Cooling issue
The engine is creating too much heat for the cooling system.
I.E., Retarded timing, too lean, improper lubrication. (Friction).
The cooling system cannot handle the heat generated. I.E.,
Wrong pump, stat, fan, radiator,coolant,blockage, etc.
It CAN be both, but usually one or the other. 3 miles is is too quick. 200* is expected with that stat. 235* is the cusp of damage.
If I lived close, I'd shoot over and find it in a day.
Hell the way it’s going I’m about to buy you a plane ticket. I did get him to admit he bought the radiator for a 78 Vet with no consideration for the 383. I told him those engines had less than 200 hp off the production line and he was very quiet. Said the fans are just universal fit 12” fans. I’m going to look at the invoices tomorrow and check into radiator solutions. I’m bleeding money on these guys and I need to see an end solution. Thanks again.
A ticket would be enticing, but there are lots of members close to you that can do this.
There are two types of fan systems, #1 the stock system with a shroud, fan clutch, and engine driven fan. With this system a shroud and seals are a must. #2 is the electric fans and here you do not need a shroud or seals if it is designed correctly. The basic starting point is 2000 cfm of air flow and 70% core coverage. Not sure you have that.
I see you have a serpentine belt system and that can cause a couple issues. The water pump runs backwards rotation and sometimes they have smaller pulley that overdrives the pump. Too much flow can be a problem. 235 degrees in three miles is more than a seal or drilling holes in a stat.
You may or may not need a new system, but if I was asked to suggest a unit (with electric fans) I would use :
Model: 4139077A (Natural/Auto)
Webpage
Your radiator looks fine. There is nothing super special about your setup. You don't need to be buying a bunch of stuff like a radiator or fans yet. I suggest you stop throwing money at it and go through the suggested checks.
Webpage
I appreciate all the help everyone has volunteered on this site.
Regards. Dianne
PS. Penelope is my 78
1) Took a look at your photos. Visually, the water pump looks like the Edelbrock reverse rotation for small block chevy.
2) Most aftermarket serpentine systems are setup with a “performance” ratio that actually slows down the water pump to reduce horsepower loss. I have March serpentine on my big block and had to get a larger crank pulley to speed up the water pump. That, in conjunction with the big spoiler helped cure low speed cooling for my 496 big block.
3) The seals are absolutely critical to getting all the air to flow through your radiator.
1. It seems as if the radiator support is very far from the radiator. The gap is huge. Even without seals. Is there a radiator/support/bracket mismatch?
2. Lower hose. Why the universal fit hose? A Corvette hose with the internal support spring should hook up no problem...if the radiator has the proper outlet configuration. is there a sroing inside the lower hose.
3. Squeeze the upper and lower hoses when its running.. If the water pump is spinning backwards the lower hose will be very hard.
Fix know mechanical issues first. Radiator to shroud sealing? lower hose? Correct direction water pump etc. Pick a starting point and follow the system to locate any trouble spots. Ex. start at the thermostat housing... correct housing? Correct-stat? correct upper hose? Radiator full of fluid? Correct cap? Correct lower hose.? Correct water pump? Heater hoses oriented correctly?
i called March and with the help of Price he confirmed they sent the reverse rotation water pump with my kit parts. I told him about the overheating and he suggested thermostat much lower like 160 which several of you have mentioned and might check whether the water is moving too fast. He said to look for Morosso resistors to slow it down. I think I saw this comment elsewhere. So waiting on parts and ready to ride.
Dianne, splitting all this into an old and new thread is killing me. Pick one.
1) Took a look at your photos. Visually, the water pump looks like the Edelbrock reverse flow for small block chevy.
I don't mean to blow my own horn but solving Corvette cooling issues is all I have done for the last twenty years. Nobody can match the number of clients I have worked with on this issue. Why someone would consult a carpenter, truck driver, and school teacher about a surgical procedure is a mystery to me.
Q: Did anyone ever confirm your gauge reading with an IR gun?
Many replacement temperature sending units are not correct and read much higher than the actual temperature. Many times people claim they are running hot when they are not because they assumed the gauge was correct. Most of them do not find this out until they spent a whole bunch of money trying to solve a problem they don't have.
