stop advance bushing
Old Mar 30, 2010 | 01:56 PM
AvRog's Avatar
AvRog
Default stop advance bushing
Anyone know how to install a stop advance bushing on a 69 distributer???
Old Mar 30, 2010 | 02:18 PM
blueray72's Avatar
blueray72
Sorry I can't help but I'm interested to know about this bushing. Why do you want to shut down the advance?
Old Mar 30, 2010 | 03:23 PM
midyearvette's Avatar
midyearvette
the bushing does not stop the advance, it limits the advance and installs on a peg that is under and through the weight assembly....
Old Mar 30, 2010 | 04:38 PM
MelWff's Avatar
MelWff
you have to pull the distributer from the car, remove the gear and install the bushing. If you need more details, let me know.
Old Mar 30, 2010 | 04:47 PM
7T1vette's Avatar
7T1vette
The "stop" bushing is just pressed over the stop-pin on the underside of the advance plate. You do have to drive-out the pin in the drive gear, then remove the gear & shim to lift the plate/shaft assembly out. Then use pliers [whatever] to wiggle the stop off the pin. Replace it with the new stop and reassemble it. If the stop is not tight on the pin, you can use a bit of Loctite to hold it or pinch/crimp it on.
[Note that the gear is an uneven number of teeth, so it is important to put an index mark on the gear and the shaft to assemble it the same as it was.
Old Mar 30, 2010 | 05:43 PM
AvRog's Avatar
AvRog
The current/previous stop seems to have all but disappeared, I can get to the pin without pulling the inner shaft but it is too hard to press the stop over the pin. should this be very difficult or have I got the wrong part that came with the Petronix conversion kit?
Old Mar 30, 2010 | 08:37 PM
7T1vette's Avatar
7T1vette
Well, it is a 'press fit'. If it weren't, vibration would shake it off the pin. You will need to 'tap' or press it on. Start easy and work up; you don't want to use any more force than necessary. And support the other side of the plate so that you don't bend anything.
Old Mar 30, 2010 | 09:08 PM
lars's Avatar
lars
Good job spotting the missing bushing - most people never know it's gone. A missing bushing will cause an advance curve that is waaay too long, producing too much total timing (along with possible detonation, power loss, and engine damage) or not enough initial timing if total is set.
You need to completely disassemble the distributor and pull the mainshaft out. Get Mr. Gasket part number 928G - it has a brass advance stop bushing that is very good. Lay the bushing on its side and give it a light smack with a hammer to make it oval - this will make it fit extremely tight onto your stop pin, which is undersized due to years of light corrosion. If you do not do this, the stop bushing will fall off at high rpm and short out your points. Don't ask me how I know this.
Use a hammer to pound the de-formed stop bushing onto the shaft pin by holding the shaft upside-down on an anvil. You know you have it tight enough if brass shavings come off the bushing when you smack it on.
Put the distributor back together. making sure the "dimple" in the distributor gear is pointing the same direction as the firing tab on the rotor.
Charley (7T1vette) has good and technically accurate comments above.
Lars
...and just my opinion, but throw that PerTronix in the trash and put a good set of points in your unit...
Old Mar 31, 2010 | 08:02 AM
AvRog's Avatar
AvRog
Lars
I'm embarrassed to say I've been complaining for a year how the car has stunning low end grunt and shuts off by 3800. Finally dawned on me that the more I backed off the timing, the higher it would rev while giving up the low end. Hope I haven't caused any damage.
So I take it I remove the inner shaft so I can properly press on the bushing. In diagrams I see a retaining clip, is this not required?
Lars, as per your e-mail I will do a complete restore of the unit back to points after I iron out this issue. I tend to compound my screw ups attempting too many changes at a time. I went to petronix as I have no previous experience with points. I'll keep the petronix as an on-board hot spare.
Thanks Guys
Later, Rog.
Old Mar 31, 2010 | 11:07 AM
lars's Avatar
lars
The retaining clip was used by the factory to keep the stock rubber sleeve on the pin - the rubber tended to "relax" over time and fall off (as yours has). The brass bushing, once given the "calibrated smack," will not fall off, so the clip is not needed.
Lars
Old Apr 1, 2010 | 07:05 AM
AvRog's Avatar
AvRog
Thanks Lars
Old Feb 5, 2023 | 03:37 PM
Masfel74's Avatar
Masfel74
Lars
Hello to everybody, I found this old post. I'm working on my '69 L36 Corvette's distributor. It seems ok but it doesn't give more than 15 degrees in mechanical advance (it's really the maximum, I also tried with very soft springs). I read that it should be 26 degrees. If I don't pass the 36 deegres in total advance can I remove the stop advance bushing for have some more degree or it's better to have something around the pin?
Thanks a lot!
Filippo
Old Feb 5, 2023 | 04:21 PM
Peterbuilt's Avatar
Peterbuilt
Default Hi and Welcome.
[QUOTE=Masfel74;1606237097]Hello to everybody, I found this old post. I'm working on my '69 L36 Corvette's distributor. It seems ok but it doesn't give more than 15 degrees in mechanical advance (it's really the maximum, I also tried with very soft springs). I read that it should be 26 degrees. If I don't pass the 36 deegres in total advance can I remove the stop advance bushing for have some more degree or it's better to have something around the pin?
Next time start a new post.
Old Feb 5, 2023 | 04:32 PM
Peterbuilt's Avatar
Peterbuilt
https://www.corvetteforum.com/forums...long-post.html
To stop advance bushing
