Help! Harmonic balancer mark is ....off
Old Sep 4, 2023 | 03:16 PM
lars's Avatar
lars
You might also want to check out my post on balancer slipping and replacement:
https://www.corvetteforum.com/forums...blem-post.html
Lars
Old Sep 12, 2023 | 06:21 PM
rgouette's Avatar
rgouette
ok, so I unwrapped my shiny new TDC check tool, & headed out to the garage to see what it tells me.
Here's what I did:
1) threaded the toolinto cyl#1(drivs side fwd)
2) rotated the engine until it stopped on the tool
3) made a mark on the balancer at the "0" mark on my newly installed timing tab
4) rotated the opposite direction until it stopped
5) made another mark at the same place
6) made a mark between those two marks: I believe that should be TDC
Some notes of interest:
1) The factory timing mark on the HB is at 12:00
2) The distrib rotor is pointing at the REAR of the car..
So, I can conclude that either
1) I've got a replacement engine with a timing mark somewhere at 12:00(haven't looked yet)..and the distro was way outta whack...
2) the HB has slipped
Does all that sound right to you fellas?
thanks much,
Rich
Old Sep 12, 2023 | 06:45 PM
n2h2o2's Avatar
n2h2o2
Are you on the compression stroke or exhaust stroke?
Old Sep 12, 2023 | 06:56 PM
rgouette's Avatar
rgouette
crap... I forgot it could be the exhaust...
I'm not wanting to yank the valve cover to look at vales, only because it's a pita with the tall covers....
I'll revisit this...
and thank you for that most elementary of reminders..
Old Sep 12, 2023 | 07:47 PM
RubyRedMetallic's Avatar
RubyRedMetallic
Were your distributor is pointing doesn't matter as long as you moved the wires to match. Just be aware which ever terminal it's pointing at is #1, then place the rest in order off that.
Old Sep 12, 2023 | 08:56 PM
n2h2o2's Avatar
n2h2o2
This is where the thumb over the spark plug hole comes in handy...
As soon as you feel pressure on the compression stroke, put in your cool tool...
Old Sep 12, 2023 | 10:14 PM
rgouette's Avatar
rgouette
yeah, I shoulda known better…
back at it tomorrow!
Old Sep 12, 2023 | 10:43 PM
barkingrats's Avatar
barkingrats
1967 Pedal Car Champion
It doesn't really matter which stroke you're on as Top Dead Center on #1 occurs at the same place whether it's compression/power or exhaust/intake with the balancer mark and timing tab. In your test, is the mid-point between rotation stops at the engraved balancer mark? This was the point of doing the stop-to-stop test, to determine if the outer ring had slipped. If it has, then the engraved mark will not be centered.
Old Sep 13, 2023 | 07:50 AM
rgouette's Avatar
rgouette
I guess the new priority is going to be searching to see if there is another timing tab on the engine, as some have suggested COULD be the case if the engine isn't original..
If there ISN'T another timing tab, then I've got bigger problems.
Either way, here's the good news: I found a fellow who lives a couple of minutes away, and he has a long history of chevy racing engines/building
He came over a couple nights ago, & did a overview of the thing, & gave me some things to do before he comes back again.(put in new points/condenser etc)
I'll run all of this by him... I'm sure he'll get me sorted out.
Old Sep 13, 2023 | 11:22 AM
lars's Avatar
lars
So you used your TDC tool, rotated the engine one way until it stopped... made a mark on the balancer at the "0" line on the timing tab.... rotated the engine the other way until it stopped... made a mark at the "0" line on the timing tab.... and then made a new timing line halfway between the two lines. This new line did not line up with the existing line on the balancer. When you align your new line with the "0" line on the timing tab, your original line on the balancer points straight up at the 12:00 position.
Is that an accurate recap of what you did? If so, you have accurately determined and set the engine to the TDC position. It may be 180 degrees out on the firing stroke versus exhaust stroke, but that's irrelevant to the TDC position.
If so, you have a defective balancer. Once you get those first two lines established, the timing line should be located exactly between the two lines. There is no small block Chevy that uses a timing tab at the 12:00 position, nor any SBC balancer that has its timing line at the 12:00 position when the engine is at TDC. New points & condenser aren't going to change that fact. Fix the obvious problem: replace the balancer, and then re-do the TDC check to verify the accuracy of your timing tab and make any minor correction necessary.
Lars
Old Sep 13, 2023 | 11:33 AM
rgouette's Avatar
rgouette
Lars
Yes Lars, what you wrote out, is exactly what I did.
And no worries, I totally get that points & cond won;t fix this issue.
I'll get with my local guy & nail down this TDC/mark issue before I do ANYTHING else!
Thanks for chiming in!
Rich
ps. I wonder if a nice cold Guinness might not help here...
;O
Old Sep 13, 2023 | 11:39 AM
Jebbysan's Avatar
Jebbysan
Dr. Detroit
Rich
;O
You already nailed down the balancer mark.......now replace it. Your local guy or Guiness isn't going to do anything....nobody is going to be able to do more than you have already done. About half of these cars have a spun balancer on them.....this is no mystery
Jebby
Old Sep 13, 2023 | 02:27 PM
  #33
Mdbirk's Avatar
Mdbirk
Rich
;O
Mmmmmmm Guinness
Old Sep 13, 2023 | 02:29 PM
  #34
rgouette's Avatar
rgouette
Originally Posted by Mdbirk
Mmmmmmm Guinness
Thank you!
Old Sep 13, 2023 | 03:23 PM
  #35
427Hotrod's Avatar
427Hotrod
2020 C2 of the Year - Modified Winner
2020 Corvette of the Year (performance mods)
C2 of Year Winner (performance mods) 2019
2017 C2 of Year Finalist
Just went through this fun this week on a widow neighbors '59 Pickup her husband built for her. Timing mark was 6" from where it should be. I kept looking for the timing mark with timing light..and even tried another one in case it was barfed. Then I finally noticed the mark a LONG way from where it should be.
My piston stop is a gutted spark plug where I tapped it internally and inserted a long bolt. Works great for the last 20-30 years!
You're on the right path.
JIM
Old Sep 13, 2023 | 03:26 PM
  #36
427Hotrod's Avatar
427Hotrod
And there were some timing tabs at 12'o'clock as I recall from my dealership days. They were moving them all over the place for a while.
JIM
Old Sep 13, 2023 | 03:37 PM
  #37
rgouette's Avatar
rgouette
JIM
Thank you good sir!
~R
To Help! Harmonic balancer mark is ....off
Old Sep 13, 2023 | 04:33 PM
  #38
lars's Avatar
lars
And there were some timing tabs at 12'o'clock as I recall from my dealership days.JIM
Okay, wiseguy Jim... one year only in '86... I think we have solidly established that his balancer has slipped and that the mark should not be at the 12:00 position on his '74... I might have to lower your Texas flag below the level of my Colorado flag, and move the Shiner Bock tap handle from the right side to the left side of the tap tower for that one.... So can we say that "no stock C3 Vettes ever had the timing tab at the 12:00 position."
Lars
Old Sep 13, 2023 | 06:32 PM
  #39
leigh1322's Avatar
leigh1322
Old Pro Solo Guy
They do not even have to be all that old.
I just had the balancer almost slip off on my wife's 2007 Honda.
"That's what all that noise was"
It came off in 2 pieces.
Old Sep 13, 2023 | 06:46 PM
  #40
427Hotrod's Avatar
427Hotrod
Lars
LOL....the only reason it stood out to me was I was just doing it last week on that truck and i was thinking I seemed to remember some being behind the water pump...and the ones with the timing probe hole. Not knowing what cobbled up mess of an engine might be in it...other than they said it was a 350 and it had OEM heads....I figured it might have wrong balancer on it. She has a short water pump so no way to see a tab back in there anyway. But her mark was way down below to the bottom..so it wouldn't be one of these funky ones anyway that would have been on the other side of the timing pointer if it was. She needs a balancer too!
That's alright...I'll keep your CO flag at full mast in the Batcave/Skunkworks shop!!
