More Brake Woes
M/C needs to be bench-bled; repairs made to lines, etc; system needs to be bled in specific order [I prefer from 'nearest-to-farthest' sequence].
You eventually got to this process. Glad it is finally tight!
Glad you got it all fixed
Test drive next...
And no, brake fluid does not flow out when you change from the switch to the tool and back again. Unless something is severly wrong with the Prop Valve.
You can see the five brakeline ports on the Prop Valve. Two lines coming in from the master, and three lines going out to the calipers. And you can clearly see the big spring on the front side pushing on the piston. The two holes are for the bolts to the frame and the right side port in the photo is for line to the rear brakes.
Hard pedal and no light.
I'm officially calling this job FINISHED!
The culprits in this case were VERY small leaks. One at a LR caliper seal. Also a leak at the combination valve where the crossover line attaches. These were allowing air into the system and causing a pedal that went to the floor.
No amount of bleeding would correct the problem until the leaks were fixed.
Thanks to all who responded. You guys are awesome.
On to the next project...
2 Quick questions:
1) How did you diagnose the leak at the junction block?
2) Did your brakes slowly sink to the floor all the way? Mine is soft then seems solid like the last 1".
This was a great thread that is going to help a lot of people!!!
2 Quick questions:
I replaced the combination valve. I figured it was 37 years old so why not. The fitting from the crossover line to the valve was simply seeping. I mistook the very small drip on the driveway to be from the master cylinder. The valve is almost directly under the mc. So I tightened the fitting more. More of a leak developed then. I could probably have saved myself from replacing the brake line if I knew about the copper washers that I posted above.
2.
Yes the pedal would be soft and go to the floor.
Thanks for the kudos on the thread. I hope it does help some people out with the pesky C3 brake system.
scottjamison - The pedal feeling a bit mushy up top but solid at the bottom is a classic sign that you have air in part of the system. You should have a dual piston Master cylinder - they are the norm - and their purpose in life is to make sure that if you have a failure in part of the braking system - you won't lose ALL your braking power. When one piston in the master cylinder moves quite easily - the other piston basically operates the other half of the braking system. So - do a full bleed and see how it feels - (I'd start with bleeding the fronts but thats just a partially educated guess as to where the problem lies...) of course - if there is some air in the system - you have to figure out how it got in there - and that typically means a leaky seal or a bad line somewhere.... so look for brake fluid seepage/ drips while bleeding....
Yes I just replaced the ENTIRE system as part of my upgrade and have a dual MC. We have bled it several times, so now I am going to start looking for tiny leaks ala Street Rat. I did notice that when the MC cover is off and I pump the pedal, the front squirts up in the air a little but the back does not. I don't know if that means anything, I just noticed it.
This weekend I will back it up my driveway just to give a final incline MC bleed (I have a steep assed driveway) then I cleaned my garage floor really good today while it is getting the sweet exhaust system built for it and I will start looking for drips. I also want to try resetting the porportioning valve just in case. I already have the tool.
