Cooling issue
Old Jan 20, 2019 | 10:21 AM
  #41
carriljc's Avatar
carriljc
Penelopegirl - hopefully your cookie sheet shroud plan works. However, if it does not, then take a look at this thread. https://www.corvetteforum.com/forums...post1587817315
Per your discussion I would not expect you to enjoy wandering around a pick-a-part (I do ) and these mid 90's Camaro fan assemblies are all put together with a shroud. In the post above F22 even shows dimensions with a tape measure. Great post with F22.
Old Jan 20, 2019 | 11:33 AM
  #42
OldCarBum's Avatar
OldCarBum
Call Dewitts Radiator, they are a forum vendor.
Usually Tom DeWitt will chime in when he sees threads regarding cooling and radiators.
You might just send him a PM.
I researched cooling through many manufacturers and found Dewitt’s had by far the best quality radiator in the business.
They also advertise their radiators are “direct fit” with no modifications to the vehicle needed.
Everything I have read shows this is true.
Their web site is great and I would suggest looking at their direct fit, aluminum, HP, combo unit for your 383.
Two rows of 1.25” tubes, with no epoxy, and the combo kit comes with the dual spal fans, all wiring, relays, and the shroud.
I just ordered my combo kit for my 496 build and I believe their 15% off sale is still running which knocked over $200.00 off my order.
This set up should be more than adequate to cool you build.
In your photos it looks like you have an auto trans which is also additional heat into your cooling system because the trans fluid is cooled in the side tank in the radiator.
If I’m correct and you do have an auto trans make sure you order the correct radiator.
The other option is if you want the natural finish or painted black from their factory.
I opted for the natural finish as I think it just looks cool over the black and the natural finish is cheaper.
Old Jan 20, 2019 | 12:37 PM
  #43
chevymans 77's Avatar
chevymans 77
St. Jude Donor '05-'06,'11,'13-'14,'16,'18,'19,'24, '25
Post #15 shows the foam core support to hood seal along with the seal between the top of the radiator and the core support.
Neal
Old Jan 20, 2019 | 12:45 PM
  #44
chevymans 77
Do a search on google using "C3 corvette radiator seals", look in images and a large number of pics will show the seals and them being installed.
Neal
Old Jan 20, 2019 | 12:49 PM
  #45
chevymans 77
https://www.corvetteforum.com/forums...uide-pics.html
look through this thread, while not the exact same year the idea is the same as to the seals.
Neal
Old Jan 20, 2019 | 01:00 PM
  #46
SteveG75's Avatar
SteveG75
Radiator seals here.
https://www.ecklerscorvette.com/cool...ort-seals.html
Since you are in SE Florida, recommend a drive up to Titusville and talk directly to folks at Ecklers.
Old Jan 20, 2019 | 01:30 PM
  #47
Doug1's Avatar
Doug1
Drive up in the 78 that has cooling issues? Lol, it has been cold here in FL for awhile now so the car will probably be ok.
Hey Penelope, have you taken the thermostat out yet? Very simple job, first get a gasket from auto parts store for $4, take the two bolts off on the housing, remove thermostat and put in garbage, make sure both sides of metal are clean, put housing with new gasket on and tighten the 2 bolts. 10 minute job.
Old Jan 20, 2019 | 04:04 PM
  #48
HeadsU.P.'s Avatar
HeadsU.P.
The O.P. has a chrome T-stat housing. A $4 gasket won't cut it. Needs the $25 silicone gasket.
Old Jan 20, 2019 | 04:08 PM
  #49
carriljc's Avatar
carriljc
O.P. would be better off with a cast iron housing and a regular gasket. I sh*t-canned my chrome POS and went back to cast iron when I my chrome housing started leaking.
Old Jan 20, 2019 | 04:23 PM
  #50
Doug1's Avatar
Doug1
I've got the cheap chrome housing, the gasket has worked ok for me.
Old Jan 20, 2019 | 04:25 PM
  #51
Doug1's Avatar
Doug1
How long did it last you before it started leaking? Are you saying it rusted out and got a small hole?
Old Jan 20, 2019 | 04:32 PM
  #52
cv67's Avatar
cv67
St. Jude Donor '05
Mine seeped from day 1, removed the oring and filled it in, used various gaskets no dice. Finally after sitting for a few yrs its corroded itself shut.
They warp when you tighten them who wants to risk a motor to that? Buddys oring failed on his, cooked an 8k motor his 2nd day out.
Summit may still sell the cast aluminum housing that goes on their crate motors. Its plenty strong and $10. Smooth finish so polishes up real easy if you like bling.
Throw that cheap stuff in the trash. Its not if, its when.
Old Jan 20, 2019 | 07:17 PM
  #53
carriljc's Avatar
carriljc
I don't think that it lasted one year (1). Never felt right, and I tried to reseal it, finally just sh*t-canned it and got a cast iron puppy. Never leaked again. My new engine looks to have a cast aluminum unit which doesn't leak either. I'll never get another chrome P.O.S.
Old Jan 20, 2019 | 07:37 PM
  #54
Penelopegirl's Avatar
Penelopegirl
Yes I do have auto. I think I’m days away from dumping what I have and starting over. I’m just trying to look at what I have and cost to replace right now. Thanks much.
Old Jan 20, 2019 | 07:44 PM
  #55
Penelopegirl
I just realized they’re only 110 miles away but my Penelope sure ain’t going there. She’s overheating 3 miles from home.
Old Jan 20, 2019 | 08:11 PM
  #56
Big2Bird's Avatar
Big2Bird
3 miles? Naw, this sounds more like something stupid easy.
Ignition retarded
Carb is lean.
Water pump is incorrect rotation
Thermostat is bad.
Bad hose
Something along those lines.....
Old Jan 20, 2019 | 08:21 PM
  #57
SteveG75's Avatar
SteveG75
Honestly, if you are overheating in three miles when it only 60 degrees out, I would honestly consider the possibility that you have a standard rotation water pump with the reverse rotation serpentine setup.
To Cooling issue
Old Jan 20, 2019 | 08:22 PM
  #58
Penelopegirl
Default Runs hot
Ignition retarded
Carb is lean.
Thermostat is bad.
Bad hose
Ok so I exaggerate just a little but she is running way too hot. New thermostat 195 he tells me. Fans are coming on but don’t seem to bring the temp down. After the new thermostat I drove her 3-4 miles test run went up to 200 stayed there so I headed home was 230 when I got home. That’s too hot for me. The fans seem to run all the time now so what’s going to happen when it really gets hot. I’m afraid they threw parts at her buying for a 78 Corvette with no consideration for the 383 so I know this is going to get worse as weather heats up.
Old Jan 20, 2019 | 08:30 PM
  #59
Penelopegirl
Default Water pump
How do I find that out for sure? I know it has the March pulley system so how do I find out about the pump?
Old Jan 20, 2019 | 08:33 PM
  #60
Big2Bird's Avatar
Big2Bird
Do you have the receipts? Can you look up the pump used?
