck master clutch master cylinder
Crossmember (stock/modified/aftermarket): Modified stock
Exhaust Manifolds/Headers: modified SS Hooker sidepipes with LS1 flanges
Wiring Harness (modified stock/aftermarket): Speartech custom length harness puts computer in rear compartment
Radiatior/Fan: Be Cool with dual Spal fans
Fuel Pump/Lines/tank: Rock Valley SS tank with in-tank pump
Steering System: Steeroids rack and pinion
Brakes: 14" slotted rotors with 6 piston aluminum Wilwood calipers in front and four piston aluminum Wilwoods on stock sized slotted rotor in rear with proportioning valve. Hydroboost assists in the braking.
Misc info: C5 Magnuson supercharger, LS6 heads and cam. If you decide to go with a roots blower, make sure you get a hot rod style as it will make the installation much easier. The Maggies will fit under a L88 hood. Also, highly recommend Speartech for your wiring harness. Asked all the right questions and I ended up with a harness that fit perfectly into the car. Finally, a 700R4 automatic tranny mount will bolt up to a T56.
Contact info: SuprJames@aol.com or PM me here
Video of car: http://www.youtube.com/watch?v=5n0kVNdr8bE
I've already done the LSX swap, but am now swapping for a 4l60e. What did you all do for the output yoke on the trans? Curious what I need to do for the driveshaft as my TH400 had a much larger yoke.
