C3 ( &C2) Suspension Analysis & some fixes
Firstly, any side yoke play in the differential results in lost negative camber on the outside rear wheel in a turn. Obviously the lower you can get this play the better. On this subject too, I note too that pictures underneath most of the quick autocross guys cars that I have seen over the years have the strut rod inners mounted high to utilise camber gain.
Secondly, chassis flex. There's a lot of it... Short of a full cage, tying through the fire wall from front to rear of the chassis, there still will be, and the stickier your tyres and higher the cornering loads, the more flex there will be. Though you can help with solid mounts, a spreader bar etc, there is still a lot of flex, you can clearly feel it if for example you go through a drain at an angle. It's just something that you have to live with and work around. My car is a street car first and foremost, and there is no legal way to put in a full cage where I live in Australia and retain street registration (damn nanny state...). And there's not a whole lot of room in these cars to begin with, even without a cage anyway. I think from memory that gkull does have an extensive cage in his car.
My car just lifting the inner front powering out of a corner:
Yes I have seen many autocross cars lift a front tire (some rear ones too but I don't pay much attention to FWD usually LOL)
What many don't realize, but I am sure you do, is that even on a car with 50/50 weight distribution, that about 70% of the weight transfers at the front. So the 600 ish lbs of weight transfer goes mostly to the left front, it's like an extra 100# or so just got jacked from the back to the front of the car. That tire can hit 1500-1700+ lbs in the corner and the right be at 100-200# even at 1.0G. It would not take much more G Force than that to lift the inside front. (On a 911 with their light front end that process happens even quicker.)
Now with a sudden power application, front shock rebound valving comes into play, which is many times stronger than the compression, and can lift the tire briefly before the shock unloads and extends. Another way is the outer bump stop bottoms out, that's the bad way to lift it. Making sure it happens the way you want it too, that makes the car faster. Adding understeer to the car, so you can use more throttle, also aggravates the problem. Ideally you want all four tires on the ground, but sometimes the other change that causes it is worth it.
All suspension tuning is always a compromise, but the main goal is all the motions must be smooth, gradual and predictable. After all the goal is to take the tire exactly to the edge of it's adhesion, and hold it there, without going "over" right?
Clearly a lot experience and expertise in this thread.
Speaking of unsprung weight, if 80 pounds of unsprung weight is removed from my 72's C3's suspension with new wheels and aluminum calipers will I feel that improvement in the ride and handling on the street?
Car has the full VB&P suspension front & rear but stock calipers and 15 x 8 steel wheels. Definitely could feel the suspension upgrade.
Thank you.
Lovin' the tire wear picture!
I used to set my alignment by tire wear (well at least partly)
My Hoosiers were about as thick as 4 pieces of paper when they looked like that. I do not know how they even held air.
Now if only you could get the middle to wear as evenly. Then they would be bald all the way across. LOL
So now....the question is:
1) Do you need a couple more psi to get the middle to wear evenly? -or-
2) Is the inside wear from large static camber and the outside wear from pos camber in a corner?
Only tire temps will tell the tale... or a corner pic would help like GKull mentioned.
99 Black Bird TA
It should ride better. And respond to bumps better, especially things like tar strips, and handle better in a bumpy corner.
But with the same shocks I have no idea if you could actually feel the difference or not.
Maybe on impact strips. Maybe on the clock on a course. But you quite literally may have to (soften??) the shocks (rebound?) due to 20% less weight to control, to optimize traction. Then it would definately ride better. That is the advantage to less unsprung weight.
I also did the Chevy Power book recommended kit from Tom's with all the frame gusseting and welded up the frame with continuous seam welding. Nothing rusts in the Southwest with 12% humidity on most days.
Fire proof aluminum bubble matting and flame retardant short pile carpet after gutting the interior and using a hole saw to cut through the body
Rear most is near the diff crossmember and hoop bar is in front of the kick up
275 front street tires and 335 rears on 9 and 13 inch wheels
Back in street trim for this summer with cushy factory seats
.... In process of putting a factory looking shifter handle and stereo back in it at the moment.
Anyway, this tire wear is #2. I was overinflated. Inside wear from braking camber, outside wear from cornering camber.
I am a bit limited by vintage racing rules. For example, have to run stock control arms and spindles. Honestly, I'm surprised at how well the F40 handles.
These are NASCAR bias ply slicks for vintage racing. Made for 10 inch rear wheels. The tread width is something like 12 inches. Really sticky at temp. Road racing I was able to get an hour or even two out of them even on abrasive tracks.
Which rear strut rod mount are you running? C2 or C3? And are you allowed to change it according to the rules?
The front a-arm bar Gkull mentioned really helps as well, if you have PS, and probably would not be visible.
Moog Upper control arms with 1/4" slot added. You could do this to stock arms too.
That would immediately fix my bump-steer problem. Is the upper ball joint the only thing you changed for this experiment? Could you post the part number for the ball joints you used?
I also have SPC upper A-Arms, so 4-bolt ball joints are fine, I just need to swap the mount plate.
https://howeracing.com/collections/h...er-Ball-Joints
1963-1982 Corvette Alignment Information - CC Tech (corvettecentral.com)
Thanks for posting the camber curve imrpovements possible with 3/4" longer upper ball joints. Thanks to your careful measurements it looks like the camber gain doubles from 1 degree to 2 degrees for that critical first 1.5" of bump. That could be just the ticket for someone wanting to run less static camber and still have 0-0.5 degrees negative in a corner.
Bumpsteer blocks
Guess what I found on Duntov Motors site?
https://www.duntovmotors.com/vintage...s-steering.php
These bumpsteer blocks remind me of the old Guldstrand/VBP design.
Now there are so many different things that affect bumpsteer in the suspension, (basically everything) that I would strongly suggest to anyone contemplating this to measure your car first and determine what it needs. You could just as easily make it worse, as make it better. Bumpsteer is affected by camber, caster, and ride-height.
When I get to that point I will carefully measure my car and see if I can cut mine down to under .030" like Jason did. However spring rates, ride height, castor and camber must all be taken care of first, probably in that order. Bump-steer is dead last.
Toe Rod Ends adjustable
The adjustable height tie rod ends are shown on the Duntov site, and are also available from Howe:
https://howeracing.com/collections/h...p-tie-rod-ends
Height-adjustable tie rod ends are also available (from Howe & others) for the last bit of bump-steer fine-tuning.
After years of tweaking my stock suspension I finally just cut and modified a spare C3 frame and put a narrowed C4 suspension on it, and am running it under my '69. While I like the lighter weight of the C4 suspension, I find that I'm still doing similar tweaks to it to get the car to handle the way I like.
Looking forward to additional content in this thread, and the possibility of it becoming a new sticky.
