Overheating
Old May 28, 2020 | 08:37 PM
Ammoman82's Avatar
Ammoman82
Originally Posted by drwet
Somethings not right here. This doesn’t sound like purely an overheating issue. 210-220 degrees is warm, but it’s hardly overheating and certainly not enough to cause the engine to quit. Not sure what but something else is going on here.
I’m thinking I would start with the basics: compression test, leak down, timing. Then go from there. If I had to hazard a guess I’m thinking head gasket??
thats is what I’m worried about. But no smoke or milky oil. The last time it cut off yesterday was when I got on it when hot. Restarted and drove home (less than a quarter mile) without issues.
Old May 28, 2020 | 08:42 PM
Ammoman82's Avatar
Ammoman82
I just reread that, over heating is 240/260 plus and blowing steam everywhere. IF it just gets to 210/220 then stalls its a heat related issue. It sounds like it wold be an delectrical or fuel related issue. Maybe you have a bad coil, a cracked cap, youre vapor locking, or have a fuel pump issue.
Edelbrocks are known for being heat sensitive and needing low fuel pressure, but it doesnt account for the temperature increase. If you have the quadrajet, thow it back on and see if the temp isssue goes away. The stalling may just be a symptom of the overheating, or the stalling is a symptom of something else and the overheating is also a symptom of that other problem. So elimate possible causes. Start with the carb and then check your tune up. if changing that doesnt do it you may have to get your radiator flushed. Maybe its flowing enough to stay cool at idle rpm ,but not at 3000 rpm. If there is alot of mud in your system you may have to flush it 3 times, i had to in my old motor.
working on flushing it tonight. Rather drained it and then all the family stuff happens so I will get it done tomorrow after work. A thought about the fuel crossed my mind about that being hot/flooding the carb or the filter being clogged already despite being it being new. But I’m new at most of this and never been experienced at diagnosis with engine issues.
Old May 28, 2020 | 08:44 PM
Ammoman82's Avatar
Ammoman82
Originally Posted by MelWff
Do you have a vacuum controlled heat riser valve where the drivers side exhaust manifold connects to the exhaust pipe?
If so did you not correctly connect the vacuum lines and the valve is always closed forcing exhaust gas constantly through the intake manifold?
im not seeing one. Had it converted to straight pipe in 2012 and it may have broken before that.
Old May 28, 2020 | 09:04 PM
Haggisbash's Avatar
Haggisbash
Assuming you don't have an air leak somewhere do you know if the carb is supplying the correct air fuel ratio above idle that your engine needs? Typically most carbs out of the box seem to be jetted on the rich side but what is yours like? A lean mixture will make the engine run hotter.
Old May 28, 2020 | 09:07 PM
Bikespace's Avatar
Bikespace
A few more questions that may help:
Do you have an infrared thermometer to check your temperature? I found that shooting at the upper radiator hose gave me my most consistent results (compared to a thermocouple taped to the hose). Clearly something is happening, but the exact number is helpful to know.
What is your timing set to? If you haven't already, it is worth it to email @lars (post 15) and ask for his timing papers, as well as his distributor and Q-Jet setup papers. Going through his timing method (Not stock, but much better), may well fix your problem, and it is certainly easier to do than swapping a carb.
Old May 28, 2020 | 09:08 PM
Ammoman82's Avatar
Ammoman82
it isn’t yet. Haven’t gotten that fully set because of the heat. The carb itself is staying hot to the touch. Some of the advice I had was that the 210-220 range was too hot so I’ve been focusing on that.
Old May 28, 2020 | 09:11 PM
Ammoman82's Avatar
Ammoman82
I will have to look for the thermometer you mention. Haven’t messed with the timing at all through this process. Thanks for the information
Old May 29, 2020 | 12:27 AM
7T1vette's Avatar
7T1vette
If it does not overheat during idle condition or a low cruising speed, but it overheats once you increase speed to highway conditions, chances are the [steel] sping in the lower radiator hose (keeps that hose from collapsing at higher speeds) has rusted/rotted away. When the engine is OFF and cold, grab that lower hose in the middle and give it a good squeeze. If it does not resist changing shape, you have no sping inside it. Unless you have a corrugated hose (non-collapsing by design), put the required spring in it and your problems may disappear.
Old May 29, 2020 | 08:56 AM
drwet's Avatar
drwet
That's an excellent suggestion, but it still doesn't explain why the engine quits.
Old May 29, 2020 | 09:06 AM
Rescue Rogers's Avatar
Rescue Rogers
Is my vette stock?? HAHA
2016 C3 of Year Finalist
That carb may be vapor locking at that temp possibly..... My edelbrocks never stalled like that but they would be hard starting when the ambient air temp was high, I had to go to a wood spacer to keep the heat away from the carb, but I have a L88 hood, so clearance wasnt an issue for me. I also had to intall a pressure regulator.
Old May 29, 2020 | 11:19 AM
7T1vette's Avatar
7T1vette
Sorry....I forgot my crystal ball...........
When he fixes the overheating problems, the "quitting" will disappear.
Old May 29, 2020 | 11:23 AM
Rescue Rogers
Or if he fixes the quiting, the heat will dissapear............
Old May 29, 2020 | 12:07 PM
  #33
7T1vette's Avatar
7T1vette
Whatever....... This is an OPEN forum. YOU give your advice; I give MY advice. That's how it works. The OP can decide what he/she wants to go with.....
Old May 29, 2020 | 12:18 PM
  #34
Jebbysan's Avatar
Jebbysan
Dr. Detroit
Please get rid of that square bore to spread bore adapter you installed. Those are just the most terrible thing and you will never get it to run right.
Buy either a 2101 or 2701 edebrock intake, and use 1204 intake gaskets or put the Q-Jet back on. Either intake is EGR delete and the 1204 will block the nasty heat riser passage in the heads off. I would get the intake.....the AVS2 is a nice carb.....although most do not agree with me.
The above timing recommendations need to be done before you can do anything else......
Jebby
Old May 29, 2020 | 12:30 PM
  #35
Rescue Rogers
I was kidding....
Old May 29, 2020 | 03:49 PM
  #36
derekderek's Avatar
derekderek
It is not just that. In 10 years somebody is gonna use this info to figure out their similar issue.
Old May 29, 2020 | 04:31 PM
  #37
Big2Bird's Avatar
Big2Bird
If I am reading this correctly, the issues started with the carb swap. I would go back to square one, and reinstall the quadrajet.
The Edelbrock may be lean, or the float is incorrect, and its lean/starving for fuel.
Put it back, check ignition and timing, and go from there.
Any other maintenence like flushing cooling system, fresh coolant, etc will do no harm.
Jebby is spot on about the adapter non sense.
To Overheating
Old May 29, 2020 | 07:09 PM
  #38
7T1vette's Avatar
7T1vette
Actually, the first WORD of this thread was "Overheating" (title of post #1)....which is WHY the OP decided to try swapping carbs. But, into the minutia we go....
Old May 29, 2020 | 07:16 PM
  #39
69lemans's Avatar
69lemans
When its hot, feel the upper and lower hose to see it they are equally hot. If not, you probably have a Rad problem. May also want to feel the fins on Rad.
Old May 30, 2020 | 10:25 AM
  #40
drwet's Avatar
drwet
When I read the original post, I got the impression the 'overheating' started after he installed the carb. Perhaps the OP will chime in and clarify?
