Old School SHP Engine Build
GM never used flat washers under the prevailing torque windage tray nuts but I have added some. If you do not use washers, the nuts will tear metal shards from the sheet metal windage tray when you tighten them up. Just can't live with that.
The nice 8" damper (balancer) has a very typical wear groove on the nose from riding on the lip of the front cover seal. Not a big deal but it does need to have a sleeve pressed on to repair it good as new.
My wife has left for work so I sneaked into her sewing basket and pilfered her cloth measuring tape. The damper measured out to be 25.25" in circumference. If you divide that measurement by 10 you will get 2.525" which is actually 36 degrees on the damper.
(360 degrees/10 = 36 degrees)
Measure to the right of the "0" mark on the damper 2.525" and place a mark there.
You can use this new mark to set your timing at 36 degrees at the top of the advance curve. Poor mans degreed damper. If you have the smaller damper, the method is the same but the dimensions are different.
Its starting to look like an engine!
Glass burette. Bought a cheap one online from a scientific supply house years ago.
Grease seals the plexiglass to the head. Water is added through the hole near the top of the intake valve.
Just an observation and am not bashing in any way......
BTW.....for $6 more dollars you can use a stud to hold on the oil pump and for free you can chamfer the oil port on the main cap for less turbulence at high RPM. I love the stud because it leaves NO way to pull the threads out of the main cap when torquing the bolt....which on old stuff I have seen many times.
Jebby
It's kind of a choice between the devil you know vs the devil you have not met. This oil pump shaft will never see much more than 3500 RPM on a good day...it rotates at half crank speed. The nylon sleeve has been used in literally MILLIONS of GM engines and they have never been failure prone - Even when used in the screaming DZ 302. The top of the shaft fits inside the recess in the bottom of the distributor gear and the other end is held in place by the oil pump and sleeve. Its not going anywhere.
I generally tend to dislike and avoid cheap aftermarket replacement parts because they frequently disappoint me. So much off-shore manufactured crap out there. I know GM spent a LOT of time and money designing and manufacturing these pieces for many years so I sleep well at night knowing the work was done and the parts will fit and function as intended. No pins to fall out, no cheap plating to flake off, No questionable metallurgy with potential for excess wear.... If it works, I don't want to spend money to change it for something that might work and toss out the one that does work. Just how I like to roll.
So the wider gears makes it a higher volume and pressure pump. My present stock 4 bolt higher nickel motor also uses drilled out morroso oil restrictors the make it a priority mains oiling system
https://www.chevydiy.com/1955-1996-c...manual-part-9/
These are the measurements I took before final assembling of the heads.
The chambers are cut for better flow at the factory on 2.02" x 1.60" SHP heads. Never hear anyone tell you how many cc's of metal is removed when the factory cut the chambers around the periphery of the intake valve.
A good amount of metal was hogged out.
The best identity of the stock parts, is a Chevrolet Parts Number book that I have to go find! It is a series called By The Numbers! I think it is 65-69 and then they have a 70-75, and a 60-64 edition and I think one more. The 65-69 covers the LT-1 also, if I am correct. Will have to go look, but I also have the 70-75 book too!
I have X and O rods, floaters, presses, and both the 91s and the 83s in the 4340 6 inch! I see the X rods called pink rods, but those aren’t! The pinks got shot peened and had 3/8 bolts.
So for a cost of less than $20.....you can use a premium steel collar shaft, an ARP stud on the oil pump and port the inlet. These are accepted bread and butter parts and mods....and IMHO kinda foolish not to do as they are proven.
BTW....have you ever primed the pump with a drill pre-startup? Ever notice how much drag the drill gets when the oil finally starts pressurizing? 1hp per 1000RPM is what the shaft requires.
Too me that is a lot.....
I don't care what GM ran in their 302 DZ......if something can be made obviously better for next to nothing then why not do it?
Ok.....carry on
Jebby
Anyway...nice build.
Jebby
Jebby
No grinding initially. Maybe after the build is shaken out and I get tired of it.
Jebby
You can buy cam Valley vent tubes that eliminates the windage of all the oil pouring down on the crank
Was doing two things at once....
Jebby
Ok.....carry on
Jebby
But when you think that GM made millions correct is not good. Corporate design is with planned failures. For instance, I had a 76 with the cheap junk nylon timing gear and it wore away and finally broke. The cam chain was also such cheap junk that it was all strethed out. GM WAS never looking out for you. Planned obsolescence was the company model.
I know you have spent a lot of time at the track. I have heard that road race SBCs would need to run about 1 quart over full for hot laps with the factory pan, pump and baffle setup. Can you confirm? For my street car the oil drain back is probably not going to be much of an issue but actual track experience is quite different.
If I were headed to the track I would probably spend a lot of time focusing on the oil drain back concerns. Tubes, glyptal paint, grinding to smooth the return passages, etc.
Accusump can also pressurize your oiling system just before you turn on the key. the 4 quart is kinda over kill. At the shop we usually installed a 2-3 quart on non dry sumped American V-8 motors
