alignment specs
Old May 10, 2016 | 05:26 AM
69small block's Avatar
69small block
Default alignment specs
Recently
got a quicktrick alignment tool as a gift. anyone use on of these and what specs did u use since all the ones i have referenced are for bias type tires I would think they would be different for radials.
any suggestions
thanks for help
Old May 10, 2016 | 07:06 AM
Ibanez540r's Avatar
Ibanez540r
Originally Posted by 69small block
Recently
any suggestions
thanks for help
I swear someone fairly recently posted a thread with all the different company alignment recommendations, but I can't seem to find it. maybe someone else will post a link...
Anyway, here are the various specs from VB&P
https://www.vbandp.com/instructions/...pecs/file.html
Old May 10, 2016 | 01:14 PM
wendellp601's Avatar
wendellp601
Default Here's a consolidated list
Recently
any suggestions
thanks for help
I bookmarked the thread below some months back for future reference.
It has tables from a number of different sources.
Hope this helps.
https://www.corvetteforum.com/forums...ent-specs.html
Old May 10, 2016 | 02:34 PM
Ibanez540r's Avatar
Ibanez540r
Hope this helps.
That's the one
Old May 10, 2016 | 04:48 PM
ddawson's Avatar
ddawson
I use the Van Steel Advanced street but with 1/32 toe in on mine. Works great.
Old May 11, 2016 | 05:28 AM
69small block
Thanks guys for the info
Old May 11, 2016 | 08:00 AM
7T1vette's Avatar
7T1vette
Gotta have a bit of toe IN on the front end to make the wheels "track" straight. If you have neutral toe, the wide tires will wander around on roads that are not truly flat.
Old May 17, 2016 | 07:20 PM
Luce's Avatar
Luce
I set for +5 degrees castor, but it causes excessive bumpsteer. Does anyone sell one of those tapered studs so you can replace the outer tie rod with a heim and 2 nuts and adjust the bump steer out?
To alignment specs
