Started the 2004R install.
A few questions for those who know.
1. Do i need to fully remove the driveshaft, its still in with loose straps in the rear, i slid the yoke into the transmission and looks like plenty of room to move the trans back a bit to drop down or i believe i can just take the yoke out while still in the car, not sure how far back the transmission needs to move back... just to clear the liner pins at the bellhousing?
2. Is there a better option for strap bolts over the 12 point bolts, can easily see those rounding when trying to tighten, anyone know a part number or source for better bolts for 1980 auto?
3. There is a vacuum actuator at the back of the th350, can I just plug the vacuum line up front?
4. I plan on cutting the cooler lines if i can't remove the lines at the transmission, will attempt when I lower the trans a bit, if I cut them I can get them off once the trans is out. I will flare all ends and reconnect with flexible lines in a small section. I have read the 200R4 is opposite from the th350 with the in and out lines meaning the upper line goes to the lower port and vice versa... can anyone verify this?
thanks in advance, might have more as I go.
My responses in BLUE.
1. Do i need to fully remove the driveshaft, its still in with loose straps in the rear, i slid the yoke into the transmission and looks like plenty of room to move the trans back a bit to drop down or i believe i can just take the yoke out while still in the car, not sure how far back the transmission needs to move back... just to clear the liner pins at the bellhousing? I did NOT remove my driveshaft. Just tucked up it up high int he tunnel and used a chunck of wood lodged aft to keep it up there.
2. Is there a better option for strap bolts over the 12 point bolts, can easily see those rounding when trying to tighten, anyone know a part number or source for better bolts for 1980 auto? Mine did NOT round off. Just take your time.
3. There is a vacuum actuator at the back of the th350, can I just plug the vacuum line up front? I did not have a modulator so I cannot provide any assistance here but I would suppose you could just lug it up top.
I would make every effort I could to disconnect before cutting. I fabricated my lines using SS braided hose but if I had real lines I would have tried to keep them. Let me look up the inlet vs outlet information...I think i saved a link somewhere.
Looks like the inlet vs outlet are opposite but no big deal per these guys: https://nastyz28.com/threads/2004r-t...g-lines.35443/
I used long extensions to get to the u-joint bolts. Worked well. You can try that when putting them back in if you wanna give it a shot.
I used 6L80 Banjo-Type tranny fittings to make the 200-4R fittings fit inside the confines of my narrow 68 manual tranny tunnel. You should not have to do that and after you lower the tranny a skosh you should be able to get a handle on those fittings.
Just FYI: I spent like a day trying to make a fill tube fit and then after I mutilated the heck out of it.....I said "screw it!" and ordered a Braided SS Lokar Tranny Fill Tube specific for a 200-4R. Later I saw that there a few generic Braided SS aftermarket fill tubes....but oh well... it worked great.... I temporarily tye-wrapped it to the wiper door actuator bracket and haven't anything else with it.
I recommend installed a drain plug. I'm glad I did since I ended up removing and reinstalling my pan several times over the past 2 years for something other. It makes a lot less of a mess and saves on the Dexron VI synthetic fluid I use....anyway, something to consider.
this trans came with the deeper alloy finned pan with drain plug and braided fill tube made for it which im happy about, I was gonna drop it to set up TV cable but I'm reading I won't have to if I use a pressure gauge and adjust at the carb
Beautiful clean looking unit. I have a pressure gauge installed from the beginning. But I really think the way to really set the TV Cable is with an Endoscope Camera (cheap on amazon) pointing to the slug (pan removed of course) and attached to your phone/table/or laptop and then adjusting the TV cable at the engine end through it's full range of travel.
I had done every trick I could find, and yes I had a pressure gauge installed, but I finally dropped my pan, pointed the camera at it, and I was pretty much discombobulated...... so i adjusted it while viewing from up top.
You can eyeball the slug adjustments here. Pictures aren't the best but you'll get the idea: https://www.corvetteforum.com/forums...post1605527708
https://www.ebay.com/itm/30245200756...BlBMUKqKse6WYw
Went pretty smooth for the most part doing it by myself on my back, had two jacks going, thought having side pipes would make the job easier not having to remove exhaust but oh no... had to disconnect from side frames to lower the back of the transmission enough to get to all bolts. I have it in, bellhousing bolted up, crossmember in place, fill tube in as well, still need to connect the lines, shift linkage and set up TV cable to the carb. My only concern is the distance between the torque converter and flex plate, belhousing is bolted tight to engine but there is still about 1/4" between torque converter and bolt holes... I can slide the torque converter forward to meet the flex plate but is that kind of distance normal?
just did some reading, looks like I will need some torque converter washers/shims
The swap was fairly simple on my 78, I tested it last week and it works, just need the vacuum switch for the lockup torque converter. It is a little odd with the 2200 stall, compared to how it was before with the stock stall.
