Hydrogen generaters ?
Old Feb 20, 2009 | 06:23 PM
  #121
toddalin's Avatar
toddalin
Originally Posted by Mike Ward
Please go figure out how much 14,250 L of air weighs.
40.58 pounds.
Old Feb 21, 2009 | 01:43 AM
  #122
slowride262's Avatar
slowride262
Ok,
But here is my concern.
Now if were leaning out the Fuel to Air mixture wouldn't that start a chain of failures like burnt valves,cracked pistons,burnt valve seats???
My thought is fuel (aka) Gas was also a coolant and when you start going over the ratio of like 14:1 mixture that you were ok.
But if you start going under the ratio you started to have these problems.
Your thoughts???
Old Jan 25, 2011 | 09:08 AM
  #123
newbie2vette's Avatar
newbie2vette
Originally Posted by riggs 74
It seems to me that there is a over abundance of pure stupidity of folks that seem to
open their mouths (OR KEY IN) before they decide on whether or not their opinions really
needs to be heard. It is best to remain silent and look knowledgeable instead of speaking
and removing all doubt.
I simply started this tread after running across some hydrogen information after researching
some info about electrons and protons and thought that members of this forum seam to
carry some engineering knowledge but so far I have not seen many intelligent replies.
To all that have replied in an intelligent manner, Thank you.
Back to the topic.
I'm looking at Hydrogen generators (not Hydrogen cells) for two reasons.
1st, I have read about (no info-mercial crap) but stuff that the average Joe's from around
the world have been working on, some impressive and some not at all.
2nd, If nothing else, I have gained more knowledge about many different things
since I started this tread, and all my searches and also I well have a pretty cool
Hydrogen touch to play around with when I'm done if not a lower fuel bill.
Thanks to all that have and to those who still may reply in an intelligent manner.
Riggs.
My apologies if I "Revived" an old thread. I was updating the thread I started asking about retarding the timing on my 1972 LT1 to accommodate the hydrogen I am inducing, when this thread was revealed as a related topic. I can honestly say spending 22 yrs in the Navy have shown me a great deal of tech, this is one of them. yes this theory is been around for some years it was even used by some stock racers to augment combustion but the fuel crisis was not around.
My question to support the gentleman who started this post is: How many of you drives trucks with 5.0 liter and bigger who gets 17-19mpg in the city and 23-25 on the highway doing 75-80mph? I can name one, and several other diesel powered cars and trucks in my area. My sceintific definition this process should not work and thermodaynamics is not met to support what is taking place during the combustion process in any ICE. I did a high school lecture on the topic and the easiest way I can sum it up is:
normally during combustion one, I mean one spark plug generated the iginition, inducing hydrogen during the combustion cycle is like having hundreds of spark plug to iginite the air fuel mixture, hence instead of push the unburn fuel out the tail pipe, you burn it. what happens when you burn additional fuel, power and when you have additional power your power to weight ration changes.
another example I was able to do was take a lighter, many have seen this. take your standard lighter and turn it on, consider that the flame from a standard combustion process, now take a spray can of anything, it would flare up, consider that with hydrogen being induces. you can take 3" X 11" 316L SS plates and run them -NNNNN+. That's a Cathode (-) bipolar plates (N) and anode (+) attach a 12v to it from your car batt submerged them in a bucket of water with a little NaOH or KOH, even salt for the experiment purpose you will create HHO.
The process has become much simpler than when it was initially introduce to the general public, initially the "wet cell" (it got hot fast)was the unit, now a "Dry Cell" (you can run it for hours 4-8 hours at a time like most semi) are the prepared unit. The unit I designed does not store any hydrogen, it only store the solution mixture as the electrolyte and the scrubber (vinegar mixed with distilled water 50-50). The only extra step needed to be done is making sure the alt in the car is strong enough or upgrade to a high output one (vette has a 140 amp) at idle it produce 40 amp.
Old Jan 25, 2011 | 09:22 AM
  #124
noonie's Avatar
noonie
Timely, just the other day, I saw a news report where the US is using a new unmanned 100% hydrogen powered spy plane that will fly at 65,000 feet and stay up for a month at a time, mostly because the weight of the fuel needed has been eliminated. Of course, the cost for this is probably astronomical too.
Old Jan 25, 2011 | 09:25 AM
  #125
newbie2vette
Actually, it is thousands less and it is being used to augment the jet engines to lower heat, to quite the turbines and use less JP 5.
Old Jan 25, 2011 | 09:34 AM
  #126
noonie's Avatar
noonie
Well if that's really the case, the news media is about as accurate as usual
Here's a google that confirms the elevation but drops the time down to four days. Maybe I missed part of the story.
http://www.foxnews.com/scitech/2010/...e-phantom-eye/
Old Jan 25, 2011 | 10:16 AM
  #127
MrJlr's Avatar
MrJlr
Tree-huggers....
Old Jan 25, 2011 | 11:01 AM
  #128
Mike Ward's Avatar
Mike Ward
Too...much....BS.....and.....bad....scie nce......
Must...not...take...bait........
Old Jan 25, 2011 | 11:25 AM
  #129
TopGunn's Avatar
TopGunn
http://www.switch2hydrogen.com/h2.htm
Old Jan 25, 2011 | 11:57 AM
  #130
wcsinx's Avatar
wcsinx
This paragraph demonstrates at least 2 fundamental misunderstandings of the operation of an Otto cycle gasoline engine. Please go educate yourself on this first. Take off the aluminum foil hat. And then try to make a coherent post.
Old Jan 25, 2011 | 12:07 PM
  #131
Mike Ward's Avatar
Mike Ward
And the following includes 2 more.........
Ooops, must not take bait.
Old Jan 25, 2011 | 12:44 PM
  #132
bryanpl123's Avatar
bryanpl123
I know most of you discount the possibility of a device like this working... and yes it does violate the laws of Thermodynamics if it were to work as advertised... it does require more engergy to create they hydrogen then the hydrogen provides to the fuel supply.
The most recent and probable claim is that it is works because it uses the extra power that your alt produces when the rest of the system isn't using it... excess power(previously wasted energy).
I'm not entirely sure, but atleast on new vehicles the alt only kicks on for as much as it is needed...so there would be very little to no excess energy....
Whats the case for the alt in our old C3s? don't they run constantly?
I'm not going to try it.... but if you do..it may have some validity
Old Jan 25, 2011 | 12:57 PM
  #133
bashcraft's Avatar
bashcraft
Spin constantly? Yes.
Produce electricity? Only when needed.
Old Jan 25, 2011 | 01:33 PM
  #134
wcsinx's Avatar
wcsinx
Yeah, that's a really cool new feature. It's only been around for ... mmm ... 50 years or so.
Old Jan 25, 2011 | 02:09 PM
  #135
newbie2vette
http://ntrs.nasa.gov/archive/nasa/ca...1977016170.pdf
I am not here to promote this and since everyone seems to have the ability to research negative media on the subject, try looking for research paper such as the on in the link. I use to be along everyone's opinion on this, but instead of going by what a third party is saying about it I decided to develop my won conclusion and started to build them and test them. the last test I wanted to do was on a carborated engine, since my wife wanted a corvette and it's the same era as the one NASA tested I wanted to re-create what theit process.
Have an opened mind, you might be surprised on the what you will see or discover. Yes, there's plenty of scammers out there that used this process to get rick quick and people fell for it. that was an unfortunate event/behavior but, as there's positive there will be negative.
Old Jan 25, 2011 | 03:03 PM
  #136
69427's Avatar
69427
From: I tend to be leery of any guy who doesn't own a chainsaw or a handgun.
I'm an (automotive) design engineer, and I love technical issues and challenges, but this thread is painful. I'm not trying to be a rude SOB, but can the hydrogen enthusiast PLEASE do a spellcheck or a proofread of his posts? It's so stinking annoying reading all the spelling and grammar errors that I am losing all confidence in the author's technical expertise and any interest in the topic.
(Cliff note: If you're going to write like a sixth grader, don't expect people to take you seriously.)
Old Jan 25, 2011 | 06:44 PM
  #137
bryanpl123's Avatar
bryanpl123
Good to know... there is the answer
To Hydrogen generaters ?
Old Jan 25, 2011 | 08:38 PM
  #138
zwede's Avatar
zwede
I'm alternating between laughing and crying. We really do need to start teaching some basic science in school.
Old Jan 25, 2011 | 09:26 PM
  #139
69427's Avatar
69427
I agree, along with spelling and sentence structure.
Old Jan 25, 2011 | 09:33 PM
  #140
Bowerss2's Avatar
Bowerss2
