Rear leaf spring uneven gap
Old Mar 11, 2017 | 12:55 PM
apn003's Avatar
apn003
4th Gear
Default Rear leaf spring uneven gap
I am hoping someone out there already experienced this and has a fix. I bought the stock replacement steel spring SKU 25-159750-1 from Corvette Store Online. Used the 8" bolt package to mount. However, once I got the tires on (new), I find I have a 4" gap tire to fender well on the drivers side, and a 5 1/2" gap on the passenger side. Any ideas how to fix this? I have the bolts tightened in about 1 inch. Not sure if just tightening in one of the bolts will work, or if that will produce uneven tension on the spring. Any ideas?
Old Mar 11, 2017 | 01:39 PM
Alan 71's Avatar
Alan 71
Hi apn,
I see this is referred to as a "Stage 3" Spring.
Do you know what it's characteristics are compared to the spring you removed from the car?
Do you think the spring on your car the original?
What were you seeing that made you think you needed a new spring?
It would be good to know what year your car is and what other suspension components you may have replaced… bushings, shocks, etc..
Regards,
Alan
Old Mar 11, 2017 | 01:41 PM
resdoggie's Avatar
resdoggie
Had a 1976 L-82, 4-sp
Royal Canadian Navy
Have you taken the car for a scoot around the block to let the rear suspension settle?
Old Mar 11, 2017 | 06:54 PM
DUB's Avatar
DUB
Drive it and do not get so caught up at this time on the measurement.
DUB
To Rear leaf spring uneven gap
