Steering box question
Old Feb 4, 2018 | 11:30 PM
TheGreek!'s Avatar
TheGreek!
Default Steering box question
Is there a difference between C3 manual steering boxes and power steering boxes besides the pitman arm? Did they have different ratios (amount of turns lock to lock) or are they the same box?
Old Feb 4, 2018 | 11:57 PM
7T1vette's Avatar
7T1vette
Steering box is the same (at least it was in 1971; 16:1 ratio).
Old Feb 5, 2018 | 12:28 AM
Bikespace's Avatar
Bikespace
Steering box is the same. The Pitman arm has the same effective length, but a different shape. The turning ratio difference comes from a second set of holes drilled in the steering arms of cars made when manual steering was available.
Here's a good thread:
https://www.corvetteforum.com/forums...tman-arms.html
Old Feb 5, 2018 | 07:03 AM
Alan 71's Avatar
Alan 71
Hi TG,
Here's an example of the steering arm that was used with both standard and power steering.
On cars with STANDARD steering the tie-rod was in the REAR hole while on cars with POWER steering the tie-rod was in the FORWARD hole...as Bike described.
Typically steering arms used on cars with power steering have a large 'rivet' like plug in the rear holes.
Regards,
Alan
A steering arm with the 'plug' in place. So an arm from a car with power steering.
Old Feb 5, 2018 | 09:36 AM
Alan 71's Avatar
Alan 71
Hi r,
Was it because power steering became standard at some point?
Pitman or arm-steering arm?
Regards,
Alan
Old Feb 5, 2018 | 10:21 AM
redvetracr's Avatar
redvetracr
Originally Posted by revitup
Pitman arms with the two holes were discontinued at some point. There's only one hole in the '77 pitman arm.
when did a pitman arm have two holes?
Old Feb 5, 2018 | 10:24 AM
Bikespace's Avatar
Bikespace
Originally Posted by Alan 71
Hi r,
Regards,
Alan
I think power steering became standard in 1977. My '79 and '80 both have the single (rearward) hole in the steering arms. Given the way GM worked, I bet there are examples of '76 cars with one hole, or '77 cars with two holes, or even both.
All Pitman arms have two holes (one for the steering box, one for mating to the control rod). No Pitman arms had extra holes, just a different shape. Here's the filthy takeoff power steering pitman arm, along with the manual steering arm ready to go in. Not the best picture, but they are shaped different. Both have two holes. All idler arms are the same, too, 63-82, power and manual, so the important dimension is the same.
Old Feb 5, 2018 | 10:35 AM
Big2Bird's Avatar
Big2Bird
Beat me to it.
Old Feb 5, 2018 | 02:09 PM
TheGreek!'s Avatar
TheGreek!
Thanks for the replies, I guess the boxes are the same after all. Not surprisingly, my everything-is-worn-out-on-it '69 needs a new box because the one in it right now is worn out to the point that the slop in it can't be adjusted out with the screw on top of the box. With that being said, who has the best deal on a rebuilt steering box?
Old Feb 5, 2018 | 03:18 PM
Bikespace's Avatar
Bikespace
Most of the vendors have steering boxes, new and rebuilt, even Jegs has them.
That said, if I didn't want to go the Borgeson power steering box route, and I didn't want to rebuild the stock box myself, I'd PM GTR1999 and ask if he can spec a rebuilt box for you.
https://www.corvetteforum.com/forums...1-gtr1999.html
Old Feb 5, 2018 | 05:27 PM
Alan 71's Avatar
Alan 71
Hi TG,
You might want to consider having Bairs Corvettes rebuild your existing steering box.
They're in Linesville, Pa., and have a web site.
There seems to be some confusion about what was being discussed in the thread.... steering arms/pitman arm.
My comments and photos were about the STEERING arms.
Regards,
Alan
Old Feb 5, 2018 | 07:04 PM
DUB's Avatar
DUB
***JOKING****
They always have had two holes One to put on the gear box splined shaft..and the hole on the other end for the power steering control valve or manual steering taper stud.
DUB
Old Feb 5, 2018 | 07:09 PM
DUB's Avatar
DUB
I would highly advise you contacting GTR1999 here on the forum when it comes to your gear box needs. Or at least consider it.
There are those that know about steering gear boxes/differentials...and then there are those who KNOW about gear boxes. GTR1999 (Gary) KNOWS gear boxes. Make not mistake about it!
DUB
To Steering box question
