overheating problem in my c3
Old Sep 8, 2010 | 07:59 PM
dmrodco's Avatar
dmrodco
Originally Posted by snoopykissedlucy
Wait........did you say you DON'T have a thermostat?
It is very important and needs to be there. Only drag racers that drive 1/4 mile at a time can run without one.
Not true we run them without all the time. if you dont drive in cold weather you'll never have an issue.
Have you looked at the timing ? too much can cause overheating issues if this just cropped up you have a blockage somewhere in the system
Old Sep 8, 2010 | 08:20 PM
mar's Avatar
mar
What fan are you running?
Originally Posted by dochorsepower
Just a few quick thoughts - one guy on another forum had problems with overheating because his engine builder put the wrong head gaskets on, 400 on a 350 or vice-versa. Also I'm not a believer in the electric fans, lots of people have had trouble with them. I run a direct fan on the waterpump, Stewart waterpump and Stewart drilled thermostat (160), original type brass 4-core radiator and the temperature never gets over 180 even climbing a hill on a 95 degree day.
Old Sep 8, 2010 | 08:59 PM
over_kill's Avatar
over_kill
4th Gear
I just bought the car about 4 months ago...owner who did most of the mods passed on most receipts but not all info is there. I was under the understanding that if the head gasket was blown the car would overheat quickly...is this not true?
Old Sep 9, 2010 | 12:09 AM
Rollochrome's Avatar
Rollochrome
Old Sep 9, 2010 | 12:17 PM
7T1vette's Avatar
7T1vette
A head gasket can "blow" in many different ways, depending on what gasket junction is "lost". Overheating is not one of the primary faults of a blown head gasket...but it can happen.
You need to verify that the temp gauge in your car is showing you the "actual" temperature. It is very possible to get a replacement temp sender and have the gauge read 50* +/- (or more!). Don't go chasing a problem that isn't really a problem.
Many auto parts stores will have an IR temp gun that they can use to take a reading from your intake manifold and heads. If those readings agree with your gauge, continue to search for the problem. Otherwise, fix your [high reading] temp gauge and stop worrying.
P.S. The idea expressed above on someone installing the wrong head gaskets is a distinct possibility if you really are overheating and you can't find another reason. By the way, have you taken time to use some radiator cleaner to get the old lime deposits out of your radiator? If not, that is something you should do.
