My Personal Paint Thread
The shine you're getting on that paint/clear is tremendous... Tell your son I said "Hi", and to enjoy his time home with the folks!!!
Rogman
(Left Front corner polished)
(Light Door installed, up position)
(Light Door guts)
(Light Door installed, down position)
Rogman
I've still got some more color sanding and polishing to do up front (down below) but I just had to get some of the loose parts back on the car. At this point I think the next step is to charge the battery and start it up, since all of the vacuum lines are once again hooked up, then finish the 'repair' work in the back. After that I think I'll put the new weatherstrips onto the doors and hang them, and build them up on the car.
The worst part of the whole deal is going to be the carpet install, something I've never done before, but once I'm past that it should all go pretty quickly. The whole thing is actually kind of fun now- a year ago it was definitely NOT fun- it was just endless hours of sanding and grinding and stripping and cleaning but now it's actually beginning to pay off
Please forgive the poor photo quality...I took them with my phone in somewhat poor light...
I did start the car for the first time in awhile about a week ago just to get it warmed up and see if the lights and wipers work. The lights go up (slowly) and won't go down, and the wipers don't work at all...grrrrr. I'm going to finish installing the rear valance, exhaust bezels, etc, repaint the trim on the front grilles, but before I install those I'm going to troubleshoot the lights while I still have decent access into the hole where the relays go. Once I get the lights and wipers sorted out all that will remain will be carpet installation and door assembly/ installation. Lastly, I will clean up the wheels and try to make them look reasonably presentable, then use my newly-acquired Motive power brake bleeder to try and get the !@&&*!$$ brakes working properly before I head down the road with it. There really IS light at the end of the proverbial tunnel...
It looks like you're making very nice progress getting it back together!.
To do a nice detailed job and NOT screw anything up while you're working does take a good bit of time.
Almost there.... don't rush the finishing.
Regards,
Alan
All kidding aside (your car IS probably the most nicely, accurately-restored C3 I've seen on this forum though- no kidding there), it just felt a little embarrassing to be going through the trials and tribulations that I have endured with this project, expending as much or more work as those guys do but getting far lesser results because I just don't have the resources that those guys have. It's not that I don't know what perfection looks like, it's that it takes soooo much effort to get there when you don't have the right equipment or experience that it's almost impossible to really produce what you set out to produce.
Still, it will be infinitely better than what I had two years ago, and I might even be able to put it in a car show or two without having to make excuses for the paint!
