Need more electrical help, PLEASE!
I started to drive the car this year, and noticed that the wipers wouldn't work. I found some disconnected vacuum hoses, and reconnected them, so now the wiper door is working correctly, but the wipers still won't go. I found that a bad splice on the brown (ground) wire had become disconnected, so I fixed that, but the wipers still wouldn't go. Then, I noticed that the blower motor had stopped working. I then found the fuse was blown again, and replaced it. Now, with a good fuse, and a fixed brown wiper wire, neither the wiper motor nor the blower motor are working.
I have spent more than an hour pouring over the wiring diagram trying to figure out what could be wrong, and am baffled. Any help available?
Edited to add: 1970 big block with AC.
I would check the power ar your blower motor. You may have burned a wire or melted a switch.
Then check your grounds again.
Good luck
ANY other wire is bogus and don't belong there.....SO that wire I refer to in your OE post is probably black and belongs UP TOP connected to a bolt on the intake
3 wires to the starter.....BATTERY, Starter from ignition switch,
(small one next to block) and another one from the large BATTERY post to feed rest of the car......
IF someone still has a breaker point ign. you can have another wire to the outer side of the solenoid, away from the block.....
'70 BB, so it is a short hood. The first thing I checked was the ground, it was bad, so I repaired it. Checked all fuses again, and the AC was blown again. replaced that, but still no joy on the wipers. Ground still checks as good.
I always start at the resistor... I check for power coming into the resistor on either the yellow, green, blue or purple based on which speed you have the switch in. If I have power there then I test at the motor, if I don't have it there I go inside the car to find out why. The brown wire feeds power from the fuse panel to the switch located on the left side of the control. This switch sends power to the speed switch so I'd test there next.
I haven't used my wipers since the '80's and when I checked them a few months ago, they would not work. There was no battery getting to the wiper motor, it turned out to be dirty contacts at the override switch under the steering column.
I started at the wiper door safety switch, no battery, then I checked at the override switch and had battery on one side but not the other. And yes, the switch was in the correct position. Removed the switch and cleaned the contacts....problem solved.
This is the schematic I used to get the blower motor working. It works fine now, but did blow another fuse, so I may have more work to be done there.
What I am working on now is the wipers. From reading older threads, you apparently have a "tutorial" on wipers? I couldn't find that on your site. Can you post a link?
A friend of mine came over this afternoon to take a look for me. He is convinced that my ground is, in fact, bad. We were able to confirm voltage to the wiper motor, but could not confirm ground. Actually, we could not get any continuity from the engine block to the negative terminal on the battery, so we both walked away confused about how to effectively test a ground.
If you have no ground from the engine to the frame run one. then check the frame to the birdcage .
to check, use a multimeter on the resistance setting. some have an audio alert when you have 0 resistance. you are looking for as close to zero as you can get. touch the 2 leads together and you get 0. running through wire will give you some resistance but very minimal.
http://repairs.willcoxcorvette.com/?yt=1972&s=wiper
Here is the direct PDF that deals with wipers and issues associated with the system.
http://repairs.willcoxcorvette.com/1...-72-with-test/
When you search the tech page always make sure look at the bottom for "Older Post".. it's on the second page.
Willcox
After watching the tutorials, and studying the diagrams from Willcox, I was re-convinced the problem was with the ground since I had 12 volts at the yellow wire. So I disconnected the spliced black wire, and forced a ground there with a jumper. The wipers did not work, but worse, the whole car is dead. Nothing electrical is working. All of the fuses are OK, but no interior lights, no headlights, no starter motor, nothing.
I would say I am more than a little frustrated. Any ideas where to go next?
Check the fuse links now, this is for a 72 but I think it's the same for your car.
Remove the connections from the wiper motor and then there should be some kind of testing that you can do between terminals on them to see if all is OK. I don't have that info, but think that testing with an ohmmeter to see what resistances you have between all combinations of the terminals should help you decide if there is a short in the motor assembly (as I suspect).
If you have blown one (or more) fusible links, you should know that you should NOT replace them with regular wire. You should find suitable fusible links to replace them. Yes, they are just smaller AWG wire...but they are inside non-flammable insulation and terminated by non-flammable end pieces. That way, if there is a short that fries the fusible link, the insulation will not catch fire.
