Trailing Arm Hell
Old Sep 13, 2012 | 08:25 AM
  #41
MrJlr's Avatar
MrJlr
Originally Posted by Street Rat
Now everything is back together. She's cruising down the road again.
I put the trailing arm bolts back in by attaching fishing line to the bolt and pulling the bolt through. WHAT A TIP THAT WAS! Now the "hell" is long gone but the memory remains. The payoff was worth the pain.
The trailing arms were rebuilt by tracdogg2 to perfection. The car handles like a dream. I had the rear alignment set this week. Putting anti-seize on the shims helped the technician get the newly installed shims out for readjustment.
Now it's on to the front suspension. I've purchased all Moog replacement parts. Let the "hell" begin...
That's awesome.....sure is nice to have all that like new again...!!!!
Old Sep 13, 2012 | 12:13 PM
  #42
cottoneg's Avatar
cottoneg
Geeez, let see know….You may want to consider
Replacing those rubber bushings at the front of the control arm with steel
Replace all emergency brake shoes and springs with stainless steel.
Replace those rubber brake hoses with braided steel lines
Swap from regular shims to stainless steel.
New grade 8 bolts all around
Of course you want the arm to look pretty, so get all the rust off and paint it.
New bearings???
What am I forgetting before re-assembly???
Remember, they come apart real easy the second time around.
Old Sep 14, 2012 | 02:19 PM
  #43
Krystal's Avatar
Krystal
Originally Posted by MrJlr
Wow......I'm SO happy to have a California car.....mine came right out!
Way to stick to it though.....glad they're out !
Must be the rust thing that makes this miserable. My car has lived it's entire live here in the North but has never seen salted roads. I do remember it took my husband a couple of hours to get 'em out and he showed me the "rusty dust" that at one time had been my adjustment-shims........ small wonder the rear of the car was doing so much sloppy steering beyond what I was doing with the steering wheel.
In-spite of the condition of the thin metal shims and completely rotted rubber bushings ......... the arms and pocketed area where they bolted in were really in remarkably good condition after near 30 years.
Old Sep 14, 2012 | 04:27 PM
  #44
BB72's Avatar
BB72
Two important points, remove as many shims as you can and don't run the sawzall at full blast, it'll burn the blade out fast, half speed maybe. Those blades aren't cheap here. Rusty parts will kill a blade fast.
Old Sep 14, 2012 | 10:20 PM
  #45
bhk2's Avatar
bhk2
Originally Posted by corvettedave383
I thought the brake booster removal was quite easy too be honest, just have the right socket extensions, job done
dave
Old Sep 15, 2012 | 09:36 PM
  #46
garygnu's Avatar
garygnu
grease those bearing while they are out .I use a die grinder with a cut off wheel to remove the nut .
Old Sep 16, 2012 | 09:50 AM
  #47
imariver's Avatar
imariver
I guess I must be pretty fortunate. I just finished a complete, rear suspension rebuild. This also included removing the differential for overhaul too. Actually I had no chioce, seeings how I broke a side yoke. Anyway everything came out, and went back in just fine. And all this while lying on my back.
FYI & BTW....... When you put everything back together, you do know that you have to orient the rotor to the to the spindle hub........ right?
Old Sep 16, 2012 | 11:42 AM
  #48
bhk2's Avatar
bhk2
Help me here, I am not understanding how it could be unoriented... are you referring to the window to adjust the brake shoes?
Old Sep 16, 2012 | 05:55 PM
  #49
johnt365's Avatar
johnt365
Originally Posted by 69ttop
Removing the TA's is much easier if you use a elongated nut,the kind of nut that is used when you want to connect 2 lengths of threaded rod together, then screw two bolts all the way into the nut and position the assembely into the TA pocket in the frame. Then back out the bolts so they spread the walls of the pocket about a 1/16 of an inch. The TA's and all the shims can be removed quite easily reinstall TA's and shims in reverse. Remember to keep track of the shims so they or their replacment shims can be reinstalled to their original position. 3/8ths or 1/2 inch thread size should work.
Can anybody post a picture of what this jig looks like please? I can't get my head around how this works but it sounds like what I need because I just want to do an alignment not replace bushings.
Old Sep 16, 2012 | 06:09 PM
  #50
noonie's Avatar
noonie
It works just like a screw jack, the more you unthread it, the longer it gets.
Similar also to leveling legs of equipment or even a refrigerator.
Old Sep 16, 2012 | 09:06 PM
  #51
pancake's Avatar
pancake
The front end is a piece of cake. Don't sweat it!
Old Sep 17, 2012 | 08:20 PM
  #52
imariver's Avatar
imariver
Yes, There are holes in the rotors, that line up with holes in the spindle hub. When properly aligned, you can access the brake shoe adjusters.
Old Sep 18, 2012 | 02:57 PM
  #53
A88FXRS's Avatar
A88FXRS
try a torch and wet rags. works well for me and out in 10 minutes. no cussing or yelling !
Old Sep 18, 2012 | 03:29 PM
  #54
johnt365's Avatar
johnt365
I would be thankful if you could break this down a bit for me. Where do you put the torch and rags?
On a side note this reminded me of when older tv shows and movies would have someone deliver a baby at home. There was always someone there who had delivered a baby at home before and they called out to one of the other people in the room " Quick, go get me a pan of warm water and plenty of clean rags!" They NEVER showed what the water and rags were for though. I watched my wife deliver a baby from start to finish in the hospital, cut the cord, the whole deal. The nurse never asked for a pan of water and they didn't tear up any sheets for rags or anything.
Seriously, what are the rags for? I will buy a torch but need some instruction.
Old Sep 20, 2012 | 10:09 AM
  #55
mooncricket's Avatar
mooncricket
Was interested to hear the torch and wet rags method myself... anyone?
Old Sep 20, 2012 | 10:33 AM
  #56
wcsinx's Avatar
wcsinx
sonofa.... now why didn't I think of that That's a hell of an idea.
What I ended up doing was hooking a slide hammer onto the shims and banging them out. Once the shims are out, a sawzall will go through the bolt like butter. I can't imagine trying to cut through the shims.
Old Sep 20, 2012 | 10:09 PM
  #57
RIO68's Avatar
RIO68
First time every time!!
To Trailing Arm Hell
Old Sep 22, 2012 | 09:10 AM
  #58
mooncricket
care to share?
Old Sep 22, 2012 | 09:43 AM
  #59
'75's Avatar
'75
Soak some rags in water and pack them in behind the frame and around the gas lines. Use the oxy acetylene torch to quickly cut out the shims and or bolt, takes seconds, but not for the inexperienced. Oh, have a good fire extinguisher ready.
Old Sep 22, 2012 | 10:34 AM
  #60
7T3C3TTZ07's Avatar
7T3C3TTZ07
Default As I did
I elected to use the Sawzall approach (excuse to purchase my now second favorite tool) for removal and the needle nose plier method for install. I matched the shims but I took it for alignment anyway. There was a bit of difference. The alignment technician told me that the alignment changed when the bolt was tightened on the new bushing. Probably compressing the pocket to a slightly different dimension. I had a bag of shims available and I was given a huge discount for my regular business there. It was an interesting experience. I think there ought to be a C3 bragging rights bumper sticker: "I did my own Trailing Arms."
