Header side pipe inserts
Old Jan 14, 2019 | 06:21 PM
Red Hot 71's Avatar
Red Hot 71
Default Header side pipe inserts
Can anyone out there tell me how the resonator inserts are installed. Do they just lay in the side pipe? My OBX header side pipes are not resonated because they were out of that type. Thought it would be easy to do. I have tried Google & all I keep getting is how to install the side pipes. One site told me I had to weld them in place. Can a member w/common sense please help me?
Old Jan 14, 2019 | 06:56 PM
flyeri's Avatar
flyeri
Look at THIS POST and go down to #21 and #24 for my solution to securing the insert in the side pipe. Your side pipe should slide about 4 inches up onto the header. Hope this helps.
Old Jan 14, 2019 | 07:33 PM
DaveL82's Avatar
DaveL82
I used some from Classic Chambered Exhaust a few years back and they slipped into the tube with a slightly snug fit if this is what you're looking for. Never welded into place in case I need to remove
Old Jan 14, 2019 | 08:01 PM
stingr69's Avatar
stingr69
Side pipe inserts typically just drop in to the side tubes before you attach them to the discharge ends of the header collector, . STS makes some good ones. Not cheap but they are popular around here.
Old Jan 15, 2019 | 09:34 AM
resdoggie's Avatar
resdoggie
Had a 1976 L-82, 4-sp
Royal Canadian Navy
Yep, my Maxflow inserts just lay in there.
Old Jan 15, 2019 | 10:36 AM
jim-81's Avatar
jim-81
Not sure how the OBX inserts attach but when I had Doug's inserts, they just drop in and they wedge themselves in, you just tap them in with a wood block. When it came time to remove them several months later they came back out again with a little tapping with a wood block, or maybe I just tapped the sidepipe on wood. The STS baffles are different in that they have two tabs with weld nuts. You match drill the sidepipe to those holes, then slide in the baffle, then bolt them in using red Loctite.
To Header side pipe inserts
