1976 fuel guage reads 1/4 when tank is full?
Old 03-18-2011, 02:07 PM
Jay-Dog
Jay-Dog's Avatar
Default 1976 fuel guage reads 1/4 when tank is full?
Any suggestions on what is wrong with a fuel gauge that seems to work except that it only goes to about 1/4 when the tank is full? PO replaced fuel tank thinking that was the root of the problem. FYI, radio doesn't work, tach won't go above 1800 rpm. Related?
Old 03-18-2011, 02:16 PM
Easy Mike
Support Corvetteforum!
Easy Mike's Avatar
Received 1,470 Likes on 1,249 Posts
Cruise-In II Veteran
Originally Posted by Jay-Dog
...Any suggestions on what is wrong with a fuel gauge that seems to work except that it only goes to about 1/4 when the tank is full?...
Sending unit.
...radio doesn't work...
Fuse
...tach won't go above 1800 rpm...
Tach board or filter.
Old 03-18-2011, 02:19 PM
Jay-Dog
Jay-Dog's Avatar
Thank you sir.
Old 03-18-2011, 02:51 PM
Easy Mike
Easy Mike's Avatar
Thank you sir.
You're welcome. All the above are First Guesses...The usual suspects.
Have a good weekend.
Old 03-18-2011, 03:30 PM
mds3013
mds3013's Avatar
Lots of info here to help you fix some of your issues. mike...
http://willcoxcorvette.com/repairand...62514c3371ac3b
Old 03-18-2011, 04:49 PM
76stingracer
76stingracer's Avatar
I had the opposite issue. Gage read full but there was not gas in the tank. Ended up being the bladder had pulled away from the side on the tank and was blocking the sending unit in the tank. If everything checks out I would take a look at the vacuum hoses to the tank. The steel line on the drivers side had rusted out.
Old 03-21-2011, 01:03 PM
Jay-Dog
Jay-Dog's Avatar
Wow, excellent article from Willcox. I'll be taking apart the gauge cluster for other work, so I plan to test the fuel gauge resister at that time.
Old 03-21-2011, 11:52 PM
0Willcox Corvette
Former Vendor
Willcox Corvette's Avatar
Received 1,813 Likes on 1,458 Posts
St. Jude Donor '08-'09-'10-'11-'12-'13-'14-'15
I have to go with Resistor on this just from the title. If the resistor is blown, the highest reading the gauge will make is 1/4 tank.... Post back with what you find.
To 1976 fuel guage reads 1/4 when tank is full?
Quick Reply: 1976 fuel guage reads 1/4 when tank is full?
