Squirrelly front end feel
Old Apr 16, 2020 | 04:59 PM
  #41
Steve Kistler's Avatar
Steve Kistler
Will attempt video tomorrow.
Old Apr 17, 2020 | 10:12 AM
  #42
leigh1322's Avatar
leigh1322
Old Pro Solo Guy
I don't think it is the pressing of the hub bearing that is the problem, it is getting the free-play correct. You can't check it unless it's assembled and to to adjust it you need to dissasemble it again.(press off/on). You have a better chance of getting it right the first time if you have some special vette TA measuring tools.
Old Apr 17, 2020 | 10:53 AM
  #43
Steve Kistler
The video didn’t work so that being said the wheel moves over 1/4” at all positions on passenger side only. Besides access to a press,what tools are needed? I am going to go remove the wheel and figure out whet this will entail. My mechanical abilities are suspect at times. I completely rebuilt my steering column, rebuilt my engine (not the machining) the entire front suspension and fixed a huge crack in the rear quarter. I did not however get The Qjet to function so I replaced it. I should also mention I have achieved those tasks after several attempts at times.
Old Apr 17, 2020 | 11:00 AM
  #44
Bikespace's Avatar
Bikespace
The prep starts well before this, but Post #91 summarizes what @mobird did for his trailing arms. Perhaps read that thread to see if you want to dive in.
https://www.corvetteforum.com/forums...-thread-5.html
Old Apr 17, 2020 | 11:21 AM
  #45
leigh1322's Avatar
leigh1322
Old Pro Solo Guy
Originally Posted by Steve Kistler
.... . I should also mention I have achieved those tasks after several attempts at times.
Sounds like a great way to learn... The old try and try again method!
Seriously getting the TA arm off is your first step. And that can be challenging. Then search for TA rebuild for documentation. It's been done many times at home. Especially if you have access to a press.
That's a good TA rebuild post!!
Old Apr 17, 2020 | 11:23 AM
  #46
Steve Kistler
Thanks ,that was an excellent suggestion. I am often the get it close guy and that isn’t what I need for this job. If I send my trailing arm to Van Steel is there anything else that requires special tools for reassembly?
Old Apr 17, 2020 | 11:30 AM
  #47
Steve Kistler
I really love/hate working on cars. I enjoy a challenge but as I get older rolling around on the garage floor gets to be a challenge by the end of the day sometimes...lol I will get the TA off and then decide what to do next. Any special tools needed just to remove it? I have a really big hammer.
Old Apr 17, 2020 | 11:34 AM
  #48
leigh1322's Avatar
leigh1322
Old Pro Solo Guy
On some cars a sawzall comes in handy for the bolt.
Try lots of PB Blaster and hope it works!
Old Apr 17, 2020 | 11:43 AM
  #49
Steve Kistler
Got one of those as well. Once I get it off I will go from there. Thanks
Old Apr 17, 2020 | 03:07 PM
  #50
Steve Kistler
Got it off and didn’t break anything or use the saw. Next step I assume is the press to get it apart and get some parts headed this way. Is a 6 ton press big enough or should Iget a 12 T?
Old Apr 18, 2020 | 07:57 AM
  #51
Steve Kistler
If I get a spindle knocker,a setup tool and bearing puller set do I need a hydraulic press? Thanks
