My Personal Paint Thread
Looking GOOD!
My only experience and advice is from watching the fellow who painted my car with lacquer wet sand and buff.
I was startled by how much water and soap he used while he was sanding to keep things 'floating'.
Maybe?
Regards,
Alan
As for the 800 grit; I had seen some YouTube videos where the guy was using 800 (and even 600!) to cut the orange peel down before using the fine grits; it was probably just laziness and impatience on my part more than anything else that led me to do that...no more. some of you mind-readers out there need to get into my head before I make more of these dumb mistakes!
Cheers!
We aren't gonna be able to tell that there is "good layer of clear still on the car", not from pics and not even from being there and looking at in person(at least not me anyway). yes you are totally correct about the darker colors, anything short of perfection will show a haze. That's why I warned you about doing it in sections, which you did. Just be carefull about going through....
First, RE-sanded all the way to a 3000 finish IN THE GARAGE under flourescent light and using soapy water. This took an hour and a half, starting with 1200 grit...
Polished one small spot by hand under the lights to see what kind of result that would give...encouraging.
View of the passenger-side, un-reworked panel- haze is visible in the light reflection...
And the driver's side panel after cutting-buffing-polishing. This done with a 4" wool/foam pad in an electric drill with not enough speed to generate any real heat (I didn't want to sling compound all over the garage). MUCH better, the haze is all but gone, and the orange peel that I had missed on the first attempt is all removed as well except for a couple barely noticeable little spots.
THIS is a big part of the reason that I did this thread. I'd have to go back and check to be sure, but if I'm not mistaken one guy told me about the flourescent light thing, another about the Trizact pads, another about using soapy water for sanding, and as it turned out it was the COMBINATION of all those things that FINALLY produced an acceptable result.
This really is the part of the job that is the most absolute WORK. The rest is a combination of patience, diligence, and skill, but this color sanding and buffing is just endless, grueling WORK, and unless you're willing to put in ALL of the effort necessary to get it right it just won't happen. So at this point I really do owe each one of you guys who took the time to look in and give encouragement and advice a sincere THANK YOU!! I'm beginning to feel like it's all been worthwhile...
That said, I didn't especially think the last steps were all that much work. A good D/A and then one of these
gets the job done! I only used a drill motor and some small pads for the concave area below the rear pillar.
We all want to see the finished car out in the California sun!
The shine you're achieving looks great... Keep it up...
Rogman
I do happen to have a nice Milwaukee ELECTRIC DA that's a lot quieter than my compressor. I wonder how wet-sanding with THAT would work out??
Let's just put this idea to bed before somebody gets hurt, OK?
I've been following your thread for the past 18 months or so.
You have done a great job with your car. You have truly shown all of us how much work is involved in doing this right.
Excellent work!!
Makes me wonder how long I can live with the paint job that is on my car. Hopefully a while longer.
In the span of about 20 minutes I worked my psyche through the clinical stages of denial/sand some more and see if that fixes it/nope/more denial/acceptance of painful reality that I screwed up royally/OK, moron, just what do you do to extricate yourself from this mess, eh?
After processing all of that teeth-gnashing (AND doing the SAME thing to the driver's door) I decided to stop, sand the entire driver's door, headlight door, wiper door, and wiper grille (which had been attacked by the dreaded solvent pop) with 600 grit paper and re-clear them.
I had enough clear left over to do a whole 'nother car, and some reducer, so no extra $$ expended if it worked.
After sanding everything and moving cars out of the way, I reducede a batch of clear about 25% so it would flow and piled another four coats on. No real orange peel to speak of this time, actually it flowed out like glass (methinks warmer temps+extra reducer made the diff.). BUT in the areas where I had sanded through the clear the basecoat lifted pretty noticeably...
...this was obviously terrifying at first; thought I was going to be stripping and re-painting a headlight door and driver's door, but tonight I sanded and buffed the light door and (while not absolutely perfect) there is just a barely-noticeable 'tint' or shift in color where I went into the base. The spot on the driver's door that was sanded through is actually very small, so I'm pretty confident that will polish up OK. I'm a little concerned about the rest of the car, but now that I have the wet sanding process pretty well worked out I'm a little more confident that I can get away with doing the rest of the car ONCE.
(Wiper door/ grille)
(Headlite door after polishing...not quite there yet)
...at this point, if somebody told me they got a complete-strip, base/clear paint job done on their C3 for $15k, I'd tell them they got a bargain...
