Roll Over Valve-Do I Really Need It?
Old Mar 26, 2016 | 11:09 AM
Richard Daugird's Avatar
Richard Daugird
Default Roll Over Valve-Do I Really Need It?
Pulled the tank in my '74 Coupe last night and noticed the rollover valve is a bit damaged. I live in a pretty flat area, can I do away with it?
Old Mar 26, 2016 | 11:36 AM
Richard454's Avatar
Richard454
It does more than just keep gas from pouring out of the tank if you park the car on a steep incline or flip the car over-
It's also called a fuel separator- as it keeps gas from sloshing in the vent line....Not good....Without it- you'll reincarnate the Ford Pinto!!!
Have you though about removing the seats belts too!!!
I have an original one in pretty good shape- if interested shoot me an email richard454 at comcast dot net
Old Mar 26, 2016 | 11:55 AM
Luce's Avatar
Luce
In an ideal world, or if you plan to be cremated anyway, no you don't. In that same ideal world you also don't need to tighten your wheels tighter than 10 ft/lbs or use tempered glass on the side windows or laminated glass in the front.
They're money well spent.
Old Mar 26, 2016 | 01:10 PM
Richard Daugird
O.K Thanks I'll look at mine and see if it's still good!
Old Mar 26, 2016 | 01:31 PM
GUSTO14's Avatar
GUSTO14
Richard, a few years ago, you were stuck with what ever you could find at a swap meet. There was a guy at Carlisle that had a bucket of old ones he sold for $75 a piece. Most were little better than what you might already have. No one was reproducing them at the time.
Even if they aren't inexpensive, at least now you can purchase a new one.
Fuel separator valve
GM Part Number: 7028035
Years: 1970 - 1974
photo courtesy of Paragon Reproductions
https://www.paragoncorvette.com/p-35...tor-valve.aspx
The plastic body typically splits where it is molded together after the check valve is inserted. Without it after filling the tank, you end up with at best fuel fumes and at worst, a fuel leak over your left muffler. I would recommend you replace it with a new one and be good to go for another 25 years or so.
Good luck... GUSTO
Old Mar 26, 2016 | 01:34 PM
Richard Daugird
Thanks, if I need a new one it will come from Wilcox. As helpful as he is here, a part would have to cost a significant bit more for me to shop elsewhere.
Old Mar 26, 2016 | 01:49 PM
Alan 71's Avatar
Alan 71
Hi RD,
The vapor separator is pretty simple.
As long as the body and nipples aren't cracked the only way to check if it's working is to shake it and listen for sound that is like a ball bearing bouncing around in it.
If you don't have the the vapor canister in the engine compartment hooked up you should cap the nipple on the gas tank.
Regards,
Alan
To Roll Over Valve-Do I Really Need It?
