Choke pulloff question
Old Aug 24, 2015 | 12:35 PM
71 Green 454's Avatar
71 Green 454
Default Choke pulloff question
The choke pulloff on my '71 454 doesn't hold vacuum. There is one at NAPA, part number CRB24773 for $16.20.
Question, how do you remove the pulloff from the mount? Does it pull straight out and the new one snap back in?
http://www.napaonline.com/Catalog/Ca...773_0062528371
Old Aug 24, 2015 | 01:12 PM
toobroketoretire's Avatar
toobroketoretire
Yes
Old Aug 24, 2015 | 01:23 PM
Alan 71's Avatar
Alan 71
Hi 71,
I'm curious what the front 'cover' on your pull-off looks like?
Is it by any chance gray plastic with the R/P logo of Rochester products molded on it?
Thanks!
Regards,
Alan
Old Aug 24, 2015 | 01:32 PM
71 Green 454
Originally Posted by toobroketoretire
Yes
Originally Posted by Alan 71
Hi 71,
Thanks!
Regards,
Alan
No, it's off-white/yellowish in color...the original one from the factory. It looks like the one that Russ posted here:
https://www.corvetteforum.com/forums...choke-rod.html
Old Aug 24, 2015 | 01:33 PM
Dave J's Avatar
Dave J
Where the plastic meets the metal there is a square mounting surface that gets pushed onto the choke mechanism. First you must bend the "tabs" of the choke mechanism holding the old pulloff open. Then you carefully slide the old one off. You can then slide your new one on and bend the "tabs" back into place.
Old Aug 24, 2015 | 01:40 PM
Alan 71's Avatar
Alan 71
Hi 71,
I'm looking for one that has this appearance.
I believe it's one year only.
Regards,
Alan
Old Aug 24, 2015 | 01:46 PM
71 Green 454
Are the tabs you're referring to in this photo?
Old Aug 24, 2015 | 01:55 PM
Dave J's Avatar
Dave J
Look where the pulloff meets the choke mechanism. The squared base of the plastic and the groove of the slot where it goes into.
Old Aug 24, 2015 | 02:35 PM
71 Green 454
Hi 71,
Thanks!
Regards,
Alan
I see RP on the front with 5 numbers, but it's not gray.
Have you seen other 71's with gray choke pulloffs?
Old Aug 24, 2015 | 02:36 PM
71 Green 454
Thanks Dave J,
Dave C
Old Aug 24, 2015 | 02:46 PM
Alan 71's Avatar
Alan 71
Hi 71,
I really don't know.
That's what was on my base motor's carb, but it's certainly possible it was different on a 71 bb carb.
I see the white plastic and the metal pull-offs too.
Regards,
Alan
Always looking for the littlest detail!
Old Aug 24, 2015 | 02:53 PM
Dave J's Avatar
Dave J
Alan, I have several of these R/P logo'd pulloff's. I am not in a position to take a pic now, but can later today. I have a top shell, one on my '70 L46 (not original) and several slow leakers. I could bring them to Carlisle if you want to see them in person.
Old Aug 24, 2015 | 04:50 PM
Alan 71's Avatar
Alan 71
Hi Dave,
Yes, I would be interested in seeing them… are you implying that they're that gray color?
Regards,
Alan
Old Aug 24, 2015 | 08:40 PM
Dave J's Avatar
Dave J
Alan, The pulloff on one of my cars appears to be a light grey color. It's hard to get a good picture of it installed. If you like I could pull it off and bring it to Carlisle. If it's what you want, I will trade it for another original one of any color, it doesn't matter to me.
Old Aug 25, 2015 | 06:16 AM
Alan 71's Avatar
Alan 71
Hi Dave,
It sounds like it could be what I'm looking for but I'd need to see it to be certain.
I don't have a pull-off to trade but would certainly be willing to buy it from you.
Regards,
Alan
To Choke pulloff question
