I’ve done a speed to rpm test. So I guessing my tach could be out a bit. My tyres are about 26.75” at 60mph I’m at 2750rpm , 65mph I’m at 3000rpm 80 I’m at 3700. Is there any 4 speed bolt in box that could give me better highway speed with my 3.08 rear?
Just as as reference again, OEM stock 3.70 geared L-82 4 speed and auto (1:1 final gear) should be exactly 2860 RPM's @ 60 MPH with a 27 inch tire (255/60/15).
I have been asking for years, why can't someone make 3rd gear in my 4 speed 1:1, and add a 4th gear overdrive like .60:1 that would fit in the ST-10 box? My engine could easily do with 3rd gear being 1:1 with zero issues especially with the HP/Torque this engine makes now.
Could you imagine what would happen if someone sold the gears alone or offered to retrofit the 4 speed box for reasonable money ($1,000?). The 5/6 speed conversions would dry up overnight........
No.
I assume you are not interested in the $3k-5k bolt in 5 speed solutions offered in the aftermarket.
For bolt-in overdrive there are essentially two options. 1) find the super rare T50 5 speed from the Monza. Considering they are made of glass and will break when used with any engine over a 3 inch stroke and there are no replacement parts available no one in their right mind would use it. 2) have your current 4 speed box rebuilt using a steeper 1st gear. Then you can then have a 2.xx rear gear installed in the diff so with your 1:1 4th gear the revs drop.
There is nothing around that will bolt in inexpensively. A WCT5 is really the closest and is the way to go if trying to source from a salvage yard.
Of course the least expensive route is to use larger diameter tires.
Oh ok, I guess the wct5 is really my only option. The reason I was asking about the bolt in 4speed is because I’m in the UK, so sourcing a 5spd and getting parts will be a bit difficult. Thanks a bunch for explaining my options. I will probably do the wct5. So The most straight forward fit would be a gm 26spline v8 transmission, what gearing would suit my final drive?
Oh ok, I guess the t5 is really my only option. The reason I was asking about the bolt in 4speed is because I’m in the UK, so sourcing a 5spd and getting parts will be a bit difficult. Thanks a bunch for explaining my options. I will probably do the wct5. So The most straight forward fit would be a gm 26spline v8 transmission, what gearing would suit my final drive?
