fuel line
Old Jun 18, 2020 | 09:48 AM
69vette427/435's Avatar
69vette427/435
Default fuel line
Anyone have any pics of how the fuel lines are run in the front. 1969 427/390. Not sure how to run them
Old Jun 18, 2020 | 11:55 AM
MelWff's Avatar
MelWff
What do you mean by front, fuel pump to carburetor?
If so the three lines involved are in the link below.
One line goes from the pump to the fuel filter.
The second large line goes from the fuel filter to the carburetor.
The third thin line is the return line and runs from the fuel filter to the return line on the frame.
https://www.zip-corvette.com/69-427-...-line-kit.html
Old Jun 18, 2020 | 12:23 PM
69vette427/435
The rubber lines. the vapor return line and line on the pump. Diagram looks as if they are twisted around each other
Old Jun 18, 2020 | 12:36 PM
7T1vette's Avatar
7T1vette
You should have an Assembly Instruction Manual (AIM) for your year car, so you have the detailed drawings you need to work on your car. Also, the "S" shaped rubber hose on the fuel pump needs to be a MOLDED hose, rather than bent-around stock hose. Regular fuel hose will KINK with those short turns and shut off fuel flow. Buy the molded hose for this one....
Old Jun 18, 2020 | 04:35 PM
MelWff's Avatar
MelWff
its a fuel return line not vapor and is just a short piece of hose from the return line pipe to the line on the frame.
As mentioned above the line from the frame to the input of the pump is a premolded S shaped hose.
Are you using the correct gas filter that has pipe connections for in and out and has a second small out that the return line connects to with a very short piece of hose, GF432?
Old Jun 18, 2020 | 07:21 PM
lars's Avatar
lars
1969 L36 fuel line routing and configuration is the same:
https://www.corvetteforum.com/forums...cs-please.html
Lars
Old Jun 19, 2020 | 09:22 AM
69vette427/435
I have the correct fuel filter and the FUEL return line is good. I,ve found the molded S line. The catalog say its for 70 to 82. Can I assume that it will fit a 69 also?
Old Jun 19, 2020 | 09:29 AM
69vette427/435
Default Fuel line
Old Jun 19, 2020 | 09:37 AM
Mooser's Avatar
Mooser
Removed - Not the same setup
M
Old Jun 19, 2020 | 09:51 AM
69vette427/435
Not the set up I have. 1 line in and 1 line out
Old Jun 20, 2020 | 06:48 AM
Danish Shark's Avatar
Danish Shark
The S shaped hose is for small block only.
69 big block does not use that, just a regular piece of hose.
Old Jun 20, 2020 | 12:33 PM
69vette427/435
thanks. Thats what I i was looking for
To fuel line
