Solid Motor Mounts BBC
Old Jan 13, 2016 | 07:27 PM
stc315's Avatar
stc315
Default Solid Motor Mounts BBC
Pulling the 454 in my 72 to reseal and repaint block and heads. I was thinking about adding solid motor mounts while I have it out. Does anyone make solid mounts for it? I think Moroso does, but I couldn't find anything definite on it.
Thanks,
Sam
Old Jan 13, 2016 | 07:34 PM
stc315's Avatar
stc315
Dang it, found my answer. Looks like Moroso does still make them #62530. Couldn't find it in Moroso catalog, but found it on Summit lol. Has anyone used them on their big block? Just want to make sure there are no issues.
Thanks,
Sam
Old Jan 13, 2016 | 07:43 PM
MotorHead's Avatar
MotorHead
From: Who says "Nothing is impossible" ? I've been doing nothing for years.
Yeah Moroso does, but I always thought the mounting points were the same in Corvette for Big or Small blocks.
Anyway I have them under my 427ci smally and I really like them. I had them on and changed them to poly and changed them back to solid.
Make sure you use a polyurethane transmission mount with them. You don't want all 3 mounting points of engine / transmission to be solid
Old Jan 26, 2016 | 02:42 AM
stc315's Avatar
stc315
Update. Got the motor out, re-sealed, cleaned, and painted. Installed new oil pan, pump, and pick up. Installed Moroso mounts with ARP bolts. Added chrome timing cover and black balancer cover. Have to do some clean up on the engine compartment before I can put it back in.
Old Jan 26, 2016 | 09:23 AM
BKbroiler's Avatar
BKbroiler
I have Moroso solid motor mounts on my small block. One thing I would recommend is to check that the motor mounts slide over the chassis mounts enough to get the bolt in. Mine wouldn't drop down with the weight of the engine on them. I had to lift the engine up and spread the mount. Only happened on one side but it was a PITA.
Also, you might want to upgrade that oil filter.
Old Jan 26, 2016 | 09:35 AM
stc315's Avatar
stc315
Thanks, I will look for that. Usually use hp4 filter, but this engine is bone stock. Cast bottom end 2 bolt main with mild cam. Planning to build a 540 next year.
Old Jan 26, 2016 | 11:31 AM
Kubs's Avatar
Kubs
2024 C5 of the Year Winner - Modified
2023 C5 of the Year Finalist - Modified
St. Jude Donor '09-'10-'11
FRAM have been known to fall apart and send cardboard through the engine. I prefer WIX or Napa Gold (same as WIX) as they are all metal construction.
Old Jan 26, 2016 | 11:38 AM
MotorHead's Avatar
MotorHead
I use the HP-4 high performance / racing filter. No cardboard in these filters.
Old Jan 26, 2016 | 11:52 AM
marshal135's Avatar
marshal135
Veteran: Marine Corps
That's a thing of beauty
Definitely WIX filters.
All I use on a street driven stock 427.
Thanks for the pic.
Marshal
Old Jan 26, 2016 | 11:56 AM
Kubs's Avatar
Kubs
You sure about that?
A quick google search showed this:
Also, here is a filter comparison we did over in the C4 section a few years ago. It shows how robust the WIX/Napa filters are.
https://www.corvetteforum.com/forums...d-version.html
Old Jan 27, 2016 | 09:54 PM
stc315's Avatar
stc315
I picked up a WIX filter today and ordered a new upper radiator hose since the last one I bought was too short. I also picked up some fiberglass and resin to patch a hole I found on the A/C housing on the firewall. Was going to patch it with tape for quick fix but decided I better do it right since I have the engine out already.
To Solid Motor Mounts BBC
