Top End Install Time
Old Oct 2, 2009 | 11:09 PM
  #61
RunningMan373's Avatar
RunningMan373
With his pistons so far in the hole, could some one run a compression calc to see what his options are, as far as final compression, with the different head gaskets? It's needed info, at this point i think. 50 mills in the hole, flat tops with dual valve reliefs.
According to this site: http://www.csgnetwork.com/compcalc.html#
every 25 mills in the hole, cost you 1/2 point in compression ratio, every 50- 1 point, aprx. With 10cc for the dishes, 4.10 in head gasket bore dia, 0.015 compressed thickness, 64 cc head chambers, 4x3.5 bore/stroke, and 50 mills in the hole, it gives 9.233:1. Perfect.
Old Oct 2, 2009 | 11:19 PM
  #62
forvicjr's Avatar
forvicjr
The only way i can think of finding true CR is to bring the piston to TDC and run a light coat of vasaline around the gap between the piston and bore and CC the top of the piston,CC the head pick the gasket he will use (the cc spec will be on the package of a good gasket. do the math and wala......vic
Old Oct 3, 2009 | 04:39 PM
  #63
dp9's Avatar
dp9
The pistons being .05 in the hole is more about his squish than this CR. I know its really about both, but if he's just doing the top end right now he can change his CR (mill heads, felpro 1094), he cant change his piston depth. Then again, if it was running ok before redoing the top end, it should run better afterwards, it just wont be optimal. sorry, just kinda talkin to myself out loud here. Just keep the piston depth in mind when you go to rebuild the bottom end, redman.
Old Oct 3, 2009 | 07:19 PM
  #64
Little Mouse's Avatar
Little Mouse
Redman76, is showing 165 to 175 compression with 76cc factory heads
an obvious by looking at the picture .039 or .041 gasket with a volume
of 9.1cc, he is now going to switch to a 64cc chamber heads with
an .015 gasket with a volume of 3.2 cc. He will end up with plenty of compression for a 219 .050 hydraulic cam.
Now he has said hopefully in a yrs time he wants to build a 383 short block. Can you give me the reasoning behind tearing a short block all apart doing all this machining to gain a tad more compression in an engine he does not even want to keep. he has no oil control problems
compreesion shows good the engine in general looks to be in good shape.
Old Oct 3, 2009 | 11:51 PM
  #65
redman76's Avatar
redman76
St. Jude Donor '09
You summed it up pretty good. The bottom end seems to be okay for now and I'm not shooting for optimal (yet) and my expectation is that it will be better than it was but not as good as it can get with the right bottom end. When I do the bottom end, I will replace entire rotating assembly and maybe block.
I was reading a thread where you were asking about gasket matching intake ports. How did that work out for you?
Old Oct 4, 2009 | 12:00 AM
  #66
redman76's Avatar
redman76
St. Jude Donor '09
How critical are the head alignment dowels? When I pulled my old heads off, I was missing one. I tried to remove the other one when cleaning the block surface. I was having some problems getting out and stopped before I destroyed it. It has some marks on it now. Can I just file/sand to get rough edges off, or do I need to replace. I have already bought some Felpro replacement dowels to at least replace the missing one, but was curious about the other. If I need to remove . . . any tricks????
Old Oct 4, 2009 | 12:33 AM
  #67
Little Mouse
I'm guessing you just marred it up some with vice grips don't worry about it, but do put the other dowel in your missing, wrap some sand paper around it or brush it with a file if need be work on it awhile clean it up. Keep your new dowel pins for the final 383 build.
Old Oct 4, 2009 | 12:38 AM
  #68
redman76's Avatar
redman76
St. Jude Donor '09
Thanks LM!!!
Old Oct 4, 2009 | 02:29 AM
  #69
RunningMan373
9.2:1 showed over 300 hp on a DD. Now, the stated stock C/R for a L48 with dishes is 8.5:1. Some engine builders say it's a false number, it's actually closer to 8.2:1. if the second number is correct, my set up is 9.2:1, which would make it dead on what Redman is building, with like parts. I would suspect like numbers,, ie: 320hp/400T. It will be a worthwhile build- as is, which i think is important. if it would have showed 8.0:1 or some such low number, pulling the block now, and building it probably would have been a better course. Your gonna be very happy with this build, might not see the need to upgrade.
as a side note, i just installed full length headers on the 'Vette. The difference is great. Be sure to install full length headers on your build, Redman, if you don't already have them. i was hitting a wall at around 4k RPMs, engine really grumpy with all that back pressure. With headers, the engine sings up to the 5k rev limit i set on the MSD module, exhaust tone much smother and quieter, believe it or not. I got these cheapies, but hey, for 259 the fit perfect, and are ceramic coated
http://www.summitracing.com/parts/BIG-31106FLT/
Old Oct 4, 2009 | 08:49 AM
  #70
dp9's Avatar
dp9
What I got out of that thread was that if my intake manifold isnt absolutely perfectly shaped, i might as well sell the entire motor for scrap because its not worth building. not exactly helpful since I dont have $700 to lay down for a wilson cnc ported manifold. I reached a conclusion on my own, tho. All the negative effect of having a head port that is larger than the manifold port are going to be there whether the manifold is matched to the head or not. The size difference, regardless of the transition, will cause fuel to condense into droplets (to a certain extent), the air to slow down, etc. If the manifold isnt matched tho, there is added turbulence which only makes a not-optimal situation worse. So you might as well make the transition as smooth as possible. So I port matched my RPM Airgap, and I'm going to port match my Vic Jr. I havent had either of them on the motor yet, and they havent been on the motor previously, so I cant really give before and after scenarios (which would be a GREAT thread if someone made a couple trips to a dyno). Those are just my thoughts tho.
Old Oct 4, 2009 | 11:20 AM
  #71
redman76's Avatar
redman76
St. Jude Donor '09
Thanks, I've got the Hooker side mount setup with STS baffles.
What I got out of that thread was that if my intake manifold isnt absolutely perfectly shaped, i might as well sell the entire motor for scrap because its not worth building . . . If the manifold isnt matched tho, there is added turbulence which only makes a not-optimal situation worse.
Sounds like you did a good job of reading between the varying opinions. I get so confused sorting through some of this stuff . . .
Old Oct 7, 2009 | 11:46 PM
  #72
Kustom8's Avatar
Kustom8
Lane.....glad that you got the parts so quickly,and you are happy w/them.If you wanna go the new header route....you know where I am.
Thank you for your purchase,and looking forward to seeing your build progress.
Kevin
Old Oct 12, 2009 | 11:53 AM
  #73
redman76's Avatar
redman76
St. Jude Donor '09
Just a quick update . . . life has caught up to me (working on son's truck, water leak in house - repairing damage, hurt my back) and I have not been able to do as much as I hope, but here is where I'm at:
- Radiators painted and have all necessary parts to assemble radiator support.
- Block is prepped and ready to go. I replaced one missing head alignment dowel, painted some of the more visable areas of the block, and have chased all the threads in block.
I'll keep tinkering with cleaning/painting and start the assembly process soon.
Old Oct 12, 2009 | 03:55 PM
  #74
RunningMan373
The assembly actually goes pretty quickly. If i remember correctly, it only took around 2 days. Be sure to align the guide plates on the heads for the push rods carefully. C.
Old Oct 12, 2009 | 06:51 PM
  #75
dp9's Avatar
dp9
cool. take pictures.
Old Nov 11, 2009 | 11:47 AM
  #76
redman76's Avatar
redman76
St. Jude Donor '09
I have the radiator assembly painted and ready to drop back in. Also finished gasket matching intake to heads. I'm doing a fiberglass repair on the passenger fender well and then will be ready to shoot the engine bay and front crossmember with paint. Here are some pics of the radiator assembly:
Old Nov 12, 2009 | 06:35 PM
  #77
dp9's Avatar
dp9
cool. how'd the port matching work out for ya?
To Top End Install Time
Old Nov 15, 2009 | 11:41 PM
  #78
redman76's Avatar
redman76
St. Jude Donor '09
Port matching went pretty good I thought. I bought a cutting bit for my die grinder and opened it up to the gasket edge; only went 1" deep; then sanded smooth. I don't know that I'll ever be able to tell the difference between matched or not, but I wanted to give it a try.
Dang it, barely work on the car this weekend. Seems like the closer I get to assembly, the more I see to do. The "while-I'm-at-it " will pay off once I get running again.
Old Nov 30, 2009 | 03:42 AM
  #79
RunningMan373
So, what's the hold up? Engine parts got frozen in ice, and have to wait for spring or something?
Old Jan 27, 2010 | 12:13 AM
  #80
redman76's Avatar
redman76
St. Jude Donor '09
What????? It's only been two (more) months.
I'm really getting close. Had a buddy help me get radiator and support in tonight. Heads are on, valvetrain adjusted, everything lubed and oiled and most cables, hoses, etc hooked up. Got some final work to do and then fire up. Probably next nice day I will be ready to break cam in. I'll post some progress pics tomorrow!!!
