Allison XR-700 Ignition
Old Jan 31, 2021 | 02:50 PM
Richard Daugird's Avatar
Richard Daugird
Default Allison XR-700 Ignition
Anyone have one of these? Mine is on a ‘74 small block tach drive distributor.
Old Jan 31, 2021 | 11:51 PM
7T1vette's Avatar
7T1vette
It is just another aftermarket electronic ignition system...like Pertronix, etc. If it functions well, keep it.
Old Feb 1, 2021 | 08:13 AM
pspicci's Avatar
pspicci
I had one on my 71 for aprox 30 years. only issue i ever had was the plastic piece that has the slots cut in it had one of the mounting ears where the rotor screw goes thru break off. i called the the factory and they sent me 2 replacements at n/c. outside of that one issue it worked flawlessly. only reason i stopped using it is about 5 years ago i switched to a MSD tach drive dist.
Old Feb 1, 2021 | 09:54 AM
Richard Daugird
7 & 8 cylinders are cold, I have new cap, rotor, plugs and wires, I'm thinking it might be the ignition box.
Old Feb 1, 2021 | 10:03 AM
Jebbysan's Avatar
Jebbysan
Dr. Detroit
The box can't cause this.....it either works or does not. The pickup for the box though can or the pickup trigger wheel and I suggest going there next. Looks like it is optical so look for any obstruction in the slots.
Jebby
Old Feb 1, 2021 | 10:23 AM
Richard Daugird
Thanks, I'll look into that.
Old Feb 1, 2021 | 09:36 PM
7T1vette's Avatar
7T1vette
I agree....not the box.
To Allison XR-700 Ignition
