Reverse Lights
Old Jul 1, 2016 | 02:05 PM
Hawgdified's Avatar
Hawgdified
Default Reverse Lights
I dont have any reverse lights. Cant figure it out. I replaced the fuse which is in w the blinkers. Blinkers work fine. I changed reverse bulbs. Is it the backup switch ?
Old Jul 1, 2016 | 02:15 PM
billschroeder5842's Avatar
billschroeder5842
Zen Vet Master Level VII
Yes, there is a switch.
What year is your Vette? Auto or manual?
Old Jul 1, 2016 | 02:16 PM
Knerf's Avatar
Knerf
have a multimeter?
you can test the switch and see or check the wires running back to make sure they dont have a break somewhere in them.
Old Jul 1, 2016 | 02:35 PM
Hawgdified's Avatar
Hawgdified
Originally Posted by billschroeder5842
yes, there is a switch.
What year is your vette? Auto or manual?
76. Mt
Old Jul 1, 2016 | 02:59 PM
Easy Mike's Avatar
Easy Mike
Cruise-In II Veteran
Have you checked the switch?
Old Jul 1, 2016 | 03:01 PM
Hawgdified's Avatar
Hawgdified
I haven't. Im kinda new to all this so not sure where to start or how to find it
Old Jul 1, 2016 | 07:27 PM
SH-60B's Avatar
SH-60B
The switch should be attached to the shift linkage on the side of the case. You can jumper the leads to see if the lights come on.
Old Jul 1, 2016 | 08:46 PM
65GGvert's Avatar
65GGvert
The switch is attached to the transmission and has a short linkage rod going to the reverse lever. The short rod could be missing, misadjusted, bent, etc. The switch is adjusted by loosening two screws that hold it to the transmission and rotating the switch until the lights come on in reverse (switch on) and go out in any other gear, including neutral.
Old Jul 5, 2016 | 05:01 PM
Richard Daugird's Avatar
Richard Daugird
How difficult would it be to wire a switch to manually turn on the reverse lights when the car is not in reverse? Kinda like a cargo light on a pickup, if you were in a dark parking lot and needed some light.
Old Jul 5, 2016 | 07:23 PM
65GGvert's Avatar
65GGvert
Not difficult at all. Just wire a switch across those pink and green wires I posted. You can get to it at the firewall under the master cylinder, or at the transmission. Shorting the pink and green wires turns on the reverse lights, just as shifting the transmission to reverse shorts those same two wires. It's probably not a good idea, because you'll probably end up driving with them on, but it will work.
Old Jul 5, 2016 | 08:39 PM
Alan 71's Avatar
Alan 71
Hi,
I believe adding the switch as 65GG suggested is even easier than he described… that pink/green connector that's on the engine side of the firewall is part of the DASH harness (it comes through the 4 hole grommet along with the tach cable and oil pressure line, on '70ish cars).
So it can be pulled back into the interior and the switch added.
Regards,
Alan
Old Jul 5, 2016 | 09:18 PM
71 Green 454's Avatar
71 Green 454
I would check the short linkage rod, maybe a clip fell off.
Old Jul 5, 2016 | 09:52 PM
65GGvert's Avatar
65GGvert
Originally Posted by Alan 71
Hi,
Regards,
Alan
My thinking was that he also wanted the lamps to still work in reverse when shifted, so adding the switch and running the two wires to the plug at the firewall was my solution. I may have misunderstood his intentions, but now with your idea he knows his choices.
Did you notice that the guy wanting to add a switch was not the same as the OP whose switch didn't work?
Old Jul 7, 2016 | 10:17 PM
65GGvert's Avatar
65GGvert
Looks like we may not hear from either of them.
Old Jul 8, 2016 | 09:16 PM
65GGvert's Avatar
65GGvert
Hawgdified, don't leave us hanging. Did you find the problem?
Old Jul 9, 2016 | 10:11 AM
Hawgdified's Avatar
Hawgdified
Not yet. Havent had a chance. My plan is to clean the switch first because its really gunky. Could be just stuck. Then go from there. Thanks for all the feedback
To Reverse Lights
