Differential ring gear backlash problem...
Old Sep 6, 2016 | 03:32 PM
  #41
tracdogg2's Avatar
tracdogg2
I just set up two posi's, both 297. I was using standard replacement shims in .005 increments.
On both the clutchpack on the ring gear side was .055 shim, the other side to .050. But .052 will be better.
Mike
Old Sep 7, 2016 | 05:51 AM
  #42
stingraymax's Avatar
stingraymax
I just checked and am on .040 and .045, if I go higher they bind up and the posi is almost impossible to turn.
Old Sep 8, 2016 | 01:35 PM
  #43
tracdogg2's Avatar
tracdogg2
Don't go by Toms video. He is using a new eaton carrier and new spider gears. Set the clutches up one side at a time, then assemble it and check your end play.
Mike
