A-arm/Frame Dimension Question
Old Sep 18, 2014 | 01:05 AM
Kim72's Avatar
Kim72
Default A-arm/Frame Dimension Question
I want to check the a-arm/shock tower frame cross dimension (a-arm to a-arm on a big block car) on my 72. I've searched the AIM, service manual, and the web for a length/number but no luck so far. Can anyone help out here? Also, where exactly do you measure too to check this?
Old Sep 18, 2014 | 07:32 AM
Mooser's Avatar
Mooser
The measurement between the shock towers is 26-3/8"
You check where the shims touch the frame right where the studs come through the frame that hold the upper control arm shafts
HIH
M
Old Sep 18, 2014 | 09:35 PM
Kim72's Avatar
Kim72
Thanks Mooser. Just what I wanted.
Can I ask where you got this dimension from? I couldn't find it anywhere.
Old Sep 18, 2014 | 10:04 PM
Mooser's Avatar
Mooser
It shows up here and there. I needed it when I built my spreader bar mounts for the BB.
One of the diagrams you'll find is from a 79 frame manual (same as the others)
There are a few threads here on the forum where it pops up (at least one I thanked someone for posting since I knew I'd need it, can't find that anywhere to give credit to
https://www.corvetteforum.com/forums...install-3.html Post #50 V2Racing
https://www.corvetteforum.com/forums...dimension.html
https://www.corvetteforum.com/forums...ft-offset.html
Etc. Etc.
And the one that I referenced back to is from Van-Steel
http://www.chevydiy.com/c3-corvette-...al-reassembly/
Where they have a jig to check
HIH
M
Old Sep 18, 2014 | 10:41 PM
Kim72's Avatar
Kim72
That's great. Thanks again.
To A-arm/Frame Dimension Question
