Replacing PS pump
Old Sep 30, 2021 | 10:27 PM
TuffShift's Avatar
TuffShift
Default Replacing PS pump
Main seal is leaking badly on the PS pump....local mechanics tell me it is cost effective to simply replace the entire pump......which brings me to my question: I recall reading where the grease zerks on the bottom of the PS pump should NOT be used for fear of overgreasing and blowing out the seal.
Is this true on the REPLACEMENT pump, or was this just in reference to the OEM pump?...or was that only for the steering GEARBOX and not the pump itself?
Old Sep 30, 2021 | 11:01 PM
Bikespace's Avatar
Bikespace
I don't recall any zerks on the pump, or steering box (though it can be improperly greased). There is a zerk on the stock power steering valve (at the end of the steering center link) that I believe was placed there as a trap. Perhaps the power steering valve is what you are thinking of?
I bought a replacement pump from RockAuto to complete my Borgeson conversion, as it decided to puke its guts out immediately after every other component had been replaced. You will need to swap the pump pulley to the new pump.
Old Oct 1, 2021 | 05:19 AM
4-vettes's Avatar
4-vettes
Cruise-In VIII Veteran
Considering the cost of a good pump, and the labor if rebuilding one. Yes replacement is most likely a better option. if you are capable of rebuilding the pump yourself, but then you already mentioned a mechanic in the mix.
I would recommend highly the tuff Stuff brand pump for your 79. pulling and reinstalling the pulley will be the most difficult part. And then you have a new pump. not a 40 year old one with a new seal.
And by the way, a lot of people complain about chrome cap on the tuff stuff pump. the chrome is just a press on cover. It comes off easily, the chrome part that is, revealing a standard cap.
And bikespace is correct, no grease zirk on the pump. just on the valve on the drag link.
Old Oct 1, 2021 | 08:26 AM
interpon's Avatar
interpon
i think i just did one of what you are talking about, below
https://www.corvetteforum.com/forums...leak-79-a.html
https://www.corvetteforum.com/forums...-question.html
Old Oct 1, 2021 | 11:14 AM
ctmccloskey's Avatar
ctmccloskey
I bought my last Power Steering Pump from Turn One as they made sure it was set up properly from the beginning. The "flow rate" is critical if you want the power steering system to operate properly. I changed pumps and had a Hyper sensitive steering system one time and that taught me to watch the flow rates.
I don't think I have ever seen any fittings other than the Input and Output on the power steering pumps. They do make new cases for the PS pumps and they have the new seals already in them. You simply swap the guts over...
Old Oct 1, 2021 | 12:03 PM
lars's Avatar
lars
Karl -
If your pump is working fine but just leaking, there is no need to replace it. The replacement pumps do not have the same reservoir shape as the original. The pumps are super-easy to work on and rebuild with a rebuild kit (available from NAPA, Classic Industries, and many other sources for under $15). I just went through the original pump on my '71 Judge due to leaks. While I had it apart, I removed all the little dents out of the reservoir housing, painted everything up, put all new seals in it, and installed it with a new set of hoses. It's like brand new, looks perfect, and has no leaks. And it's "the right" pump for the car.
Lars
Old Oct 1, 2021 | 08:19 PM
TuffShift's Avatar
TuffShift
Originally Posted by lars
Karl -
Lars
Welllll, since you mentioned it Lars, the pump ITSELF is functioning fine...it just LEAKS around the main seal, badly...drains itself in less than a week. ...kind of a big o-ring sort of thing, I am told.
Beings that I am 80 yrs old, my squirming days beneath that C3 are pretty much "history". It was the mechanics recommendation that it would be more "cost-effective" to replace the entire pump, than to have to 'eat' all the labor costs to JUST replace the O-ring....IF he says, IF he can even GET just the mounting O-ring.
It is scheduled to go into the shop this coming Wednesday. What do y'all suggest? It's NOT that I am necessarily a "tightwad", but I AM retired and on a fixed income nowadays.
Oh and btw, the main pressure hose was replaced sometime ago, so that is not an issue.
Old Oct 1, 2021 | 08:44 PM
interpon's Avatar
interpon
your options are limited so I would
go cheap and your trusted mechanics recommendation and drive it…
but keep old pump and in your spare time rebuild the gaskets and o rings and pretty it up.. see my previous link..
you may need it..
good luck! And good driving Thursday
Old Oct 1, 2021 | 09:17 PM
TuffShift's Avatar
TuffShift
go cheap and your trusted mechanics recommendation and drive it…but keep old pump and in your spare time rebuild the gaskets and o rings and pretty it up.. see my previous link..you may need it..
It's been a really good old car for me, but lately has been "showing its age" worse than I have. I'll go with the full replacement, (not sure if I can keep the old pump though.....ya know, "core charges" and all that stuff.
Will let ya'll know how the Thursday drive went
Thanks to all for your input.
To Replacing PS pump
