LS3 into my 72
Half the springs done on this head
All springs done now. Waiting on the trunion upgrade which should be here tomorrow so I can bolt the rockers back on.
Any plans for the appearance, Like paint or polishing, nows the time while you have it apart.
Riggs
No real polishing, probably a set of different valve covers and coil relocation. The Ac compressor is polished. Not a chrome guy at all. I like things clean and organized.
The design of the LS is so much better to work on compared to the Gen 1 motors and a lot stronger as well. I have a TON of money going into this LS swap, but I'm glad I took the plunge because I don't think I would be as happy with the plans I had for the old small block.
Riggs
Here is all the bearings and trunions after pressing them out.
Comparison of the stockers vs the new bearing
New vs old trunion. Quite a bit larger
Pressing it all togther. You press in one side. Drop the trunion in and them put the other bearing on. The washers they give you and are perfect spacers for pressing it together. After they are done a snap ring goes on either side so they can't fall out.
It won't add any HP or bling but it gives me a little piece of mind at 6500 rpm.
I picked up a new LS3 build from TurnKey and when running over the details with them I was given the impression that the stock main line didn't offer enough flow for the engine...
I'm currently looking at routing options for full braided but wouldn't be opposed to the stock steel if possible.
On my old injection setup I ran a 3/8 fuel line at 42 psi and it was making around 500+ HP with no drop in fuel pressure. Unless you are boosting or running nitrious you will be fine with 3/8 line. The Walbro pump will also feed about 600HP.
Hope this helps. I will have complete fuel line setup soon as I get the fuel line in. Pictures will follow.
Do you happen to know what year the vette motors switched over to returnless?
I'm considering going EFI, not sure if I wanna go with a drop-in kit for the 350, or go with an LS. Being that my car is carbed, it'd actually be easier in the long haul to drop an LS in. The emissions systems are much less complicated, and I'm actually learning my way around ECM tuning.
The so called drop in systems, some are pretty good. It will be cheaper if your motor is in good condition to drop on a system rather than go to the LS motor. Everything is different on the LS motor. Mine is definitly not a budget build at all but I am trying to keep costs down, don't we all. It is still costing a bundle to do it the way I want to. If you want an LS motor than have at it. Everything is doable for sure just up the credit card limit!
You are really playing with fire with the 918 spring and that cam. Straight from Comp...
Those pushrods are not up to the task of 6500+ RPM with those lift and duration numbers. At least not for long. For the $100 you're going to invest (TSP, Comp, etc.), a set of pushrods is just a basic part of the cam swap. If you held a chromoly pushrod next to a stock one, you'd understand.
FWIW, I've run the stock rockers to 8k+ RPM with zero issues for many passes, and many street miles, without the trunion mod. But I understand the overkill mindset, trust me.
I hope you don't take this the wrong way, and I'm not telling you what to do with your car or your build, I'm just giving you some insight from what I've experienced through the (more than a) handful of cam swaps I've been through with these motors, and save you some headache in the long run.
Granted I understand that says "most", it's a very sensitive are. That cam may not have a ton of duration, but with those kind of lift numbers, and the kind of RPM you want to turn, those springs are like playing russian roulette. I had them in an off-topic car using a 232/234 .595/.598 cam in an LQ4 that only spun 6200RPM, and was nervous then. Just my honest opinion, from the talking I did with Comp, and with many a set of broken 918's out there, I would seriously reconsider your valve spring choice to a good set of doubles.
http://www.compperformancegroupstore...Category_Code=
They have gone with better wire and are good up to .625 lift. This is the same spring they did the cam comparison on the LS3 motors and they ran up to a .640ish lift with no problem. They also spun the motor past the 6500 rpm threshold many times with no issues with pushrods or springs. No question the stock rockers are a good piece and probably would never give me any problem. But I did it anyway.
I have a 2009 Z06 sitting next to the 78, so I'm not horribly tempted to build the 78 up much. I would most likely put an LS1/4L60E in the 78. It has a 700R4 already, so the only real work needed is plumbing the return, the P/S stuff and doing the wiring. I'm not afraid of EFI at all.
I'm probably going to put your thread in my archives... tons of info here and great detailed photos showing off the gotchas.
