'76 rear end clunking
When I'm going VERY SLOW, like just barely rolling forward, there is a clunking noise coming from the rear. I notice it mostly when I'm just starting to move after being stopped, and usually when turning. For instance: I come to a red light, prepare to make a right on red, and inch forward to make sure traffic is clear, there is a significant and repeated "clunk, clunk, clunk" which can also be felt. It is not consistent. I even tried to get it to happen to show a friend what I meant, and of course it would not happen. On the way home from his house, of course it did it again.
Any ideas guys? Thanks.
Having said that, my wife had a '79 Corvette that she bought new, when we were first dating. We broke up shortly afterward, and didn't see each other for a number of years. Fate, and problems with her Corvette, that she couldn't HONESTLY get fixed, eventually brought us back together.
One of the issues she was experiencing with the car, was a "clunking" noise in the rear. I replaced the u-joints, as well as a dried-out differential snubber bushing. After addressing these potential sources of the clunk, it was still there.
Bottom line, after these fixes didn't work, I had to dig deeper, and wound up pulling the differential, where I found that the pinion shaft, that the spider gears rotate on, had worn the retaining holes in the differential carrier into an "egg shaped" pattern. Every time the car was accelerated, this shaft was "rocking" in the elongated hole, making the noise. I replaced the carrier, and the noise was gone.
Now I know that my wife didn't beat on the car, but unfortunately, she wanted to put the car away, for several winters, and she entrusted a "friend of a friend" to keep the car in his storage building. He'd take the car from her in November, and bring it back in March. I think, however, the car got a "hard ride" back an forth from storage, which caused this damage.
the thick hockey puck looking one may look fine but the top one is where I have seen them fail mostly.On an automatic car...you can get in the car and while HOLDING THE BRAKE with your foot...crank the engine and put the car in gear and have someone look at that area and then put it in reverse and then back in drive and watch that area. IF it is bad...they will see it move.
Also look at the rear transmission mount....along with the previously suggested Universal joints.
I have had few cars make noise and it be the rubber bushing at the lower shock mount area on the shock absorber itself.
LASTLY and it can happen and I have seen it also is that the rubber in your trailing arm bushing is shot and the entire trailing arm can move front to rear.
DUB
