heat barrier
Old Apr 4, 2025 | 05:22 PM
alan600's Avatar
alan600
Default heat barrier
My 1980 has hooker headers and side pipes and puts out tremendous floor board heat. I am fixing to recarpet and looking for advice on the best heat shield (conventional or non-conventional) that anyone has had good luck with. any help greatly appreciated.
Old Apr 4, 2025 | 05:34 PM
Piersonpie's Avatar
Piersonpie
Here is a thread from two days ago that talks about the same thing.
Old Apr 4, 2025 | 11:07 PM
Bikespace's Avatar
Bikespace
My 80 with Hooker-style sidepipe headers does NOT put out tremendous heat.
What is your timing set to?
Here's what I posted in the thread that @Piersonpie linked:
Originally Posted by Bikespace
I used Reflectrix from Lowes, and Hushmat from Amazon. Neither was pre-cut of course. You don't need 100% coverage with the Hushmat, it works by not only dampening, but also by changing the resonant frequency of large panels.
For actual heat control, the best things you can do are:
Get your timing really nailed down (follow @lars' instructions)
Delete the heater core and plug the two ports (intake and water pump)
Make sure the horse collar is above your transmission bellhousing
Block holes/gaps in your firewall
Add (sturdy) insulation between the floor and exhaust
I'd only add that @Richard454 mentions the insulation to use (below the floor) later in that thread. Heat Shield Products has some cool stuff.
https://www.heatshieldproducts.com/
Old Apr 5, 2025 | 11:26 AM
ctmccloskey's Avatar
ctmccloskey
Thank You Bikespace! I agree with your point entirely... Having a well sealed radiator and bell housing are a great place to start. I still have my heater hoses for my heat and it is connected and it doesn't seem to have much of an effect on the car in the summer months.
I have a 427 BB with long tube headers going the normal route under the floor. My 1968 C3 has plastic floors and there are not metal parts to it. My engine is running higher than normal compression of 12.25-1 and that makes a lot of extra heat going out the exhaust and I have no issue with a warm floor let alone excessively hot floor. I have nothing trying to insulate the heat under the hood from the exhaust other than a ceramic coating on the headers. The extra heat from my compression has burned away the first few inches of each header pipe and my feet are very comfortable cruising around town or on the highway.
Is your timing retarded? Does the vacuum advance still work? It has a good solid vacuum connection with no leakage? How about the total timing you are running, what is it?
Do you still have a catalytic converter on the vehicle? Take a infra-red thermometer and measure the temperature of the front of the catalytic converter. How hot is it? As a catalytic converter gets plugged up the exhaust temperature will go up making even more heat than normal.
Make sure that your radiator cap is on the top of the cooling system. If the hose comes out of the thermostat housing and goes Up, it could be holding air which is blocking the coolant from getting to the radiator in the first place. Air inside a closed loop can be a real problem so ensure that the coolant can flow without any air pockets.
Also be sure that your radiator's overflow tube is there and working. The system should be able to let out the excess hot coolant when the engine is fully warmed up and flow to the overflow jar. Then as the engine cools down the water should be drawn back into the engine which refills the radiator up to the top. With a bad hose connecting the radiator to the overflow jar the whole system stops helping your car. If you look inside the radiator and can see 6-8" of the upper part of the radiator inside without any coolant, then this is likely a problem. The overflow system allows the engine to have as much coolant inside the radiator as it will allow which helps keeps the car cooler.
Don't forget that a faulty worn out radiator cap will cause the engine to run hotter as it can no longer hold 16 lbs of pressure inside the cooling system. A good 16 lb cap will allow you to get up to ~261* (F) but a bad cap will cause you to get hot at 212* (F). The engine needs to be able to pressurize the cooling system in order to cool more effectively.
To heat barrier
