trailing arm bolt
Old Oct 4, 2016 | 09:49 AM
tacosupreme's Avatar
tacosupreme
I just had the pleasure of spending the last few nights under the car with the sawzall removing these bolts myself. That is now on my top 2 WORST ever list. I'm now ready to install the replacement bushings.
What direction do the bushing sleeves need to be installed into the bushings from? Does it even matter? I can't seem to find any diagrams for this in the assembly manual or in any of the usual places.
Thanks!
Old Oct 4, 2016 | 11:06 AM
Mooser's Avatar
Mooser
Are you using rubber or poly?
M
Old Oct 4, 2016 | 06:33 PM
tacosupreme
M
original style rubber bushings
Old Oct 4, 2016 | 07:01 PM
Mooser's Avatar
Mooser
Although I can't see why it would matter, I believe every single one I've seen was staked on the outside (wheel side)
Remember they must be compressed before staking
M
Old Oct 4, 2016 | 07:15 PM
DUB's Avatar
DUB
M
100%
The side you stake the bushings does not matter...BUT like 'Mooser' mentioned...I stake all of the trialing arms on the outboard side. This is because when I have my staking fixture tool installed. It can stay on the ground while I hammer the inner sleeve and stake it WHILE it is compressed in the tool.
JUST MAKE SURE....that when you stake the trailing arm bushing...you take a flat file or grinder and make sure that NONE of the inner sleeve you staked is ABOVE the surface of the flat outer washer. You want the shims to be against a totally flat washer surface.
DUB
Old Oct 5, 2016 | 06:56 AM
Stephen Irons's Avatar
Stephen Irons
2024 C3 of the Year Finalist - Unmodified
This post sort of goes hand-in-hand with mine ( https://www.corvetteforum.com/forums...rm-bushes.html )
Alas, I can't take much comfort from it!
This business of compressing the bushes is all new to me I'm afraid. DUB mentioned a video on YouTube? Anyone got a link to that? It sounds like something that is maybe easier over there, where the appropriate tools would be available, but not so easy here in sunny France!
I'm going to have to hunt out some "exploded view" diagrams I think, to understand the "staking" thing as well.
If money was no object I think Gary would have another job!
Old Oct 5, 2016 | 07:16 AM
Mooser's Avatar
Mooser
Here's what the basic tool looks like, there are fancier ones but this is the idea
Someone's home-made version, just as good if you can do it
Clamps onto arm, compresses the bushings to the correct width using the two outer bolts and guides the staking pin in the center
Can be staked with press or BFH
Clean up the end to make sure it's flat for the alignment shims
M
Old Oct 5, 2016 | 05:50 PM
Richard Daugird's Avatar
Richard Daugird
I guess when you hit it it flares out???
Old Oct 5, 2016 | 06:20 PM
Mooser's Avatar
Mooser
Basically yup
You fully install the two bushings making sure they are fully seated.
Compress the inner parts down to measure 2.200-2.230 (Gary)
Stake the inner sleeve with a 45 deg tool to lock the 2.2xx dim in place
File off anything in the way to keep the surface flat for the shims
M
Old Oct 5, 2016 | 06:23 PM
DUB's Avatar
DUB
YES...but that is because the tool you slide down to the sleeve to flare it is made to create an outward cone. And that outward cone matches the taper in the center of the special washer of the trailing arm bushing kit. You can clearly see teh tool with the point on it in the FIRST photo 'Mooser' posted in POST # 27.
DUB
