Top End Install Time
Old Aug 27, 2009 | 10:54 PM
redman76's Avatar
redman76
St. Jude Donor '09
Originally Posted by RunningMan373
and i doubt you want a loose thread chaser rattling around in the block.
Thanks . . .
Old Aug 27, 2009 | 11:13 PM
billla's Avatar
billla
St. Jude Donor '14
Originally Posted by redman76
Where is the best place to get thread chasers?
This set typically isn't in stock at the stores, but this is what I have and it's outstanding.
http://www.sears.com/shc/s/p_10153_1...hread+restorer
Old Aug 28, 2009 | 08:04 AM
L88Plus's Avatar
L88Plus
Make absolutely sure you clean around the top ring land. Grit and crap get trapped in there when you're working on an opened engine. If this stuff stays put, it'll score/scuff your cylinder walls, maybe worse. I'm not a big advocate of using compressed air when there's an open engine close, but that's just all that will get the stuff out of that area. IT WILL NOT WORK LOOSE AND GET BLOWN OUT OF THE ENGINE ON IT'S OWN!!!
Old Aug 28, 2009 | 10:26 AM
cv67's Avatar
cv67
St. Jude Donor '05
You will have a difference most times from the reading on say, #1 and #7 unless the block has recieved more work, dont sweat it.
Old Sep 3, 2009 | 11:13 PM
redman76's Avatar
redman76
St. Jude Donor '09
OK, got the block deck cleaned and measured the depth of the pistion at TDC. I'm at .040-.050 range on all the cylinders. So I think that means that I can go with the .015 steel shim head gasket?
Just for grins I researched some of the block numbers so maybe we could figure out what I've got here. I'm not sure it has any bearing, but here is what I got:
Block - Engine Code t0713ckj CKJ 1973 350 tur hydro trans. L65 - 4 A B F/Bel Air/Kingswd Tonawanda July 13
Block - Partial VIN 13b635904
Block - Casting # 3970010 k 12
Old Sep 8, 2009 | 07:44 PM
redman76's Avatar
redman76
St. Jude Donor '09
I'm ready to order parts. Anyone have a comment on the depth of the pistons in the hole at TDC? I can go with the .015 head gaskets? Correct? Also, anyone familiar with the L65 engine from GM and is that look like what I have?
Old Sep 8, 2009 | 11:47 PM
Little Mouse's Avatar
Little Mouse
I don't have anything that would tell what the casting numbers are for.
you should be somewhere more like .025 to .032 piston depth.
your going to need a pan gasket make sure you get the right one one of them uses a thicker front seal.
Old Sep 9, 2009 | 03:25 AM
RunningMan373's Avatar
RunningMan373
Your pistons are too far in the hole, or you didn't measure them right. I'll defer to more (greatly) experienced members to reason and comment as to possibly why. This might be a reason for less then good performance before. I would look at this before you start the rebuild, and look at possible solutions/outcomes before you do the rebuild.
Old Sep 9, 2009 | 05:49 AM
73StreetRace's Avatar
73StreetRace
A powerful vacuum cleaner can help, especially when you're working in the pistons area...
It will prevent most of the crap to fall in
Old Sep 9, 2009 | 04:22 PM
Little Mouse
redman76
something is wrong with your measurement but if they were down
040 to .050 then it looks like you have .039/.041 gaskets you would be no where even close to your 165/175 compression.
Old Sep 9, 2009 | 05:43 PM
redman76's Avatar
redman76
St. Jude Donor '09
Originally Posted by Little Mouse
redman76
I don't know how much it matters, but I forgot to open carb when I measured the compression. I warmed the engine up and pulled all the plugs then measured.
I don't know how I could mess up the piston depth measurement though. I set the dial at zero on the deck and then moved over the piston to get the .040-.050 measurements. I even set dial to zero on the piston and measured to deck and got same numbers. I slid dial across piston on top of pin to verify from side-to-side. I cleaned the deck to metalic finish first and set bridge at angle as you suggested before I measured anything. I used dial to find TDC before I measured. I agree it does not make sense.
Anything else I can try? I'll look at it again tonight and see if I'm missing something. I could maybe shoot a quick video to show you what I'm doing and the numbers on the gauge.
If the compression numbers are wrong, at least we can assume that the cylinders have approximately same compression, so no weak cylinders (or they are all equally bad)?
Old Sep 10, 2009 | 12:34 AM
Little Mouse
Sounds like the block has not been cut someone most likely just
used the .041 gasket.
Old Sep 10, 2009 | 01:20 PM
  #33
69vettester's Avatar
69vettester
Ill say No, The .015 gasket is For bonified Flat decks and New Heads. Use a thicker gasket just to be safe, youll lose a hair with the CR is all
Old Sep 10, 2009 | 03:40 PM
  #34
Little Mouse
If the deck or head is not strait enough you will blow head gaskets
won't matter how thick or thin the gasket is.
.041 gasket is 9.1 cc volume the .015 3.2 cc volume your roughly adding 6cc of volume to the cylinder its like going from a 64cc head swithcing over to a 70 cc head.
.041 gaskets are in full gasket sets for a reason it saves everyones behind someone that has an engine that has been cut .010 they don't know it has been done they use the .015 gasket they have piston to head damage someone that zeros there deck the .041 works someone with a standard deck the .041 still works with a loss in compression.
A two stroke general motors diesel will be under around 25 pounds of boost or more has no head gasket you check the depth on the liners if one is to low for spec you put a shim under the liner raise it up.
Old Sep 15, 2009 | 11:31 PM
  #35
redman76's Avatar
redman76
St. Jude Donor '09
Here is where I'm at . . . radiators and support pulled, oil pan dropped and cam removed. I'm working on ordering parts right now. I want to clean everything up best I can and paint as much as possible.
Old Sep 15, 2009 | 11:36 PM
  #36
RunningMan373
So what heads and cam did you choose? And if your sure about you piston to deck measurments, what compression ratio will you have with them (the heads)?
The new compression ratio is going to be key to the power your going to make. ?
Old Sep 16, 2009 | 12:46 AM
  #37
gingerbreadman1977's Avatar
gingerbreadman1977
you have come so far. i would go the extra distance , get a chain and crane and lift the block out. build your new motor on a stand. so much easier then when u can stand in your engine compartment and really tidy up everyhting so much easier.
To Top End Install Time
Old Sep 16, 2009 | 10:37 AM
  #38
redman76's Avatar
redman76
St. Jude Donor '09
I'm going with the Brodix IK200 and Lunati 60102LK cam kit. Also using .015 head gasket to bump the comp up a little.
Funny you mention that. Last night while I was taking photos, I thought to myself that I only have a few more bolts to go and I could just pull the motor. I don't think I'm going to do it this go around, but it's tempting. I was planning to do when I beef-up/replace the bottom end in a couple of years.
Old Sep 16, 2009 | 01:37 PM
  #39
larrywalk's Avatar
larrywalk
Veteran: Marine Corps
Comments:
1. If your piston top is .050 down in the cylinder at TDC, most likely it is with non-standard parts and/or the rods have been rebuilt too many times which shortens them and lowers the piston.
2. With a deck height of .040 to .050, if you don't pull and rebuild the short block, you need to use a thin gasket, not a thick composite (.041) gasket. With a .015 gasket, your quench will be a bit better, but still too wide at .065 - it should be .035 to .045.
3. Recommendation - Pull the engine, deck to 9.002, bore & hone for the next oversize (.030?), get new rods, pistons, etc. If you do this the piston should be at .002 in the hole. Then, using a composite gasket of .041, the quench height is .043 and you will have better knock resistance than with a quench height of .065.
Old Sep 16, 2009 | 06:08 PM
  #40
69vettester
If your Pistons were .020"-025" in the Hole, youd Have a near Ideal Quench of ~.040" with the .015" gasket. Then Youd have the makings of a Potentially great Build.
But you Dont.
So I agree with those saying "Your not commited yet", pull the long Block , Find out why your Pistons depth is .050, Thats not a good Number for High performance!!.
If you dont have your Numbers in range for what you want ,the Build will be too unpredictable. If the matchup of parts isnt reasonable You could well end up with a Dog motor, Money Not well spent. Dont want to rain on your parade ..Just My 2cents worth.
Question, why the 200cc runners? If your engine ends with less than 9.8 - 10.1 :1 CR the Bodix's wont move that volume of air anyway , Recipe for a slug. What do you expect your CR to be, If I missed something here, I apologize.
