Not happy with 79 windshield replacement
Old Sep 1, 2010 | 03:35 PM
whaler97's Avatar
whaler97
Default Not happy with 79 windshield replacement
I just had my original windshield replaced by the insurance company due to a large rock chip. The original had a nice tight fit against the trim on both sides and top. The new one doesn't. The driver's side is tight at the bottom, and gets a gap as it goes toward the top. The top trim can be pushed down about 1/8" before it touches the glass. The passenger side is tight to the trim at the bottom, but going up it starts to have about a 1/4" gap to the glass. I had the glass installer back out and he just wanted to fill the gaps with more black glue. What should I do? Can it be that the non- GM replacement is not sized right, or it was pushed down too tight into the glue? It had some gasket tape on the ooriginal. I told him to stop and talk to his boss to see what could be done. He said he could take it out and try resetting it, but couldn't guarantee it would be any better. He doesn't think it was a tight fit on the old glass, but I know it was because I had a tough time masking under the trim to paint it. Any help would be appreciated. Tom
Old Sep 1, 2010 | 03:46 PM
zwede's Avatar
zwede
He used the wrong stuff to mount it. Our cars use a ribbon seal. I bet he just used polyurethane from a tube. The ribbon seal is much thicker and will set the glass at the proper height from the frame. He should use 3/8 ribbon seal:
Old Sep 1, 2010 | 04:24 PM
Alan 71's Avatar
Alan 71
Hi Tom,
Besides the method used to install/seal the windshield, many replacement windshields are thinner glass than the originals were and thus can cause problems with the fit of the trim.
So your misfit could be caused by a combination of things.
Regards,
Alan
Old Sep 1, 2010 | 05:56 PM
7T1vette's Avatar
7T1vette
You really should have requested that the shop use OEM or equivalent glass and parts before they did the work. You've probably already signed-off on the repair. I doubt the insurance company will do anything about it, even though it is not right.
Old Sep 1, 2010 | 11:10 PM
myk7's Avatar
myk7
The side pieces can be bent to fit perfectly.. you will probably need to remove them to bend them though. They were probably bent when removing them. I imagine the top piece tangs can be bent too.
Old Sep 2, 2010 | 08:20 AM
zwede's Avatar
zwede
No, it will never look right if the glass is set to low. The only way to fix it is to remove the glass and reinstall further away from the frame.
Old Sep 2, 2010 | 10:02 AM
Streamline's Avatar
Streamline
On my daily driver (not a vette) I had a similar problem. Told the glass & insurance company that the windshield leaked when it rained. Glass company replaced the windshield with a new one and did it right. Wouldn't hurt to try.
Old Sep 2, 2010 | 10:09 AM
whaler97's Avatar
whaler97
The owner of the glass company called and said he would do whatever I wanted. He would not charge the insurance company if I wanted to get it done somewhere else. He doesn't want to get bad publicity and lose future referals. I think I will take it to a guy that restores cars near by and see if he can take it out and do it right. The other option is the local Chevrolet dealer does their own glass work and might do it. Thanks for all the ideas, kind of worry about bending the trim. Is the 3/8 ribbon sealer the best route to take? I agree with setting the glass on rubber spacers to dry run the fit under the trim before using any adhesive. I'm still a little concerned.
Old Sep 2, 2010 | 10:24 AM
noonie's Avatar
noonie
The original glass is around .270" in thickness, some of the cheaper replacements are much thinner.
Originally they were installed with the ribbon sealer as were almost all other cars of that era.
With newer bodies the windshield has become an integral part of the structure of the body and a little better adhesion was required. It also comes into play with the operation of an airbag and windshield blowout during a crash.
If they are willing, I would use the ribbon sealer, some companies won't use it for liability concerns.
If they insist on using it, in order to get the right height without making a total mess, is to lay a bead of urethane on , let it set up for a day and then urethane the glass in.
Old Sep 2, 2010 | 11:39 AM
7T1vette's Avatar
7T1vette
The company that installed it is willing to 'make it right'. Since you already have the "skids greased" with them, call back and ask if they can do the job correctly. If they don't feel competent in doing it, find another source. Do you know for sure that the glass they used is equivalent to original [of not]?
Old Sep 2, 2010 | 12:11 PM
whaler97's Avatar
whaler97
I can't be sure about the thickness of the glass, but I did see a label "Made in Mexico" on the windshield when it was installed. The name on the glass is Pilkington DS8193. These installers only come out in a truck, so I can't take it into a shop where more than one person can install and get it right with them.
Old Sep 2, 2010 | 03:51 PM
Alan 71's Avatar
Alan 71
Hi W,
Here's a picture of the windshield in my 71.
You can see how the glass is held away from the windshield frame by the damming strip which controls and hides the sealer. You can also see that this method allows the bead on the edge of the ss trim to be tight against the glass.
This windshild is from Auto City Classics. Not cheap, not easy, not quick.
Regards,
Alan
Old Sep 2, 2010 | 05:11 PM
BBCorv70's Avatar
BBCorv70
I recently did some research on windshield manufacturers. I'm pretty sure Pilkington is a British outfit who bought LOF glass in the 80's. Claim to have the original patterns.
Don't know if your problems come from the glass or poor installation.
The local shop I deal with sent me to another source for glass. Said they have had trouble with some windshields not fitting well, size issues. TBD how my replacement turns out. Hope to find out soon.
Old Sep 2, 2010 | 05:32 PM
whaler97's Avatar
whaler97
Local Corvette Restoration shop gave me the name of the glass intaller they use, so I will call him next week after the holiday weekend and see what he can do for me. I'll keep you all posted. Thanks for all the info.
Old Sep 2, 2010 | 10:44 PM
vettes4evr's Avatar
vettes4evr
Just yesterday I had glass replaced in a company vehicle by Safelite. I asked the guy, who has many years of experience, about the thickness of replacement windshields. I'm interested in replacing the original one in my '72 with a correctly date coded one. He said that they get them from PPG in California and that they ARE thinner than the original windshields were.
I asked him about this gap under the upper moulding, which he said he sees quite often because of a lousy, inexperienced installer. He said that you have to insist on getting an installer who has done dozens of Corvettes before, and they use rubber spacer blocks under the glass to take up the gap. The bozo glass installer would just lay a ribbon of black caulk in that gap under the moulding! I kept this guys name for when I'm ready to get it done.
Old Sep 2, 2010 | 10:46 PM
Vetteran'81's Avatar
Vetteran'81
Definately keep us posted. I for one and very interested in how this turns out.
-D
Old Sep 3, 2010 | 10:09 AM
blckslvr79's Avatar
blckslvr79
Originally Posted by Alan 71
Hi W,
Regards,
Alan
That's a purty install!
To Not happy with 79 windshield replacement
Old Sep 18, 2010 | 12:04 PM
whaler97's Avatar
whaler97
Default Finally done right!!
I thought I would let you all know that I got the windshield in correctly this time. The original glass installer didn't want to attempt this again and credited the insurance company back all his charges. I went to a restoration guy I know at StraightLine Customs and he had the glass guy he uses (who has done many Vettes and fixed bothched jobs) take out the newly installed windshield and put in another with perfect fit results. It took them 4-5 hours to get everything fit and tweaked to look like original, but it was worth the wait. State Farm Insurance picked up the bill. They even sent an appraiser out to the shop to check out the reason for doing the job over. She was very understanding and knew that classic cars need different installs than modern cars. So if you need a new windshield, do your investigation first and don't let any drive up installer work on your Vette. Thanks for all the comments. Drive safe and have fun!!!
Old Sep 18, 2010 | 12:47 PM
Alan 71's Avatar
Alan 71
Hi W,
I've been wondering, so it's good to read that things turned out well for you.
So often now people who repair most things just want to do it the way they're used to and is easiest for them. In many cases that's o.k., but not always.
Regards,
Alan
Old Sep 19, 2010 | 09:45 PM
Tom Sarno's Avatar
Tom Sarno
Next time you are at a show that has C-3 all lined up side by side, stand at the side and look across the row at the windshields. You can pick out the bad repos easily.
