Engine Build
http://www.jeepstrokers.com/calculator/
With the 64 cc heads and 5cc pistons, 4.030 bore, .040 squish, 5.7" rods and the CS XR276HR-10 cam you get.
11.12 CR and 8.96 DCR. That DCR is too high for pump gas.
Now change to a 72 cc head and you get.
10.17 CR and 8.22 DCR. That DCR is just right for aluminum, not for cast iron.
increase the pistons to 7cc and you get.
9.96 CR and 8.05 DCR. Still just a skoosh high for cast iron to be comfortable.
increase to 12cc pistons
9.48 CR and 7.67 DCR. Comfortable for cast iron heads.
You could try for a 9cc piston if you can find one and that would put you at 7.9 DCR.
If you do get dish pistons get the D-dish or also called the reverse dome piston like this one shown here.
http://www.summitracing.com/parts/ue...-030/overview/
Note that they have a flat area for quench when approaching the head. This is important for turbulance for the fuel air mixture and good flame propagation to prevent detonation.
Let us know how it goes.
One more option is to take that cam you chose and have it ground on a 112 LSA. That would drop your DCR to 7.93.
Or choosing a cam with a slightly later intake closing. The one you chose is at 64*. So if it were moved to say 66* then you could drop the DCR to 7.93 as well.
Many different ways to get it in a good operating range. DCR isn't the end all of cam a choice, but it is a good indication of if it will run well on pump fuel without problems from detonation.
I believe that the broken top ring land is due primarily to installation error.
KB requires a much larger ring gap on the top ring than other manufacturers.
If you gap the top ring too small the ring ends butt together and seize in the bore breaking off the top ring land.
Gapped properly I have had no issues with my KBs. They are one of the few well priced pistons that have proper compression height and good D-dish design available. In flat tops you have many more options. D-dish, not so many.
The weight loss of the front end is an added bonus.
I don't understand the attraction to iron heads but then again I did fail kindergarten so have at it.
So my next question is, i don't understand these different piston cc's. If the pistion is a flattop, how do you get a 5cc piston, or a 7cc piston , or 9 or 12cc??? Oldchev.
http://www.summitracing.com/search/p...rder=Ascending
These are all Dish 12 CC. Notice also there are different compression heights (pin centerline to piston top) which give you different piston to deck distances that also effect compression.
Here's the facts: 415 lb-ft at 2500rpms. ( since I'm running 2550 at 65mph I think we nailed that pretty good) Holds that to around 4100rpms. Then is climbs...at 4323rpms peak torque is 490 lb-ft. At 5400 torque is 446 lb-ft and HP is 459. At 5900rpms torque is 415 again and peak HP hits 467 horsepower. Geez, I hope that's going to be enough.
The engine has the parts in it that we've discussed during this thread. Dart Iron Eagle 180, 72cc heads, Flat Top Pistons, Comps 08-423-8 cam, Edelbrock Performer intake. Dave.
The engine has the parts in it that we've discussed during this thread. Dart Iron Eagle 180, 72cc heads, Flat Top Pistons, Comps 08-423-8 cam, Edelbrock Performer intake. Dave.Here's the facts: 415 lb-ft at 2500rpms. ( since I'm running 2550 at 65mph I think we nailed that pretty good) Holds that to around 4100rpms. Then is climbs...at 4323rpms peak torque is 490 lb-ft. At 5400 torque is 446 lb-ft and HP is 459. At 5900rpms torque is 415 again and peak HP hits 467 horsepower. Geez, I hope that's going to be enough.
The engine has the parts in it that we've discussed during this thread. Dart Iron Eagle 180, 72cc heads, Flat Top Pistons, Comps 08-423-8 cam, Edelbrock Performer intake. Dave.Mine looks identical to this with the exception of the stud on ps rear runner.
http://www.summitracing.com/parts/wnd-7546
