70 clock knob sleeve - Alan?
Old Jan 26, 2017 | 06:19 PM
Duntov's Avatar
Duntov
Default 70 clock **** sleeve - Alan?
I figure this is something Alan has info on. The clock **** in my 70 moves around. The assembly manual shows 3928775 as a sleeve, but doesn't give specs.
I found, http://www.ebay.com/itm/1968-1976-Co...pV5cA9&vxp=mtr, on eBay. It looks like vacuum hose that is cut to some length. Any insight on what it actually should be.
Old Jan 26, 2017 | 06:56 PM
Alan 71's Avatar
Alan 71
Hi D,
The shaft the clock reset **** mounts on is much smaller in diameter than the diameter of the hole for it in the gauge cluster bezel.
A short sleeve was slipped on the shaft before the **** was tightened and pushed most of the way into the hole.
Think of a short piece of soda straw, black, smaller in diameter, and thicker walls.
Regards,
Alan
Old Jan 27, 2017 | 07:02 AM
Easy Mike's Avatar
Easy Mike
Cruise-In II Veteran
Originally Posted by Alan 71
...Think of a short piece of soda straw, black, smaller in diameter, and thicker walls...
Yep. It's not much. You've probably got something lying on the work bench which would beat the $10 eBay price.
Old Jan 28, 2017 | 12:39 PM
Willcox Corvette's Avatar
0Willcox Corvette
Former Vendor
St. Jude Donor '08-'09-'10-'11-'12-'13-'14-'15
Heat shrink tubing works great as a replacement for the clock **** sleeve. You can find it in many sizes at your local parts stores. We have some here but I don't know what the size is but it's just a tiny bit smaller than the hole in the lens. (you don't need to heat it either)
-Willcox
Old Jan 28, 2017 | 01:13 PM
Hammerhead Fred's Avatar
Hammerhead Fred
Short length of a black coffee stir/straw and/or bar straw works as well.
Old Jan 29, 2017 | 03:34 PM
7T1vette's Avatar
7T1vette
That would be a "McGyver" fix, rather than a "Bubba". It would be a decent approximation of the original part.
Old Jan 29, 2017 | 06:46 PM
DUB's Avatar
DUB
I have always thought that this sleeve was made out of a much more rigid plastic....or at least every one I have come across is rigid and can not be bent by using my fingers. When I need one I use the somewhat hard plastic vacuum tubing used on the newer Corvettes.
DUB
Old Jan 30, 2017 | 10:09 AM
7T1vette's Avatar
7T1vette
The original pieces were a hard plastic that was vacuum-chromed, I believe. But, any kind of "substitute" would be better than just having that smaller diameter stem flopping around. If the 'stir stick' is the right size to fit the hole in the lens, that would be a pretty close approximation of the tube (except that it would be black).
P.S. Actually, there is an NOS box with **** and stem cover being advertised on eBay right now...$14.95.
Old Jan 30, 2017 | 11:07 AM
Alan 71's Avatar
Alan 71
Hi,
While the nut and tubular slotted nut were chrome plated the sleeve that is added to surround the clock's stem was black plastic.
Regards,
Alan
Old Jan 30, 2017 | 06:54 PM
DUB's Avatar
DUB
Thanks for the photo Alan. I was going to post a photo but it is pointless with yours being posted. I thought it was a rigid plastic. I have never seen these tubes be flexible like a rubber vacuum hose.
DUB
Old Jan 31, 2017 | 02:19 AM
7T1vette's Avatar
7T1vette
Although....I don't see why the flexible tubing wouldn't work. There's no stresses placed on that 'tube' during resetting of the clock. A substitute part just wouldn't last as long as the original.
{With that said, the rigid part would still be a better choice, I think.}
To 70 clock knob sleeve - Alan?
