81 help
Old May 4, 2011 | 11:55 AM
colin75's Avatar
colin75
Default 81 help
does an 81 have any ignition safety switches? i cant get power for selonoid when key is turned to start. thanks
Old May 4, 2011 | 01:26 PM
wajulia's Avatar
wajulia
Not near my service manual, but I remember that the alarm system can disable the ignition if that helps.
Old May 4, 2011 | 01:27 PM
Stu's81's Avatar
Stu's81
Did you check the fusable links at the starter?
Old May 4, 2011 | 11:38 PM
dburgjohn's Avatar
dburgjohn
There is a neutral safety switch on the side of the shifter for automatics. Stick cars will have a safety switch on the clutch pedal. If you have a auto, sometimes the park position will wear out. You can put it in neutral and it will start.
Good luck
Old May 6, 2011 | 03:15 PM
Easy Mike's Avatar
Easy Mike
Cruise-In II Veteran
Old May 6, 2011 | 10:46 PM
damoroso's Avatar
damoroso
Try the plug of the starter harness. It's a large clear/white plug that's usually near the rear of the passenger side valve cover. Sometimes that comes loose or gets corroded. If that connection isn't good, you won't get power to the starter.
Old May 7, 2011 | 06:52 AM
7T1vette's Avatar
7T1vette
Most likely a Neutral Start Switch problem or electrical problem with the security system. {Dead battery?}
To 81 help
