dash light bulbs
Old Oct 15, 2011 | 09:01 AM
boltnut's Avatar
boltnut
Default dash light bulbs
looks like there are one or two sizes that fit most of the gauges and and other lights behind the dash. can i get replacements at the local parts store or do i need "special' vette bulbs ? mine have hard to read part numbers on them so i was wondering if someone knew what i should ask for at advance, or pepboys, ect ?
Old Oct 15, 2011 | 09:12 AM
Ganey's Avatar
Ganey
The 1895 bulbs for it are commonly available.
Old Oct 15, 2011 | 09:19 AM
boltnut's Avatar
boltnut
is that the larger of the two ?
Old Oct 15, 2011 | 10:55 AM
Easy Mike's Avatar
Easy Mike
Cruise-In II Veteran
Owner's manual lists correct bulb sizes. Illumination lamps are usually small; tell tale lamps are usually larger. Do your homework because you do not want to go back behind the dash a second time.
Old Oct 15, 2011 | 06:59 PM
spf72's Avatar
spf72
You can get a box of the bulbs at NAPA and they are not very expensive and common to many applications - there is no Vette bulb.
Are you replacing just a few or all of them? If you are pulling the dash to change them all you may want to consider going to a LED bulb. They are a lot more expensive but they also provide a lot better lighting. I used them in one application and am very pleased with the result. I never really liked how dim my dash looked with the stock bulbs even after cleaning it all up.
Of course that may just be that my eyes aren't what they were 30 years ago.
Old Oct 16, 2011 | 02:45 AM
mauiwilly's Avatar
mauiwilly
There are LED replacements for dash bulbs ?? Please tell us more....
Old Oct 18, 2011 | 10:40 AM
spf72's Avatar
spf72
Sorry it took a few days, not on as much as I would like.
Yes you can use LED and they can be much brighter. Need to make sure you buy the right ones with multiple diodes. Issues are that they can be expensive and they can't be dimmed with the standard dimmer switch. You also need to make sure your lights being dim isn't due to a bad ground or connection as LED's won't fix those issues and probably won't work at all.
Many threads on them so I would recommend doing a search. If you do an advanced search for LED in the C3 section there are a number of good articles.
Old Oct 18, 2011 | 10:47 AM
MotorHead's Avatar
MotorHead
From: Who says "Nothing is impossible" ? I've been doing nothing for years.
My whole dash has blue LED's and it looks really cool. You can't dim them and I was worried they would be too bright but they are just right. You don't need to order all 14 or so as some are idiot lights, I only ordered 8
Old Oct 18, 2011 | 11:32 PM
7T1vette's Avatar
7T1vette
For those who want to go to all the trouble and expense of installing LED's, "go for it"!
For those 'others', the standard dash bulb (when properly installed, with good wiring and grounds, and a functioning light switch) should last about 10 years or so. About $15-20 worth of bulbs and a bit of work will get things back to 'normal'.
Both are viable options; but the LED's won't dim (unless you buy more "stuff").
Old Nov 27, 2011 | 07:45 PM
RIO68's Avatar
RIO68
What "more stuff" are you referring to??
Also, bulbs with more elelments what is the ideal number of elements on a LED bulb? The short one has like 5 elements and looks like it will work as to height of the bulb but I have no idea what might work best????
Old Nov 27, 2011 | 09:07 PM
damoroso's Avatar
damoroso
BTW, the bulbs for the dash come in different wattage ratings, though they all have the same part number. If you look for the higher wattage ones, and the rest of your system is in good shape like 7T1vette says, you should be fine.
Old Nov 27, 2011 | 09:11 PM
daanbc's Avatar
daanbc
St. Jude Donor '12
I believe I read somewhere that when you replace the dash bulbs with Clear led's, the dash actually reads blue at night. That the old bulbs is what causes the dimish Green/yellowish look.
To dash light bulbs
