crossfirejniection engine problem
Old Aug 18, 2020 | 09:16 AM
Maxim0's Avatar
Maxim0
Originally Posted by Mocse
the Corvette always gets quite warm inside when driving. It's the same with me too. it is important that the water temperature is within the normal range.
what temperature it must have to be normal I mean the water temperature seen on the internal alarm gauge
Old Aug 18, 2020 | 09:18 AM
Maxim0's Avatar
Maxim0
Originally Posted by FASTAZU
Lots of great information that may help. How is the exhaust flow? Could the catalytic converter be bad?
https://www.corvetteforum.com/forums...solutions.html
thank thanks verry mach
Old Aug 18, 2020 | 09:34 AM
Mocse's Avatar
Mocse
have you ever read the errors from the ecm. that could also help. do you know how to do that
Maxim0's Avatar
Maxim0
if someone lives near italy can i bring my car for repair?
Old Aug 18, 2020 | 09:46 AM
Maxim0's Avatar
Maxim0
no
unfortunately I'm not a mechanic I don't know how to do it, maybe I can learn
Old Aug 18, 2020 | 09:51 AM
Mocse's Avatar
Mocse
Sorry, i‘m living in Germany... it‘s too far and i‘m Not a mechanic. I repair my vette learning by doing . there must be a good workshop for Corvette in Italy. have you ever asked in the Italian Corvette forum?
Old Aug 18, 2020 | 09:59 AM
Mocse's Avatar
Mocse
Reading out the Error Codes... the odb1 is under the ashtray
Old Aug 18, 2020 | 10:05 AM
Mocse's Avatar
Mocse
You also should buy a 82 Corvette Shop manual. all parts are described in there and how to repair them including diagnosis
Maxim0's Avatar
Maxim0
no
I understand yes we are far away but I want to ask the forum italia corvette if there will be a good workshop here in Italy .... I want to say thank you for writing to me thanks for your advice thank you very much you have been of great help, especially all of you that me you have written thanks again from Italy
Old Aug 18, 2020 | 10:10 AM
Maxim0's Avatar
Maxim0
yes yes I'll have to buy it
Old Aug 19, 2020 | 03:53 PM
Maxim0's Avatar
Maxim0
what tool do i need to read odb1 error codes under the ashtray ???? please kindly send a photo thanks
Old Aug 19, 2020 | 04:10 PM
Maxim0's Avatar
Maxim0
I ask someone who knows more than me, when I put the car back in the garage is it right or wrong to disconnect the battery to prevent it from discharging due to a long period of inactivity of the car? for example during the winter I do not use the car is it right to disconnect the battery as I have already started doing for three months?
Old Aug 19, 2020 | 04:33 PM
  #33
Mocse's Avatar
Mocse
go through these instructions step by step. So take out the ashtray, bridge pins A and B with a paper clip. Switch on ignition. cel watch. 3x code 12 should appear (i.e. 3x blink pause blink blink, then the error codes and finally code 12 again) the frozen codes are always two-digit, e.g. blink pause blink blink blink for 13 or blink blink pause blink for 21. ..
Old Aug 19, 2020 | 04:35 PM
  #34
Mocse's Avatar
Mocse
I am still very sure that the IACs should be swapped.
Old Aug 19, 2020 | 05:11 PM
  #35
Maxim0's Avatar
Maxim0
thanks ok
Old Aug 19, 2020 | 05:12 PM
  #36
Maxim0's Avatar
Maxim0
thanks ok
Old Aug 19, 2020 | 05:14 PM
  #37
Maxim0's Avatar
Maxim0
thanks ok
Is it okay to disconnect the battery every time you put the car back in the garage? what problems can happen?
To crossfirejniection engine problem
Old Aug 19, 2020 | 09:47 PM
  #38
DWAVette's Avatar
DWAVette
Default 82ce
Looking at the pictures, it appears there have been numerous modifications to your engine.
Was the car running good when you got it?
Old Aug 19, 2020 | 11:06 PM
  #39
Buccaneer's Avatar
Buccaneer
From: Arizona - If you don’t know CFI, STOP proliferating the myths around it...
The ONLY tool you need to pull the codes from the ECM (computer) is a paperclip and watch the CEL light as it flashes and write down the codes if any. Use the paperclip to short pins A/B together (which is under the ash tray) which will force the ECM to go into diagnostic mode and cause the CEL to flash. You REALLY NEED TO GET THE 82 GM SERVICE MANUAL... REALLY! Everything you need is in that manual to work on the car yourself.
Old Aug 20, 2020 | 01:16 AM
  #40
Maxim0's Avatar
Maxim0
good morning yes there have been changes the previous owner wanted to switch to carburetors because the car was not working well but after he thought about leaving the injection, I think this person took the car to a wrong mechanic, I bought this car at October 2019 but I immediately fell in love as soon as I saw it I was a bit reckless and hasty about the purchase. please write in clear and simple words for a good translation unfortunately i don't speak english and i have to do the translation be patient thanks
