Question
Old Mar 5, 2016 | 05:06 PM
phminell's Avatar
phminell
Default Question
Hello,
Any idea what the use of this switch is ? I found it hanging on its electrical cables when I took down the vapor canister and the windshield washer tank and pump.
This is the same kind of switch that is behind the headlights to detect headlights proper opening.
Thank you for your ideas :-) ...
Old Mar 5, 2016 | 05:08 PM
7T1vette's Avatar
7T1vette
Looks like the switch mounted to the headlamp system which 'tells' wherether the lights are fully open (or not).
Old Mar 5, 2016 | 05:20 PM
phminell's Avatar
phminell
You're right, this is the same, but this one is behind the vapor canister, on the left of the engine near the clutch mechanism, underneath the brakes mastervac. I really wonder what's its use ? and where it is supposed to be fixed ?
Old Mar 5, 2016 | 05:32 PM
Alan 71's Avatar
Alan 71
Hi phm,
The switch is also used as part of the anti-theft system on 75-E77 cars.
Maybe?
Regards,
Alan
Old Mar 5, 2016 | 05:45 PM
DUB's Avatar
DUB
YES...this 'tamper' switch is so your alarm system would blow the horn if someone tried to pull the lock cylinder out of your fender to dis-arm the system. AND YES...as mentioned by '7T1vette'...it is the same at your headlights also.
DUB
Old Mar 5, 2016 | 05:52 PM
Alan 71's Avatar
Alan 71
Hi DUB,
Well, that certainly puts the switch in the 'neighborhood' phm described!
Regards,
Alan
Old Mar 5, 2016 | 06:20 PM
phminell's Avatar
phminell
thank you guys :-) I got it !
Old Mar 5, 2016 | 08:07 PM
Peterbuilt's Avatar
Peterbuilt
Willcox Corvette published this 'how to' some time ago:
Old Mar 6, 2016 | 06:14 PM
DUB's Avatar
DUB
Glad that you posted that....and good to know that Willcox has that apart of the repair library.
DUB
To Question
