Exploding C3 Myths
For someone to say "ignorant people who believe these myths" is calling EVERYBODY ignorant.
Everybody uses their cars for different things and is setup differently. To make blanket statements about setting timing or which water pump to use (or any setup) depends on the individual car, and how it will be used. To call them "ignorant" for not following your advise is offensive.
BTW, If i want to drive in figure 8's in a parking lot, I am going to do it. If you don't like it, then don't watch.
In Before The Lock
If, as toobroketoretire says, the heat soak affects the magnetic strength in the solenoid then he has to accept that it also affects the magnetic strength in the starter and makes it crank slowly - you can't have one without the other.
My white '74 coupe has the most work done, a Borgeson steering box, Hydroboost and a Holden V8 aluminum/plastic master cylinder. On one of my US trips, I brought home a Sanderson Block Hugger kit and fitted it. When it came time to connect the headers to the rest of the exhaust system I had some concerns about heat soak and filter removal, so I bought some 2-1/2" mandrel bent steel pipe with 45* and 90* bends. I "kinked" the driver side one out and around the filter so, upon removal, I can drop the filter straight down with minimal spillage and ditto upon replacement.
On the passenger side (still LHD) I routed the pipe out and around the starter motor so that the heat soak would have minimal effect on the starter. I agree that this is probably overkill, perhaps not even needed at all, but as I had to complete the exhaust, I could put the pipes where I wanted to, and I did. So far, even in the HOT Australian summers, I have never had a problem cranking the engine when it's hot. But then again, neither do I have a problem with my '74 'vert with a stock exhaust under similar conditions.
As Corvette starter motors, as well as ALL other parts are expensive on this side of the pond, I was merely putting into place what I hope was a small degree of preventative maintenance and hope that some of you Forumites might benefit from it.
Regards from Down Under.
aussiejohn
Yes, a mechanical secondary carburetor can be used on a street engine but a vacuum secondary or AVS carburetor offers much better low rpm performance because of the limited throttle opening and that is why the factories have always used them. For stock L-48's I highly recommend using a #1848 465 cfm electric choke Holley because of it's smaller primary venturi sizes or the OEM QuadraJet for the same reason.
If, as toobroketoretire says, the heat soak affects the magnetic strenght in the solenoid then he has to accept that it also affects the magnetic strenghth in the starter and makes it crank slowly - you can't have one without the other.
I will add one. Here is one I heard from an esteemed forum expert.
HEI ignition modules dont need regular heat sink compound, just use RTV.
Now there are specialized RTV heat sink compounds, but this myth says to use regular engine sealant RTV.
But.. the proponent of this myth also says he drilled a hole in his distributor cap and firewall so that a hose connected to his A/C vent will blow cool air on the module preventing overheating...........
If that isn't engineering... I am not sure what would qualify.
I quit now
Forgive my ignorance but, what size is the OEM QuadraJet for a corvette. I could've sworn they were 750cfm (some 850cfm). I also thought that they are all mechanical secondary not vacuum secondary.
Hardly seems an agape-worthy answer.
Edit: Just saw Priya beat me too it.
I'm surprised you want to go there, but since you brought it up...
https://www.corvetteforum.com/forums...onversion.html
I am curious (maybe ignorant?) about the heat soak starter thing. I have certainly experienced it on lotsa GM cars. I don't think it was a problem when they were new. And wasn't a Ford remote solenoid a fix? For full disclosure, I use the high torque mini starters...
And the glass 1/2 full thing? The answer is we don't have enough water in CA. It was supposed to pour today; we didn't get much. I had to wear long pants, though. Kinda cold in winter...
