Hey Kubs, did you have to modify to get those tens to fit? I have a pair of 10" and a pair of 8-1/2" slots I'd like to try on my '74.
I have not had the car on the ground with them yet. I am still doing engine work on it. However, jut eyeballing, it looks like the fronts may rub the inner part of the factory flare while turning. I do plan to put L88 flares on mine so it wont be an issue.
rosslato - What width are your rear wheels? What backspace are they? Are you having any clearance issues?
Thanks,
SR
10" wheels in the rear. Not positive but think i've got half inch spacers and have no clearance problems and stock TA's. Don't remember the Backspacing as i've had my Cragers on there over 20 yrs.
Reason: to add
I like 15 Inch wheels on the C3 and classic Muscle Cars in General the best too. It is just period correct and Looks great. I dont understand, since the demand for These tires is there, why the good Tire Companys dont produce as the demand requires. Companys like Good Year or Michelin. Yes, I know there is the Michelin XWX but it is only produced as big as 225, and it is outrageous expensive. Why dont they produce a good "H" rated tire anymore in various sizes?????? People would by it, I believe.
I figured I would update mine now that it has been on the ground. I also have Van Steel 550lb loweing springs in the front and longer bolts in the rear. I added about -2.5° of front camber to help with cornering and also to clear the fender lip but it still rubs on bigger bumps. Flares will be the next step.
Originally Posted by Kubs
I have US Mags Indy U101 15x10 all around with 265/50R15 front and rear. No great pictures yet as it is still being worked on, but I can update later on.
Damn Kubbs those slots look tuff on your car. Did go go as low as possible in the rear? In a perfect world, mine would be the same in front, but a bit lower in the rear. I recon you have it where you want, and the flares will be installed to fit the tires?
Thanks Richard! I can go lower in the rear. I have about 1/2" of threads showing after the nut on 8" long spring bolts. I am a big believer of measuring ride height to the frame rather than the fender. Doing that gives me about 3/4" of rake (which is where I want it), but it looks like more than that just looking at the fenders. I think maybe the body is high in the rear or something. It had a larger rear wheel gap even at stock ride height with stock tires. I will be molding the flares around the tires yes.
Hi Guys from down under,Went for a run yesterday and took a couple of pic's, 255 x 60 rear and 245 x 60 front with American Racing Daisy Cutters
Dave NZ
Dave NZ
Hi Richard, Stock front and back,but have taken 1 coil off the front and installed 8" bolts in the back which dropped the front 1.75" and rear 1.5"
I like the old school look,I'm pretty happy with the results
cheers Dave NZ
cheers Dave NZ
cheers Dave NZ
Dave NZ
The Daisies look great on there. Are those wheels the same size as stock?
Hi Richard,I think the stock rims are 8 1/2" and the Daisy rims are 9", They seem to fill the guards up OK, on a side note dropping the front end has given me better wheel clearance!I have no issue now with wheel rubbing that I did before
Cheers Dave NZ
