Steering column part
Old Jul 28, 2017 | 12:33 PM
marc9889's Avatar
marc9889
Default Steering column part
Sirs,
I have a '72 with a 4 speed Muncie. Can anyone tell me what this part is called, and did manual transmission cars come from the factory with this on the column? On my car, it rotates around the column freely, which causes issues when turning the ignition switch. What does it connect to on a manual transmission car?
Old Jul 28, 2017 | 02:42 PM
Alan 71's Avatar
Alan 71
Hi Marc,
The lever is part of the reverse ignition switch lock and steering wheel lock.
There is a cable that runs from that lever at the firewall to the reverse lever on the transmission.
When functioning properly, moving the shifter to reverse moves the cable which locks the steering wheel from being turned, and, allows the key to be removed from the ignition switch.
All 4 speed cars had this feature. (Automatic transmission cars had a similar system.)
Here're a couple of photos.
Regards,
Alan
Shifting into reverse moves the cable which pushes the lever up. The steering wheel locks and the key can be removed.
The column is in the 'locked' position in this photo.
Here's the cable connection at the transmission reverse lever.
Old Jul 28, 2017 | 03:09 PM
marc9889's Avatar
marc9889
That's exactly what I needed. Thanks Alan!
Old Jul 28, 2017 | 03:34 PM
Willcox Corvette's Avatar
0Willcox Corvette
Former Vendor
St. Jude Donor '08-'09-'10-'11-'12-'13-'14-'15
If you don't want to replace the cable, I've seen customers wire them in place as a temporary fix.
Willcox
Old Jul 28, 2017 | 03:36 PM
marc9889's Avatar
marc9889
Willcox
Mine is wired to hold it in place at the moment. Do you guys sell that cable, clips, etc?
Old Jul 28, 2017 | 05:51 PM
DUB's Avatar
DUB
Just to give you a 'heads-up'
IF you are planning on putting that cable in do not be surprised that the cable end that is clipped too the bracket that is bolted to your transmission is going to be a TOTAL PAIN.
When I do them I remove the bracket off the transmission and attach the cable to it and then are-attach the cable bracket to the transmission....The reason is ...that cable is going to FIGHT you due to it lacks flexibility.
DUB
Old Jul 28, 2017 | 06:08 PM
3X2's Avatar
3X2
Mine has been wire tied up for over 40 years without an issue.
Old Jul 29, 2017 | 10:08 AM
0Willcox Corvette
Former Vendor
Transmission Control Interlock Cable Bracket. 4 Speed 69-73
https://willcoxcorvette.com/corvette...-4-speed-69-73
Transmission Control Interlock Cable Bracket. 4 Speed 69-75
https://willcoxcorvette.com/corvette...-4-speed-69-75
Transmission Control Interlock Cable 4 speed. 69-76 replacement
https://willcoxcorvette.com/corvette...eed-69-76-repl
Transmission Control Interlock Cable 4 speed. 69-76 Correct
https://willcoxcorvette.com/corvette...-76-repl-26672
Park Brake Cable / Trans Lock Cable Retainer Clip 65-82
https://willcoxcorvette.com/corvette...ner-clip-65-82
The replacement cables work just fine too, unless you are going NCRS.
Willcox
Old Aug 3, 2017 | 01:47 PM
marc9889's Avatar
marc9889
Willcox
One more thing - You might consider putting together a hardware kit for people who want to eliminate the cable. Just a "whatever-it-takes to keep the lever in the right position kit". My result was a good bit less elegant that what you could probably offer.
Old Aug 3, 2017 | 03:46 PM
TimAT's Avatar
TimAT
Removed the cable, rotated the lever to the "lock" position, hit it with a small tack weld, and cut the lever off. End of problems.
Old Aug 3, 2017 | 06:40 PM
DUB's Avatar
DUB
YEP...keeping the tab in the correct position does not take a lot of imagination to make it work. I will have it secured in place in less time than it would to call and order a 'part' to by-pass it. I do not even take the time to cut off the lever.
DUB
Old Aug 4, 2017 | 06:37 AM
mrvette's Avatar
mrvette
Some 22 years ago, up north yet, I installed a late shark TT wheel/column assy instead of the stock fixed bus driver wheel....and so I also removed that interlock lever/tube assy, but now I wonder if maybe I can find the parts to put it back, because of grandsons.....but I suspect that after 22 years, anyone wanna BET I can't find those damn PARTS?? much less that it's been changed from a 4 speed to a 200 4r..... guess I need go junkyarding..look at how other vehicles got the problem solved.....
Old Aug 4, 2017 | 06:46 PM
DUB's Avatar
DUB
Two words...LINE LOCK. The rear wheels will lock down and the car will not move if that is your concern if they take the car out of gear.
Might be a bit easier than totally taking a steering column apart to but the lever and tube back in.
DUB
Old Sep 16, 2017 | 09:58 AM
ku4sd's Avatar
ku4sd
4th Gear
I have a question about this lever too. I just purchased my 74 about 3 weeks ago and I am trying to fix the things I find. I replaced my interlock cable yesterday because I noticed it was severely kinked. I now know why it was kinked, the lever will not go all the way to the 1 O'clock position. If I would force the shift lever from drive to neutral, reverse, or Park, I would ruin the new cable. It is disconnected on the steering column end right now, but it is hard to get the key out of the ignition, and it won't go into accessory. The lever turns very free, but it sounds like it is hitting a hard stop somewhere at the base of the steering column on the inside of the vehicle and it won't go from 3 to 1 o'clock. Any guesses what is causing this?
Old Sep 16, 2017 | 11:41 AM
marc9889's Avatar
marc9889
On my column, the lever travel is limited by the housing itself. Using your left hand (sitting in the car), grab the column (nearest the dash) and turn it counter clockwise as far as it will go. With your right hand, turn the ignition switch to the accessory position. If it doesn't turn to accy normally, then the issue probably isn't related to the lever or cable.
Old Sep 16, 2017 | 12:29 PM
ku4sd's Avatar
ku4sd
4th Gear
Thanks, but I did look at that, the housing will limit it in the other direction. There it hits long before the housing stops it.
Old Sep 16, 2017 | 06:46 PM
DUB's Avatar
DUB
'ku4sd'
IF the lever that your interlock cable attaches to can move relatively free...but not go all the way. ( if I read what you wrote correctly) Then you do have an issue internally in the column.
The column would have to be taken apart so you can watch how the lower portion of your column rotates ( that is hidden by that plastic cupped shield) and see what is causing the inability of the lock cylinder to be able to turn...which can be due to the toothed slide on the left side of the column on the inside.
I have had these columns be where the lever was really hard to move but still work..and it can be due the grease gets super hard and not allow that portion of the tube to smoothly rotate.
I am assuming that your column is correct for your year model....and I am assuming that it is a tele-tilt column.
DUB
To Steering column part
Old Sep 16, 2017 | 06:55 PM
ku4sd's Avatar
ku4sd
4th Gear
Originally Posted by DUB
'ku4sd'
DUB
I think that is what I am going to do. Which part # in the picture in the first post of this thread is the toothed slide?
Old Sep 17, 2017 | 01:51 AM
san's Avatar
san
Originally Posted by Alan 71
Hi Marc,
Regards,
Alan
So when you put the car in reverse the steering locks??? Is that what you just said???? Thats going to be tricky driving backwards...hahahaha
MaYbe say, with car in reverse it allows the key to be removed, which is how the steering locks.
Old Sep 17, 2017 | 05:32 PM
DUB's Avatar
DUB
I do not know what you mean by 'toothed side'???
DUB
