Big engines
Old Jan 8, 2012 | 09:22 AM
  #41
Nobody.'s Avatar
Nobody.
Originally Posted by 427Hotrod
Nobody......did you do any porting of the Holley tunnel ram? Any pics inside of it? We're doign a bunch of dyno testing right now on a 572 with a few single planes and a couple of tunnel rams...but I hadn't looked at Holley one.
What sort of RPM? Any dyno numbers with RPM?
Thanks,
JIM
Jim, the Holley is a great intake. I did all the head porting myself and the intake as well. It matched up nicely to the 370cc runners. Never dynoed it but at the track it ran from 5.43 to 5.55 depending on the time of year (1/8 mile) at 2850#. Never ran the 1/4 with it. No radical porting. Just made sure of a good gasket match to the heads and continued that up the runners about 2" or so. RPMS... shifted at 7200 and hit the stripe at 7100. Did plenty of 7800 to 8000 rpm burnouts and it never laid over. I had a 180hp fogger on it for one summer to run some local drudge events but due to not changing converters, it was just too hard on the motor IMO. It would run 5.25 - 5.30 but it put an extra 1k rpm on it. Crossed at 8000 but again, never quit pulling.
Old Jan 8, 2012 | 10:58 AM
  #42
99 Black Bird TA's Avatar
99 Black Bird TA
Might be of interest to the OP, Dart 400 CID small block replaced previous 383 & 350 engines.
Old Jan 9, 2012 | 09:56 AM
  #43
stingr4y's Avatar
stingr4y
Those are ridiculous!
I can't stop grinning.
Old Jan 9, 2012 | 11:18 AM
  #44
chevymans 77's Avatar
chevymans 77
St. Jude Donor '05-'06,'11,'13-'14,'16,'18,'19,'24, '25
496 BBC in 77 vette:
Just installed in vette;
Current;
Small for today's standards but still a BBC.
Neal
Old Jan 11, 2012 | 12:52 PM
  #45
slayer2_2's Avatar
slayer2_2
I know a little bit of engines and taht´s the right way to build a great engine!!!!!!. Awesome work a very well built for sure man... I think this is going to be a great post at least!!!
Old Jan 11, 2012 | 01:05 PM
  #46
slayer2_2's Avatar
slayer2_2
Current;
Neal
I Like it Neal, looks killer and a great engine!!!!.
Do you built it or maybe you go to shopping and buy one built for you?. What compression have it?.
How much hps have it?. What are you using to.. run 1/4 mille or maybe a rapid cruising on it?
Thanks for your future answers...
Regards, Alex.
Old Jan 11, 2012 | 01:13 PM
  #47
slayer2_2's Avatar
slayer2_2
I love sepertine belts on engine... Good engine and for sure its a good morlaco!!!
Old Jan 11, 2012 | 01:33 PM
  #48
632C2's Avatar
632C2
This is a pic of my latest project. It looks like a stock 427 435hp but is actually 542" and makes 671.05 rwhp with the factory 1967 tri-power intake manifold, factory cast iron exhaust manifolds, a custom fabricated 3” exhaust system, all accessories connected (including clutch fan), and power steering.
Here is another shot of my blue car with the 632:
Steve
Old Jan 11, 2012 | 03:16 PM
  #49
1Sweet66's Avatar
1Sweet66
Steve
671HP with factory intake and cast iron exhaust! Now that's impressive!!
Old Jan 11, 2012 | 06:23 PM
  #50
TheSkunkWorks's Avatar
TheSkunkWorks
From: Graceland in a Not Correctly Restored Stingray
Big is a relative term. All else being equal (VE% wise), a 427 turning 7000 RPM should theoretically pump as much A/F mix as a 496 turning 6000. Just thought I'd throw that out there...
Old Jan 11, 2012 | 10:08 PM
  #51
chevymans 77
Regards, Alex.
BBC 496, Forged rotating assem., custom ported open chamber ovals, stainless valves, titanium retainers, Lanati roller rockers, Lanati solid roller .700 lift int. and exh., duration at .050 254, 112 lobe center,
10 to 1 comp, custom Ross pistons, 4.25” Eagle steel crank, Eagle H-beam rods, Holley Strip Dominator intake, Internally balanced, 4 bolt Chevy block, Hooker Side-pipes, highly tuned Holley 1000 HP carb.
I was running it in a chevy truck and decided to pull it and send it to a known racing engine shop and have the head work done along with the with the matching cam. I than brought it to a local shop and had it balanced and assembled.
I installed it in the car and cranked it up. I haven't dyno'ed it so the HP is just a guess right now. Its very close to a forum members 496 BB and his made in the area of 650 HP.
Haven't been to the track so I'm not sure on the 1/4 mile times, it pulls very strong to 7000 rpm's.
Neal
Old Jan 12, 2012 | 07:39 AM
  #52
slayer2_2's Avatar
slayer2_2
Steve
Steve awesome both engines very impressive, that's going to be a cool post!!!!!
Regards Alex.
Old Jan 12, 2012 | 08:44 AM
  #53
Tom454's Avatar
Tom454
Originally Posted by MotorHead
How bout a big 427ci small block
Sweet.
Wish they could do the small block 454 in aluminum...
http://www.worldcastings.com/product...c-engines.html
Old Jan 12, 2012 | 03:32 PM
  #54
TimAT's Avatar
TimAT
Just a little 454. Block is an XCH code, crate model LS-7 slated for the 1970 Corvette, 454/460. Never made it into production. Been massaged a bit with GM aluminum heads, ARP rod bolts, and a little more cam.
Old Jan 12, 2012 | 04:16 PM
  #55
tekvette's Avatar
tekvette
Mines only a 406 pump gas 10:5:1cr
She made 531 hp though and she's built for plenty of spray.
Old Jan 12, 2012 | 08:10 PM
  #56
ajrothm's Avatar
ajrothm
My ole rat as of tonight...(watch it in 720P)
http://www.youtube.com/watch?v=9qHiTCaiZ50
Just got finished prepping her for the strip tomorrow night....hence no ac belt and funny breathers etc etc...
Old Jan 12, 2012 | 09:32 PM
  #57
SmokedTires's Avatar
SmokedTires
Cruise-In III Veteran
St. Jude Donor '05
I will be having sweet dreams tonight My hat is off to you guys
To Big engines
Old Jan 24, 2012 | 12:01 PM
  #58
slayer2_2's Avatar
slayer2_2
Originally Posted by Tom454
Sweet.
Awesome, i had too many ideas now to do jajajjaja!!!!!!. Thank you sirs.....
Old Jan 24, 2012 | 12:02 PM
  #59
slayer2_2's Avatar
slayer2_2
Really very impresive vettes both of them are brutally insane powerfull!!!!. congrats man for your work on both vettes!!!!
Old Jan 24, 2012 | 04:18 PM
  #60
BlowAMouse's Avatar
BlowAMouse
If you Blow real hard, does it get bigger?
