CrossFire TBI problem
Old Jan 20, 2016 | 02:31 PM
Bandit524's Avatar
Bandit524
Default CrossFire TBI problem
We've owned our 82 since 87, second owner, 52,000 miles, and trouble free until recently. Started running rough and ended up having it towed home. Symptoms were similar to others I've read about a failing fuel pump so ordered a stainless steel OEM from RockAuto (http://www.rockauto.com/catalog/more...nid=301&jpid=0). Original was a rusted mess and assumed the new one would solve my problem. New pump installed, barely runs, only the passenger side injector primes and shoots fuel. Put a pressure gauge on with new pump and indicates zero pressure while running. Checked for stored codes--none! Called RockAuto, ordered a second pump, installed, and no change! Any ideas?
Old Jan 20, 2016 | 04:50 PM
MelWff's Avatar
MelWff
where are you mounting the pressure gauge?
how are you getting zero pressure while running?
are you sure your gauge works?
if it runs you have some pressure.
did you change the fuel filter?
Old Jan 20, 2016 | 05:08 PM
Bandit524's Avatar
Bandit524
Thanks for helping out!!!
Brand new fuel filter; borrowed a fuel pressure gauge testing unit from Autozone and placed the gauge via a T fitting where the fuel filter goes.
I asked myself the same question; obviously getting some pressure but not enough to register?
Plan on trying a different gauge from another Autozone.
Maybe a poor ground and pump isn't getting 12 volts?
Old Jan 20, 2016 | 05:29 PM
usmilret's Avatar
usmilret
If you hear your pump singing along happily then I would suspect a flu blockage between the fuel pump and the fuel filter. Could it be probable that your pump is not correctly wired?
You can also remove the fuel pump and verify 12 VDC at the furl pump.
I believe that the reason why your driver's side TBI is not getting fuel is like you said. Low fuel pressure.
Old Jan 20, 2016 | 05:40 PM
Bandit524's Avatar
Bandit524
New pump has factory connections just like the original and only one way to connect so I know that's not the issue.
Both 3 amp fuses are good for the injectors.
I've got an ohmmeter but not sure how to check for 12 VDC.
Old Jan 20, 2016 | 06:12 PM
slickfx3's Avatar
slickfx3
wild guess , rebuild your TB's
driver's tb get's fuel first not second, fuel return line attached to the pass tb
you should get a 85-87 pump, woefully inadequate is the stock pump
how was the sock? if it disintegrate in your gas tank and you ran it without the filter to check pressure, you just shot all they debris into the nozzles
you changed your filter?
Old Jan 20, 2016 | 06:52 PM
Bandit524's Avatar
Bandit524
New filter and sock on original factory pump was intact; never ran it without a filter other than to check the pressure and the problem was apparent prior to that. Disagree about the 85-87 pump; original factory was good enough to get 30 plus years and that's good enough for me. And I can barely hear the pump cycle on when ignition is turned on and soon thereafter ceases.
Old Jan 20, 2016 | 07:22 PM
slickfx3's Avatar
slickfx3
sorry sir but the research is in and the most basic and sought after and meaningful mod is a 1985-87 pump in a 82, i have an 82, you are already in there why not?
however.
you have a new 82 pump which max out at
Old Jan 20, 2016 | 07:25 PM
slickfx3's Avatar
slickfx3
however.
i think you have located your problem, no fuel in the pass tb, that is where i would start looking...i think those tb have little screens in them, never had mine apart...
Old Jan 20, 2016 | 09:51 PM
Bandit524's Avatar
Bandit524
however.
Worried about the possible problems 30-40 psi might pose in a system designed for 15 psi!
Old Jan 20, 2016 | 10:19 PM
slickfx3's Avatar
slickfx3
i run it, daily no problems or rather my problems went away, it's a cure,
if your afpr is set at 40 yes, but if it's stock it prolly set at 13.
the stock pump was know to put out a few lbs too low when new and as they aged it went down from there and idle and wot suffer, it ran lean up there, didn't give the already compromised crossfire it full potential, and we all know crossfires need help
but your issue sounds like a malfunction you can actually see, pull that TB
Old Jan 21, 2016 | 07:12 AM
Bandit524's Avatar
Bandit524
There is no fuel in the drivers TB and no pressure either in the supply fuel line prior.
Bought my own fuel pressure gauge last night so going to recheck this new second pump.
Still not getting pressure, either the line is blocked, an electrical problem, or two bad "new" pumps which I find difficult to believe!
And thanks for your continued assistance!
Old Jan 21, 2016 | 07:26 AM
74 LS4-454's Avatar
74 LS4-454
Finalist 2020 C4 of the Year - Unmodified
Check your lines for being blocked.....when you disconnect the fuel filter, the gas should be running freely from that line, when you switch the key on and the pump gets activated. Of course if you have a good flow there, then you may have blockage from that point up to the TB's. It's possible some dirt or particles made it past the filter and is lodged in that line preventing the TB's from getting the proper flow.
The pump will only be heard for 2 seconds after the key is turned on.
You can also check your fuel pump relay in the battery, ECM area. It might be possible that can be defective.
Old Jan 21, 2016 | 10:53 AM
slickfx3's Avatar
slickfx3
i don't have my ac compressor in right now, so i can see the 2 rubber hoses the connect to the in and out fuel lines to the TB's, it's next to the right upper control arm rear bushing pita to get to without the compressor can't imagine with near where the mechanical fuel pump block off plate.....but that allows you to pump gas pass the filter
you can separate the blockage either to the engine or to the gas tank
Old Jan 21, 2016 | 10:54 AM
Jebbysan's Avatar
Jebbysan
Dr. Detroit
Have you inspected the pressure regulator diaphragms?
#7 and #8 in this photo.....
Jebby
Old Jan 22, 2016 | 11:42 AM
Bandit524's Avatar
Bandit524
I think I've found at least part of my problem; only 8 VDC at the 3 pin connector that plugs into the fuel pump. And yes the battery is fully charged. Not electrical smart so any help in tracking this down is appreciated!
Old Jan 22, 2016 | 02:43 PM
Bandit524's Avatar
Bandit524
Checked fuel pressure at the pump outlet: 20 psi.
Blew the line out both directions and pressure at filter location via T fitting: 14 psi.
6 psi drop between pump and filter?
Thinking the problem is at the TB like many have suggested!
To CrossFire TBI problem
Old Jan 22, 2016 | 04:28 PM
Bandit524's Avatar
Bandit524
Are you sure?
The pass TB gets fuel first, fuel return line attached to the driver's TB.
Old Jan 22, 2016 | 04:33 PM
DUB's Avatar
DUB
Honestly...I have the pressure gauge where I remove the steel line that joins BOTH throttle bodies and install my fuel gauge set-up there as it is shown in the FSM. I really do not think you have a fuel pressure problem.
I would be more concerned IF you were getting the fuel pump to turn back on when you crank the engine AFTER the initial TWO SECOND PRIME that occurs when you turn the key on. AND YES....making sure that you have 12 volts going to the pump is VERY IMPORTANT...obviously.
DUB
Old Jan 22, 2016 | 04:42 PM
Bandit524's Avatar
Bandit524
Jebby
This is the driver's TB pressure regulator, the one where I'm not getting any fuel at!
I'm ready to start throwing parts at it!
